    [Plugin] TIG-LayerWatcher
    43 Posts 15 Posters 26.7k Views 15 Watching
      You don't need to use "Explode to Layer0" if the container is assigned "Layer0" - therefore it doesn't appear in the context-menu in that case, you can just explode it and its contents will go onto Layer0 anyway...
      The purpose of this alternative exploder is that if the container is on Layer1 and you do a native Explode the geometry that was inside it on Layer0 arrives on Layer1, this alternative way always explodes onto Layer0.
      However I can see times when you might want to use the "Explode to Layer0" on a number of containers, some of which are already assigned Layer0 and they will they get skipped.
      I'll adjust the code and update...
        Here's v9.1 http://sketchucation.com/pluginstore?pln=TIG_LayerWatcher "Explode-To-Layer0" now works on all Containers, even those already assigned Layer0.
        Its final reporting dialog is also enhanced.
          rv1974
          TIG, sorry if I'm requesting in wrong thread..
          Would it be possible to make a tiny script that would silently (via shortcut) repeat the last layer assignment?
          For example I move some geometry to layer 'entourage' then in the future I select other objects, hit shortcut key and they would go to previously assigned 'entourage'.
          Thank you for attention
            It'd be very convoluted, with observers finding changed entities, but even then I can't see how you spot it's been given a new layer, you only know that it has somehow 'changed' but not how it was before that ?
            So I think the answer is, 'No.' 😞
              rv1974
              another option: a small non-modal floating window with one combobox containg layer list to choose from (even hidden ones!) and one button 'assign' (to selected)?
                Having slept on it, the answer is now, 'maybe'...
                Imagine this [new] tool...
                It has TWO menu entries:
                • 'Reassign Layer'
                • 'Repeat Reassign Layer'
                  They can each have their own shortcuts set up...
                The first tool reassigns Selected Containers to a Layer picked from a dropdown list in a dialog.
                The second tool is the same, but this time does it not ask for you to chose a Layer from a dialog - it remembers the last chosen Layer name - unless of course the tool has not been used this session or the previous Layer no longer exists - in which case it does ask you to choose...
                PS: I'll PM you an example...
                • mariochaM
                  mariocha
                  Hi TiG, indeed a great piece of code this is.
                  I had repeated SU crashes on selecting a component and then changing my mind and picking another one in the Component pane before dropping the first one.
                  Disabled all my plugins and finally tracked the bug down to LayerWatcher (v9.1 or maybe before). It being the only one left in the Plugins folder (but for the SU ones).
                  No crash when LayerWatcher is removed.
                  SU 2016, OS El Capitan.
                  It can easily be reproduced.
                  Has anybody else experienced that ?
                  %(#008000)[Mario C.
                    Do you have the latest version of the Extension.
                    It was changed following similar reports...
                    It's now at v9.1
                    If you still have problems please report back...
                    • mariochaM
                      mariocha
                      Sorry I thought I mentioned that it is indeed 9.1
                      It says
                      9.1 20160312 "Explode-To-Layer0" now works on all Containers, even those .... "
                      %(#008000)[Mario C.
                        I have tried the steps you outlined with changing selected [external] components in the browser on a PC and there is no problem.
                        But I can replicate it on a MAC...
                        This has not been reported like this before.
                        The LayerWatcher adds an observer on the entities collection in the model and also the entities collections for all definition's in the model - so it can see if faces or edges are being drawn on a Layer that's not Layer0 and reassign to it.
                        Looks like MAC's SketchUp deals with the temporary external-component-add differently from a PC.
                        On a PC it seems that although the selected external-component appears on the cursor you can choose to NOT place it [ESC or pick another component or tool], and that external-component is still added to the model's components.
                        On a MAC is is shown in the model's components list, but it is removed if it's not placed.
                        I can also trigger this [inconsistently] on a MAC if I select an existing model component to add and while it's on the cursor waiting to be placed I select another external-component to add instead...
                        After some testing I find I can now prevent it happening on a MAC by using a begin..rescue and a start_timer when adding the observer etc...
                        Version 10.0 is in the pipeline, watch for updates...
                        • mariochaM
                          mariocha
                          Great. ! πŸ˜„
                          Pretty useful for me to have all entities of an exploded group back on Layer 0.
                          %(#008000)[Mario C.
                            Here's v10.0
                            Observers to assign new geometry to Layer0 now trapped to avoid MAC BugSplat if multiple external-components picked, but not then added to model.
                            • mariochaM
                              mariocha
                              As a way of saying thanks. Here is a "LanguageHandlered" version of it.
                              French strings included.
                              TIG-LayerWatcher 10-LH.rbz
                              %(#008000)[Mario C.
                                Here's v11.0 which is re-signed for full compatibility with newer SketchUp versions.
                                https://sketchucation.com/pluginstore?pln=TIG_LayerWatcher
                                  Here's v12.0...
                                  It reworked for compatibility with the latest SketchUp v2020, where 'Layer[s]' >> 'Tag[s]' and 'Layer0' >> 'Untagged'.
                                  The Extension is also renamed 'TIG-TagWatcher' in v2020, although the RB code/operation etc is otherwise unchanged.
                                  It is also signed for compatibility with all currently supported SketchUp versions...
                                  • 2 / 3
