    [Plugin] TIG-LayerWatcher
    43 Posts 15 Posters 26.7k Views 15 Watching
      Here's v3.0 http://sketchucation.com/pluginstore?pln=TIG_LayerWatcher It now allows tools [like ACT] to set a layer active that is NOT Layer0 - without the warning message.
      It also allows non-native tools to add geometry onto layers other than Layer0.
      Native tools are still covered...
      • cmeedC
        cmeed
        As always your work and speed is sublime !
        • cmeedC
          cmeed
          If only ACT was updated - it's been the same pain in the a*se for so long now. We don't need those extra layers! I've never needed those camera volumes it produces and you can't turn them off. They keep coming back and It's slow slow slow. Grrrr.
          Grumble grumble.
          • N
            numerobis
            Great little plugin for fixing this idiotic exploding behavior! Thanks!
            And yes... ACT should be fixed too - this large geometry is a joke that makes it unusable!
              DOD3R
              Hello All,
              Allow me to just share my idea on how i deal with this in my workflow.
              I probably as everybody have the habit to save usually at least once in ten minutes, or usually when finishing some steps like component,floor.
              To address the problem of geometry on different layer than 0 I made similar habit of running clean up plugin from ThomThom. I did set up two hotkeys for two kind of settings. First is applicable for solid like geometries with smoothing and deleting edges and the other is practically just geometry on layer 0.
              have a great day everybody.
              T.
                Here's v4.0
                Now trapped for obscure errors from some other plugins' operations affecting its observers etc.
                It has also been made into an 'Extension'.
                  Here's v5.0
                  It has minor tweaks and is also 'future-proofed'.
                    Here's v6.0.
                    It has better reporting of geometry assignment to Layer0 on completion.
                    It also has a few background security tweaks too.
                      Here's v7.0 http://sketchucation.com/pluginstore?pln=TIG_LayerWatcher Its code loading regime has been adjusted in an attempt to avoid an occasional glitch with v2016.
                      • facerF
                        facer
                        TIG,
                        Thank you for the "clever plugin".
                        I can not find a reference to the plugin other than in
                        SketchUcation Plugins Manager and in the "Plugins" folder.
                        How would I "easily" check on which version I am running in the future?
                        All the best for the New Year!
                          @facer said:
                          TIG,
                          Window>Preferences
                          • facerF
                            facer
                            Thank you Dave R,
                            I did not see the plugin's summary at the bottom last time I looked:
                            Version 7.0
                            Creator: TIG
                            Copyright: TIG (c) 2015
                              Here's v8.0 http://sketchucation.com/pluginstore?pln=TIG_LayerWatcher It fixes a reported glitch - where the Layer Observer [spotting the resetting of the current-layer away from Layer0] was not getting transferred across when a new SKP was opened. Now fixed. πŸ˜„
                                Here's v9.0 http://sketchucation.com/pluginstore?pln=TIG_LayerWatcher
                                Read the revised Usage notes on its PluginStore page...
                                BugSplats on MACs when immediately undoing Make Group / Component now avoided.
                                Note that it no longer reassigns the layers of natively Exploded Containers' Geometry [because an unsolvable undo-stack overflow problem when > ~200 pieces of geometry are moved into their new context, because then undo of the explode becomes impossible],
                                BUT there is a new context-menu item "Explode-To-Layer0" - it is only available if the selected Containers are not on Layer0 - it then explodes the Containers and reassigns Layer0 to the resultant Geometry: this explode is then once again properly one-step undo-able, irrespective of the amount of geometry getting moved and reassigned to Layer0.
                                Otherwise its processes and tools are generally as in v8.0...
                                  dan19936
                                  TIG - thank you for this plugin! I've assigned the Explode-To-Layer0 command to my keyboard shortcut, the only problem is that since this is a context sensitive command, groups on layer0 won't explode with my shortcut. The solution is to also use [Plugin] Layer Zero Fixup Tools by slbaumgartner and assign that to your shortcut.
                                  404 Not Found
                                  (sketchucation.com)
                                  Dan
                                    You don't need to use "Explode to Layer0" if the container is assigned "Layer0" - therefore it doesn't appear in the context-menu in that case, you can just explode it and its contents will go onto Layer0 anyway...
                                    The purpose of this alternative exploder is that if the container is on Layer1 and you do a native Explode the geometry that was inside it on Layer0 arrives on Layer1, this alternative way always explodes onto Layer0.
                                    However I can see times when you might want to use the "Explode to Layer0" on a number of containers, some of which are already assigned Layer0 and they will they get skipped.
                                    I'll adjust the code and update...
                                      Here's v9.1 http://sketchucation.com/pluginstore?pln=TIG_LayerWatcher "Explode-To-Layer0" now works on all Containers, even those already assigned Layer0.
                                      Its final reporting dialog is also enhanced.
                                        rv1974
                                        TIG, sorry if I'm requesting in wrong thread..
                                        Would it be possible to make a tiny script that would silently (via shortcut) repeat the last layer assignment?
                                        For example I move some geometry to layer 'entourage' then in the future I select other objects, hit shortcut key and they would go to previously assigned 'entourage'.
                                        Thank you for attention
                                          It'd be very convoluted, with observers finding changed entities, but even then I can't see how you spot it's been given a new layer, you only know that it has somehow 'changed' but not how it was before that ?
                                          So I think the answer is, 'No.' 😞
                                            rv1974
                                            another option: a small non-modal floating window with one combobox containg layer list to choose from (even hidden ones!) and one button 'assign' (to selected)?
                                            • 2 / 3
