    AmbientOcclusion for SketchUp released
    extensions
    42 Posts 15 Posters 16.4k Views 15 Watching
    • F Offline
      fluid
      We just released AmbientOcclusion 1.5.4, you can get it here.
      This version solves a lot of issues, in particular:
      • Layer visibility
      • Slowdowns
      • Imprecise camera placement when rendering big models
      • Group closing when changing view
      • F Offline
        fluid
        We just released a new version of AmbientOcclusion, you can get it here.
        In this new version:
        • Added support for SketchUp 2016
        • Speed improvements and bug fixes
          Error 403 !
          • F Offline
            fluid
            We were experiencing some server issues, it should be working now.
            http://www.ambientocclusion-sketchup.com
            • F Offline
              fluid
              We just added a AmbientOcclusion specific forum to add feature request, show your work in progress and report bugs
              • F Offline
                fluid
                We just released AmbientOcclusion 1.9.0, you can find it here.
                • Added support for Parallel Projection and Two-Point Perspective cameras
                • Add Gain parameter to change overall scene brightness
                • Added support for disabling all section planes at once
                • F Offline
                  fluid
                  We just released a new version of SketchFX that allows to use AmbientOcclusion extension to render ambient occlusion layers directly inside SketchFX. You can get it here.
                  Without AmbientOcclusion Layer:
                  With AmbientOcclusion Layer:
                    spadestick
                    hi fluid, I think you are trying to make this a full renderer somewhat, which makes it really slow on normal systems. Anyhow, is there any way to make a image like the one attached, where I manually photoshopped some kind of occlusion / radiosity in the shadow edges where I think would be appropriate, and leave the lines crisp and clean from direct skethchup output? I it were possible - would it be still as slow as what's happening now? the intention is the give the image more depth than the lack of due to the flat shadows generated in sketchup.
                      spadestick
                      could be really useful for drawings such as these :
                      • F Offline
                        fluid
                        Hi spadestick,
                        What system are you using for testing? AmbientOcclusion should render a scene like the cube above in just a few seconds.
                        Yes, it's possible to have the shadow lines as crisp as the example
                        • F Offline
                          fluid
                          This is a major update, featuring a lot of speed improvements and bug fixes.
                          http://www.fluidinteractive.com/wordpress/wp-content/uploads/2016/03/Villa-1280x720-1030x579.jpg
                          • F Offline
                            fluid
                            We just released AmbientOcclusion Ex, a new version of AmbientOcclusion supporting animation, you can try it here.
                            • F Offline
                              fluid
                              • HDRI environment illumination
                              • Batch rendering to render multiple images at once
                              • Fog support
                              • Added User Manual
                              Here is an animation generated with AmbientOcclusion Ex with HDRI lighting:
                              • F Offline
                                fluid
                                We just released a new version of AmbientOcclusion, you can get it here: http://www.ambientocclusion-sketchup.com
                                This new version adds rendering directly inside the SketchUp viewport.
                                • 2 / 3
