    AmbientOcclusion for SketchUp released
    extensions
    42 Posts 15 Posters 17.3k Views 15 Watching
      Jim
      I like it also because it's easy and fast even on my old laptop. But after I do a few renders, SketchUp gets really slow to do anything. Even just creating a box starts lagging. I'm going to guess you are using SketchUp observers inefficiently.
      • pbacotP
        I guess I don't get it. The rendering looks nice but the shadows look unrealistic to me. A lot people like this sort of thing though.
        EDIT: I don't use SketchUp (live) a lot for project demonstrations, but I did the other day. I admit this feature might have enhanced the appearance of the model in that process.
        • K
          karimtabbara
          Hello
          I've just tryed Ambient Occlusion.
          I read "if you add overlaying on textures (adding support for .jpg/.png textures is enough) then it can be a free alternative to LightUp"
          Sorry but I don't thik so.
          LightUp is maybe 189$ but it's worth it.
          Adam has made a very good plug in.
          Even Incremental Render mode is better and faster then Ambient Occlusion...
          No need to say that wonce fully rendered with Lightup, all scenes need no time to render.
          ... And Ligtup has video Render, Internet plug in, many many settings ...
          Best regards
            spadestick
            too slow on my machine for any real use... it should be instant. perhaps graphics card?
            • F
              fluid
              We just released AmbientOcclusion 1.5.4, you can get it here.
              This version solves a lot of issues, in particular:
              • Layer visibility
              • Slowdowns
              • Imprecise camera placement when rendering big models
              • Group closing when changing view
              • F
                fluid
                We just released a new version of AmbientOcclusion, you can get it here.
                In this new version:
                • Added support for SketchUp 2016
                • Speed improvements and bug fixes
                  Error 403 !
                  • F
                    fluid
                    We were experiencing some server issues, it should be working now.
                    http://www.ambientocclusion-sketchup.com
                    • F
                      fluid
                      We just added a AmbientOcclusion specific forum to add feature request, show your work in progress and report bugs
                      • F
                        fluid
                        We just released AmbientOcclusion 1.9.0, you can find it here.
                        • Added support for Parallel Projection and Two-Point Perspective cameras
                        • Add Gain parameter to change overall scene brightness
                        • Added support for disabling all section planes at once
                        • F
                          fluid
                          We just released a new version of SketchFX that allows to use AmbientOcclusion extension to render ambient occlusion layers directly inside SketchFX. You can get it here.
                          Without AmbientOcclusion Layer:
                          With AmbientOcclusion Layer:
                            spadestick
                            hi fluid, I think you are trying to make this a full renderer somewhat, which makes it really slow on normal systems. Anyhow, is there any way to make a image like the one attached, where I manually photoshopped some kind of occlusion / radiosity in the shadow edges where I think would be appropriate, and leave the lines crisp and clean from direct skethchup output? I it were possible - would it be still as slow as what's happening now? the intention is the give the image more depth than the lack of due to the flat shadows generated in sketchup.
                              spadestick
                              could be really useful for drawings such as these :
                              • F
                                fluid
                                Hi spadestick,
                                What system are you using for testing? AmbientOcclusion should render a scene like the cube above in just a few seconds.
                                Yes, it's possible to have the shadow lines as crisp as the example
                                • F
                                  fluid
                                  This is a major update, featuring a lot of speed improvements and bug fixes.
                                  http://www.fluidinteractive.com/wordpress/wp-content/uploads/2016/03/Villa-1280x720-1030x579.jpg
                                  • F
                                    fluid
                                    We just released AmbientOcclusion Ex, a new version of AmbientOcclusion supporting animation, you can try it here.
                                    • F
                                      fluid
                                      • HDRI environment illumination
                                      • Batch rendering to render multiple images at once
                                      • Fog support
                                      • Added User Manual
                                      Here is an animation generated with AmbientOcclusion Ex with HDRI lighting:
                                      • F
                                        fluid
                                        We just released a new version of AmbientOcclusion, you can get it here: http://www.ambientocclusion-sketchup.com
                                        This new version adds rendering directly inside the SketchUp viewport.
                                        • 2 / 3
