    AmbientOcclusion for SketchUp released
    extensions
    42 Posts 15 Posters 15.0k Views 15 Watching
      karimtabbara
      Hello
      I've just tryed Ambient Occlusion.
      I read "if you add overlaying on textures (adding support for .jpg/.png textures is enough) then it can be a free alternative to LightUp"
      Sorry but I don't thik so.
      LightUp is maybe 189$ but it's worth it.
      Adam has made a very good plug in.
      Even Incremental Render mode is better and faster then Ambient Occlusion...
      No need to say that wonce fully rendered with Lightup, all scenes need no time to render.
      ... And Ligtup has video Render, Internet plug in, many many settings ...
      Best regards
        spadestick
        too slow on my machine for any real use... it should be instant. perhaps graphics card?
        • F Offline
          fluid
          We just released AmbientOcclusion 1.5.4, you can get it here.
          This version solves a lot of issues, in particular:
          • Layer visibility
          • Slowdowns
          • Imprecise camera placement when rendering big models
          • Group closing when changing view
          • F Offline
            fluid
            We just released a new version of AmbientOcclusion, you can get it here.
            In this new version:
            • Added support for SketchUp 2016
            • Speed improvements and bug fixes
              Error 403 !
              • F Offline
                fluid
                We were experiencing some server issues, it should be working now.
                http://www.ambientocclusion-sketchup.com
                • F Offline
                  fluid
                  We just added a AmbientOcclusion specific forum to add feature request, show your work in progress and report bugs
                  • F Offline
                    fluid
                    We just released AmbientOcclusion 1.9.0, you can find it here.
                    • Added support for Parallel Projection and Two-Point Perspective cameras
                    • Add Gain parameter to change overall scene brightness
                    • Added support for disabling all section planes at once
                    • F Offline
                      fluid
                      We just released a new version of SketchFX that allows to use AmbientOcclusion extension to render ambient occlusion layers directly inside SketchFX. You can get it here.
                      Without AmbientOcclusion Layer:
                      With AmbientOcclusion Layer:
                        spadestick
                        hi fluid, I think you are trying to make this a full renderer somewhat, which makes it really slow on normal systems. Anyhow, is there any way to make a image like the one attached, where I manually photoshopped some kind of occlusion / radiosity in the shadow edges where I think would be appropriate, and leave the lines crisp and clean from direct skethchup output? I it were possible - would it be still as slow as what's happening now? the intention is the give the image more depth than the lack of due to the flat shadows generated in sketchup.
                          spadestick
                          could be really useful for drawings such as these :
                          • F Offline
                            fluid
                            Hi spadestick,
                            What system are you using for testing? AmbientOcclusion should render a scene like the cube above in just a few seconds.
                            Yes, it's possible to have the shadow lines as crisp as the example
                            • F Offline
                              fluid
                              This is a major update, featuring a lot of speed improvements and bug fixes.
                              http://www.fluidinteractive.com/wordpress/wp-content/uploads/2016/03/Villa-1280x720-1030x579.jpg
                              • F Offline
                                fluid
                                We just released AmbientOcclusion Ex, a new version of AmbientOcclusion supporting animation, you can try it here.
                                • F Offline
                                  fluid
                                  • HDRI environment illumination
                                  • Batch rendering to render multiple images at once
                                  • Fog support
                                  • Added User Manual
                                  Here is an animation generated with AmbientOcclusion Ex with HDRI lighting:
                                  • F Offline
                                    fluid
                                    We just released a new version of AmbientOcclusion, you can get it here: http://www.ambientocclusion-sketchup.com
                                    This new version adds rendering directly inside the SketchUp viewport.
                                    • 2 / 3
