AmbientOcclusion for SketchUp released
Error 403 !
We were experiencing some server issues, it should be working now.
http://www.ambientocclusion-sketchup.com -
We just added a AmbientOcclusion specific forum to add feature request, show your work in progress and report bugs
We just released AmbientOcclusion 1.9.0, you can find it here.
In this new version:
- Added support for Parallel Projection and Two-Point Perspective cameras
- Add Gain parameter to change overall scene brightness
- Added support for disabling all section planes at once
- Speed improvements and bug fixes
We just released a new version of SketchFX that allows to use AmbientOcclusion extension to render ambient occlusion layers directly inside SketchFX. You can get it here.
Without AmbientOcclusion Layer:
With AmbientOcclusion Layer:
hi fluid, I think you are trying to make this a full renderer somewhat, which makes it really slow on normal systems. Anyhow, is there any way to make a image like the one attached, where I manually photoshopped some kind of occlusion / radiosity in the shadow edges where I think would be appropriate, and leave the lines crisp and clean from direct skethchup output? I it were possible - would it be still as slow as what's happening now? the intention is the give the image more depth than the lack of due to the flat shadows generated in sketchup.
could be really useful for drawings such as these :
Hi spadestick,
What system are you using for testing? AmbientOcclusion should render a scene like the cube above in just a few seconds.
Yes, it's possible to have the shadow lines as crisp as the example -
We just released a new version of AmbientOcclusion, you can get it here
This is a major update, featuring a lot of speed improvements and bug fixes.
We just released AmbientOcclusion Ex, a new version of AmbientOcclusion supporting animation, you can try it here.
- HDRI environment illumination
- Batch rendering to render multiple images at once
- Fog support
- Added User Manual
Here is an animation generated with AmbientOcclusion Ex with HDRI lighting:
We just released a new version of AmbientOcclusion, you can get it here: http://www.ambientocclusion-sketchup.com
This new version adds rendering directly inside the SketchUp viewport.
