    Error message
    18 Posts 6 Posters 2.3k Views 6 Watching
    • pmolsonP
      pmolson
      @dave r said:
      Frederik, I'd ask the same question of you that I asked of Paul.
      Try sending your model to your rendering app (Are you still using KT?) and get it started rendering. Settings don't matter. Then go back to SU and save the model. Does it throw up this error message? Also looking in the directory where the file was saved after the error. Do you see that the file name now ends in -0.skp?
      Hi Dave, Yes it does create the filename 0.skp when it happens.
      I do use podium, but this happens on files I have never rendered as well as files I have rendered.
      The filename 0.skp had me thinking of podium as a culprit because podium does something simalar when a save is attempted during the rendering process. I don't think this is the case here though in that it happens when podium is not running.
      • pmolsonP
        pmolson
        @rich o brien said:
        Hi Paul,
        Do any of your files reside on a network or external storage?
        nope
          I think Dave is probably correct but in the off chance does this happen with every file or one in particular?
          Does it happen after you have done a render with Podium?
          • pmolsonP
            pmolson
            All files.
            Happens regardless of render or no render.
            many of the files I have never rendered and never will.
            p
              I've been working with one of the folks on the SketchUp team because I get this error. I narrowed it down to working in Kerkythea and then going back to SketchUp and saving the file. They were able to duplicate the issue in Boulder. It's entirely possible this would happen with other rendering applications such as Podium and perhaps there are other programs that users might be running which result in the same problem. They are at least aware of it and working on a resolution.
              • pmolsonP
                pmolson
                Thanks Dave!
                • hellnbakH
                  hellnbak
                  I sometimes get a 0.skp file, and I don't use ANY rendering programs
                    I guess you mean you sometimes get a file called 0.skb. This is entirely different from the CFileException0 error message.
                    • FrederikF
                      Frederik
                      I don't use KT any more... Haven't used it for 6 years or so...
                      I use Thea Render, but although I don't touch it at all, I still get this error message occasionally...?!?
                      I don't see such a file...
                      I can only repeat myself...
                      @frederik said:
                      Unfortunately I don't have pattern, hence I can't replicate it by following some steps...
                      Cheers
                      Kim Frederik
                      • pmolsonP
                        pmolson
                        Thought I would update you all on this problem that I was having. Apparently it was render engine related. Even though I was not running the rendering application when I was getting the error apparently it was still the issue. Podium has put out a Beta release. after installing it I have not had the issue since.
                        • hellnbakH
                          hellnbak
                          Just for the record, I did mean 0.skp, as in...
                          • PixeroP
                            Pixero
                            Just for the record I have had this error too.
                              Dredging up old stuff.
                              There are two different messages that seem to pop up. One is related to creating backup files that get named 0.skb and the other like Paul and I had. Yours seems to make it three.
