    SUbD toggle for multiple groups/components
    renderpluginsextensions
    13 Posts 4 Posters 10.2k Views 4 Watching
      Yes, this is high up on the list for next release.
      Feel free to posts your wishes - I'd love to hear them! πŸ˜„
      • Z Offline
        ZahariStoyanov
        A little bit further - being able to group symmetrical components and SubD them as one solid object. Cars are a perfect example - let's say you make half of the hood and mirror it - you'd want to keep the editable half and at the same time SubD the whole thing with nicely flowing subdivision including the symmetry contour - like in Blender πŸ˜„
        • Z Offline
          ZahariStoyanov
          Here's the visual explanation:
          The Control Mesh:
          This happens when the two halves are SubD'd separately:
          And this is how it's actually supposed to look:
          Currently, to achieve that, you need to explode the halves and re-group them in one. By doing that, however, you lose the ability to edit the half and automatically apply the changes to the other half πŸ˜„
            You apply crease to the corner vertices - that avoids the rounding.
            In SUbD v2 there is a new default subdivision mode that will keep corners sharp. (Can be change off course.)
            I've been modelling this car with using mirrored components to create symmetry:
              Yea, it doesn't work well unless it's a planar joint.
              There is actually a feature in OpenSubdiv that takes this into account. The outer set of faces are not displayed, but taken into account when subdividing. I've yet to try it out though - I' not so convinced how usable that workflow would be.
              • Z Offline
                ZahariStoyanov
                [attachment=3:3jayf6gc]<!-- ia3 -->2016-04-16_13h52_32.png<!-- ia3 -->[/attachment:3jayf6gc]
                Corners - ok. But the whole edge between the two components appears as creased and you can't un-crease it because it's a contour πŸ˜„
                [attachment=2:3jayf6gc]<!-- ia2 -->ControlMesh.png<!-- ia2 -->[/attachment:3jayf6gc]
                [attachment=1:3jayf6gc]<!-- ia1 -->SubDividedInHalves.png<!-- ia1 -->[/attachment:3jayf6gc]
                [attachment=0:3jayf6gc]<!-- ia0 -->SubDividedAsOne.png<!-- ia0 -->[/attachment:3jayf6gc]
                So one approach could be to treat everything inside a group/component as one solid just for the sake of a smooth transition. In the given case - group the two halves(without having them exploded) and then apply SubD. Instead of giving the "nested group" error, this could be used to treat the two pieces as one and get the edge between them flowing like the other loops πŸ˜„
                • Z Offline
                  ZahariStoyanov
                  Sounds promising! Damn, I always forget about the oncoming OpenSubdiv implementation πŸ˜„
                    I sometimes forget it's not released. πŸ˜„
                      Nor is it in testing 😞
                        Soon. Need to get the cursed UV mapping sorted out.
                        • N Offline
                          numerobis
                          πŸ‘
                          This was the next thing i wanted to ask. I suppose this comes with the OpenSubdiv standard?
                          Is there a way to get the texture problems fixed for the next version? As it works now i have to apply the texture to the subdivided geometry because it gets distorted by the subdivision and the material is lost when i switch back to the base mesh. Is this what you mean by "cursed UV mapping"?
                            I hope that OpenSubdiv will improve texture mapping. But I've yet to see - I need to get it hooked up. But I'm hoping that OSD along with WrapR will make a killer combo. πŸ˜„
