    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
      Anton_S
      @faust07 said:
      Great news, Anton. Short question: I want this Topic not bloat with simple examples and tests. Should I better open a new topic as entitled "MSPhysics examples and tests"?
      Yes, I can see that you already did. However because there aren't many tutorials on how to use MSPhysics and because its generally not done, the topic could be quite empty for a while, but don't worry once the project is done, I'm gonna help you fill it in.
      @pituphysics said:
      In the MSPhysics at present there is no "Controller Panel".
      Anton is likely to put into it as well. For the time being, you can control the keyboard.
      Yep, I'm planning to put in all the feature of SketchyPhysics and more.
      • G
        gepponline77
        Thanks PituPhysics, now I can move my objects.
        Still some doubts about parameters (like controller and min-max position)
        But it start to be clearer
        • P
          pnickles
          SU2016 Plugins folder location:
          C:\Users[USERNAME]\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins
          • P
            PituPhysics
            Just write this: %APPDATA%\SketchUp\SketchUp 2016\SketchUp\Plugins
            The USERNAME is will be automatically detected. Or here is shortcuts 2014+ in zip archive:
            Plugins Shortcuts.zip
              Anton_S
              Announcing 0.6.0. See change-log here: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/CHANGELOG.md
              • F
                faust07
                Usefully new options, functions and joints!
                What is meant with the Sliders Control Panel? A control panel for the slider joint in MSPhysics UI or a Joint Controller Panel with slider input similar to SP (couldn't find it...)?
                  Anton_S
                  Faust, the control panel displays only when necessary, that is when there are actually slider controllers. The control panel will display in the lower-right corner when simulation is started. Here is an example that uses a slider controllers.
                  Arrow keys to drive and slider to raise suspension.
                  • jenujacobJ
                    jenujacob
                    i know what i am gonna ask may be way too optimistic but can we have something similar to whats shown here? πŸ˜„ love the way u can paint over a couple of selected objects and just 'drop 'em'!
                    http://hocuspocus-studio.fr/tools/product/physx-painter/
                      So many times I wished for a tool like that!
                      • P
                        PituPhysics
                        Super the new, transparent Control Panel. πŸ‘
                          Anton_S
                          Announcing 0.7.0: Change Log
                          Here is a little turret with particle effects.
                          turret.skp
                          • F
                            faust07
                            Wow, what an update rate and what significant new features. Thanks!!! Let's test the best ... And another (shameless ...) request: Would it be possible to save the replay data with the model to call this stored simulation again in another session?
                            • P
                              PituPhysics
                              OMG πŸ˜„ it's very cool. And good the innovation on UI dialog.
                              I will try the "create_particle" function.
                              • F
                                faust07
                                Example turret works under Windows 7, SU16 make very good. But immediate BugSplat under Windows 8.1, SU16 make (have to test more). Smoke and fire are not reproduced in Replay. And ... if the velocity is too low, the sun will never shine again ... πŸ˜‰
                                • F
                                  faust07
                                  @PituPhysics: cool new MSPhysics models in 3D-Warehouse πŸ‘
                                  • F
                                    faust07
                                    How does the added curve functions (similar to SketchyPhysics) work? Can't wait to see an example because my attempts to transform SP-scripts to MSP will take years...
                                    • B
                                      BallBearing
                                      At first glance MSPhysics working "mostly", nicely with SPGears & Linux SU8. When Using UI only simulation tab works on Linux / Wine.
                                      SketchUp, 3D printing stuff and more:
                                      http://www.youtube.com/user/CinemaTablet
                                      • P
                                        PituPhysics
                                        What exactly do you think? curve.skp
                                        • F
                                          faust07
                                          Yes, this is exactly what I mean. Thank you very much! The first step to this:
                                          path following bird
                                            Anton_S
                                            Hey faust, here is your birdy configured to work on MSPhysics and SketchyPhysics. I think it needs some adjustments though.
                                            BirdTest01SUF.skp
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 46
                                            • 47
                                            • 13 / 47
