    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 932.2k Views 172 Watching
      PituPhysics
      @pituphysics said:
      @gepponline77 said:
      Sorry but for me is really unclear.
      What should i have to write?
      Controller field is a single line field.
      So eventually i can insert only a row of what you have write above.
      I paste "rightx Left - right arrows" in the controller field, press the play button and press left and right arrow but nothing happen.
      Of course is my fault.
      But could you gave mme an example step by step of using a piston joint?
      I made an test model: [attachment=0:1hwdkrag]<!-- ia0 -->piston test.skp<!-- ia0 -->[/attachment:1hwdkrag]
      Succeeded solve?
      • F Offline
        faust07
        Very good example and important notes above. It works.
          Anton_S
          @faust07 said:
          Great news, Anton. Short question: I want this Topic not bloat with simple examples and tests. Should I better open a new topic as entitled "MSPhysics examples and tests"?
          Yes, I can see that you already did. However because there aren't many tutorials on how to use MSPhysics and because its generally not done, the topic could be quite empty for a while, but don't worry once the project is done, I'm gonna help you fill it in.
          @pituphysics said:
          In the MSPhysics at present there is no "Controller Panel".
          Anton is likely to put into it as well. For the time being, you can control the keyboard.
          Yep, I'm planning to put in all the feature of SketchyPhysics and more.
            gepponline77
            Thanks PituPhysics, now I can move my objects.
            Still some doubts about parameters (like controller and min-max position)
            But it start to be clearer
              pnickles
              SU2016 Plugins folder location:
              C:\Users[USERNAME]\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins
                PituPhysics
                Just write this: %APPDATA%\SketchUp\SketchUp 2016\SketchUp\Plugins
                The USERNAME is will be automatically detected. Or here is shortcuts 2014+ in zip archive:
                Plugins Shortcuts.zip
                  Anton_S
                  Announcing 0.6.0. See change-log here: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/CHANGELOG.md
                  • F Offline
                    faust07
                    Usefully new options, functions and joints!
                    What is meant with the Sliders Control Panel? A control panel for the slider joint in MSPhysics UI or a Joint Controller Panel with slider input similar to SP (couldn't find it...)?
                      Anton_S
                      Faust, the control panel displays only when necessary, that is when there are actually slider controllers. The control panel will display in the lower-right corner when simulation is started. Here is an example that uses a slider controllers.
                      Arrow keys to drive and slider to raise suspension.
                      • jenujacobJ Offline
                        jenujacob
                        i know what i am gonna ask may be way too optimistic but can we have something similar to whats shown here? πŸ˜„ love the way u can paint over a couple of selected objects and just 'drop 'em'!
                        http://hocuspocus-studio.fr/tools/product/physx-painter/
                          So many times I wished for a tool like that!
                            PituPhysics
                            Super the new, transparent Control Panel. πŸ‘
                              Anton_S
                              Announcing 0.7.0: Change Log
                              Here is a little turret with particle effects.
                              turret.skp
                              • F Offline
                                faust07
                                Wow, what an update rate and what significant new features. Thanks!!! Let's test the best ... And another (shameless ...) request: Would it be possible to save the replay data with the model to call this stored simulation again in another session?
                                  PituPhysics
                                  OMG πŸ˜„ it's very cool. And good the innovation on UI dialog.
                                  I will try the "create_particle" function.
                                  • F Offline
                                    faust07
                                    Example turret works under Windows 7, SU16 make very good. But immediate BugSplat under Windows 8.1, SU16 make (have to test more). Smoke and fire are not reproduced in Replay. And ... if the velocity is too low, the sun will never shine again ... πŸ˜‰
                                    • F Offline
                                      faust07
                                      @PituPhysics: cool new MSPhysics models in 3D-Warehouse πŸ‘
                                      • F Offline
                                        faust07
                                        How does the added curve functions (similar to SketchyPhysics) work? Can't wait to see an example because my attempts to transform SP-scripts to MSP will take years...
                                          BallBearing
                                          At first glance MSPhysics working "mostly", nicely with SPGears & Linux SU8. When Using UI only simulation tab works on Linux / Wine.
                                          SketchUp, 3D printing stuff and more:
                                          http://www.youtube.com/user/CinemaTablet
                                            PituPhysics
                                            What exactly do you think? curve.skp
                                            • 46
                                            • 47
                                            • 4 / 47
