    Push/pull double click wrong direction
    32 Posts 12 Posters 7.0k Views 12 Watching
      slbaumgartner
      As I think has already been noted, software does not act randomly. The problem is that sometimes the logic is obscure and confusing. SketchUp has some "helpful" behaviors such as always orienting a new face at z=0 so that the "front" faces downward, and automatically creating a "hole" when pushpulling a face that is inset in another face, having a hidden sign to the direction of pushpull, etc. The interaction of these behaviors can be quite confusing, but it isn't random.
      • ely862meE
        ely862me
        I get this behavior from time to time too, I believe is somehow user related.
        Elisei (sketchupper)
        Come and See EliseiDesign
          Macker
          I just recorded it happening. The second push/pull operation is a double click. You can see the correct face orientation on the first, and the distance typed, and the direction.
          https://christopher-robertslimbrick.tinytake.com/sf/NDY5NzI2XzI1MTk1MjU
          Check out my blog @ http://macviz.blogspot.co.uk
            Macker
            No ideas?
              Macker
              Got it happening again in another model...
              https://christopher-robertslimbrick.tinytake.com/sf/NTE1ODc0XzI3MTY2NTE
              See, I'm not going mad. This behavior happens.
              • Bob JamesB
                Bob James
                Just in case you are going mad, I join you.
                Nevertheless, no amount of "you must be doing..." or "it can't happen" is going to change the fact that Yes it does happen.
                • pbacotP
                  It's there and is probably predictable (but the causes are also probably too complex for mere mortals to pin down).
                  • L
                    lmfarmer
                    I, too, am having this issue, and it happens pretty consistently in 2016, doesn't happen at all in 2015. If not everybody is having the problem, could it be a PC vs Mac thing? I'm on a Mac. Are the others of you having this issue all on Macs? I haven't checked this out on Sketchup.com, but that's where I'm going next.
                    • tuna1957T
                      tuna1957
                      know this post has been around awhile, thought I'd chime in that I see the same odd behavior at times. it does seem totally random and unpredictable. Example would be creating a frame and panel look to a wall, recessing panels 1/2" ,running a wall same axis ,double clicking away and viola it pulls a panel instead of pushing. Also seems to occasionally not erase a face when punching holes in walls. no predictability may go weeks without issues than problems pop up in a model . go figure. exit the tool and go back to push pull and everything o.k.?
                      • L
                        lmfarmer
                        If anybody is interested, here's a link to the thread started by my post on this subject on the Sketchup Community forum. While the issue isn't totally "solved," I'm satisfied with the answers I got from the SketchUp team, and particularly some of John's explanations were quite helpful. http://forums.sketchup.com/t/2016-push-pull-double-click-pulls-in-opposite-direction/23140
                        • 2 / 2
