    Push/pull double click wrong direction
    32 Posts 12 Posters 7.4k Views 12 Watching
      Macker
      I absolutely guarantee you that they are facing the correct way. I always model in front/back/monochrome view.
      Check out my blog @ http://macviz.blogspot.co.uk
        slbaumgartner
        As I think has already been noted, software does not act randomly. The problem is that sometimes the logic is obscure and confusing. SketchUp has some "helpful" behaviors such as always orienting a new face at z=0 so that the "front" faces downward, and automatically creating a "hole" when pushpulling a face that is inset in another face, having a hidden sign to the direction of pushpull, etc. The interaction of these behaviors can be quite confusing, but it isn't random.
        • ely862meE
          ely862me
          I get this behavior from time to time too, I believe is somehow user related.
          Elisei (sketchupper)
          Come and See EliseiDesign
            Macker
            I just recorded it happening. The second push/pull operation is a double click. You can see the correct face orientation on the first, and the distance typed, and the direction.
            christopher-robertslimbrick
            Trusted by over 1 million users, MangoApps is the leading social collaboration, instant messaging, project management, document management and task management tools.
            (christopher-robertslimbrick.tinytake.com)
              Macker
              No ideas?
                Macker
                Got it happening again in another model...
                See, I'm not going mad. This behavior happens.
                • Bob JamesB
                  Bob James
                  Just in case you are going mad, I join you.
                  Nevertheless, no amount of "you must be doing..." or "it can't happen" is going to change the fact that Yes it does happen.
                  • pbacotP
                    It's there and is probably predictable (but the causes are also probably too complex for mere mortals to pin down).
                    • L
                      lmfarmer
                      I, too, am having this issue, and it happens pretty consistently in 2016, doesn't happen at all in 2015. If not everybody is having the problem, could it be a PC vs Mac thing? I'm on a Mac. Are the others of you having this issue all on Macs? I haven't checked this out on Sketchup.com, but that's where I'm going next.
                      • tuna1957T
                        tuna1957
                        know this post has been around awhile, thought I'd chime in that I see the same odd behavior at times. it does seem totally random and unpredictable. Example would be creating a frame and panel look to a wall, recessing panels 1/2" ,running a wall same axis ,double clicking away and viola it pulls a panel instead of pushing. Also seems to occasionally not erase a face when punching holes in walls. no predictability may go weeks without issues than problems pop up in a model . go figure. exit the tool and go back to push pull and everything o.k.?
                        • L
                          lmfarmer
                          If anybody is interested, here's a link to the thread started by my post on this subject on the Sketchup Community forum. While the issue isn't totally "solved," I'm satisfied with the answers I got from the SketchUp team, and particularly some of John's explanations were quite helpful. http://forums.sketchup.com/t/2016-push-pull-double-click-pulls-in-opposite-direction/23140
                          • 2 / 2
