    [Preview] Wrap-R Video #3
    extensions
    42 Posts 12 Posters 8.6k Views 12 Watching
      @rv1974 said:
      The goal is to place dark strips parallel to expanding side borders seamlessly. Could you post the video?
      Is this what you are looking to do?
      • olisheaO
        olishea
        this is unbelievable for SU
        oli
          @oli
          it could be a hoax though....
          • tuna1957T
            tuna1957
            Fantastic........ no mac version , I'll go sit in the corner and pout now.......
            • olisheaO
              olishea
              @rich o brien said:
              @oli
              It's not April 1st though mate!
              I used to think that all the time so I just bought a PC instead. Much easier! πŸ˜„
              oli
                rv1974
                Thank you! Yes, the result you delivered is what I expected to get.
                A couple of notes:
                1. There's strong ripple distortion of the checker texture. It will seen if finer textures (like decking or tiles) will be applied. Ho to fight this issue?
                  2.We saw lots of tedious manual labor. Do you have any plans to automate somehow the aligning part?
                  There's by no means any bit of criticism- I only try to clarify the things.
                • JQLJ
                  JQL
                  I see a lot more manual work on my current process right now
                  www.casca.pt
                  Visit us on facebook!
                    Ripples are because the texture in the viewport is not a bitmap. here's the result for you to look at...
                    road-wrapr-rv.skp
                    Of course. First we need to nail down to workflow then add the features.
                      rv1974
                      I'd disagree. I replaced the asphalt texture with decking and this here's result. It's important in Archviz and it should be addressed.
                        That's interesting.
                        I'll look at this.
                        One thing worth noting is we're only process Tri meshes. Distortions like this are artefacts of such meshes.
                        But not the outcome we want. Thanks for the heads up.
                        • Bob JamesB
                          Bob James
                          @cmeed said:
                          So this unwrapping is one step further to texturing a model or asset that fredo paint for example, can do?
                          Fredo's extension is a great tool, but the Substance programs (Designer, Painter and BTM) along with SubstanceTheaConverter gives you much more power to add things like worn edges and other "realistic defects".
                          However, to do that you need an unwrapped version of your model. That's why Wrap-R is so critically important.
                            @rv1974 said:
                            I replaced the asphalt texture with decking...
                            What replacement method did you use? I'm not getting the same result.
                            • cmeedC
                              cmeed
                              Riiiiight got it! The ramp clip is a good example - revelation time.
                                rv1974
                                Thomtom's replace material all the way.
                                But you'd get the same result even without replacing, try attached.
                                p.s. it was discussed 4 years ago.
                                http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=44552%26amp;start=30
                                p.p.s. Doh! moment: PaintThru delivers almostperfect result in this specificcase, see printscreen
                                deck_ramp.rar
                                  rv1974
                                  Higher subdivision works well even in harder situations; if Wrap-R could map it right without adding more poly counts it'd be step further.
                                  deck_ramp2.rar
                                  • 2 / 3
