    [Preview] Wrap-R Video #3
    extensions
    42 Posts 12 Posters 8.6k Views 12 Watching
    • Bob JamesB
      Bob James
      I hope to use it to unwrap models to use in Substance Painter.
      • FrederikF
        Frederik
        +1
        Cheers
        Kim Frederik
          I intend to use it for Minecraft.
          • cmeedC
            cmeed
            So Substance painter then .... Thea or render package?
            Basic question - as I use 'thea for sketchup' will wrap-r after its unwrapped a model then it's sent back to sketchup for 'thea for sketchup' to render - will sketchup hold this wrapped/unwrapped information?
            So this unwrapping is one step further to texturing a model or asset that fredo paint for example, can do?
              rv1974
              Rich, I'm curious how your tool would treat the attached most primitive ramp. The goal is to place dark strips parallel to expanding side borders seamlessly. Could you post the video?
              Another example:
              http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=44552%26amp;start=150
              post #5 from below. Could Pap-R apply an un-distorted texture on every turn of the attached cornice?
              Untitled.rar
              • FrederikF
                Frederik
                Any render application will benefit from it...
                Of course...
                It's a question about the UV- and UVW-mapping...
                Cheers
                Kim Frederik
                  Is this what you are looking to do?
                  • olisheaO
                    olishea
                    this is unbelievable for SU
                    oli
                      @oli
                      it could be a hoax though....
                      • tuna1957T
                        tuna1957
                        Fantastic........ no mac version , I'll go sit in the corner and pout now.......
                        • olisheaO
                          olishea
                          @rich o brien said:
                          @oli
                          It's not April 1st though mate!
                          I used to think that all the time so I just bought a PC instead. Much easier! πŸ˜„
                          oli
                            rv1974
                            Thank you! Yes, the result you delivered is what I expected to get.
                            A couple of notes:
                            1. There's strong ripple distortion of the checker texture. It will seen if finer textures (like decking or tiles) will be applied. Ho to fight this issue?
                              2.We saw lots of tedious manual labor. Do you have any plans to automate somehow the aligning part?
                              There's by no means any bit of criticism- I only try to clarify the things.
                            • JQLJ
                              JQL
                              I see a lot more manual work on my current process right now
                              www.casca.pt
                              Visit us on facebook!
                                Ripples are because the texture in the viewport is not a bitmap. here's the result for you to look at...
                                road-wrapr-rv.skp
                                Of course. First we need to nail down to workflow then add the features.
                                  rv1974
                                  I'd disagree. I replaced the asphalt texture with decking and this here's result. It's important in Archviz and it should be addressed.
                                    That's interesting.
                                    I'll look at this.
                                    One thing worth noting is we're only process Tri meshes. Distortions like this are artefacts of such meshes.
                                    But not the outcome we want. Thanks for the heads up.
                                    • Bob JamesB
                                      Bob James
                                      Fredo's extension is a great tool, but the Substance programs (Designer, Painter and BTM) along with SubstanceTheaConverter gives you much more power to add things like worn edges and other "realistic defects".
                                      However, to do that you need an unwrapped version of your model. That's why Wrap-R is so critically important.
                                        @rv1974 said:
                                        I replaced the asphalt texture with decking...
                                        What replacement method did you use? I'm not getting the same result.
                                        • cmeedC
                                          cmeed
                                          Riiiiight got it! The ramp clip is a good example - revelation time.
                                            rv1974
                                            Thomtom's replace material all the way.
                                            But you'd get the same result even without replacing, try attached.
                                            p.s. it was discussed 4 years ago.
                                            http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=44552%26amp;start=30
                                            p.p.s. Doh! moment: PaintThru delivers almostperfect result in this specificcase, see printscreen
                                            deck_ramp.rar
                                            • 2 / 3
