    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 927.3k Views 172 Watching
    • W Offline
      WronskiKamil
      Will it be possible to export the animation to vray in the future? Maybe in the next version;)?
        jeep906
        Dear author! I apologize for my English, I translate Google translator.
        Is it possible to save the properties of individual objects defined in the MSPhysics UI tool when combining these objects into a common group?
        if there is no such possibility in this plugin, I am ready to pay for writing a new one, where there is such an opportunity. Please help me!
          tayyab2224
          As far as i know , it is not possible in this version, anton_s might be busy anywhere else .
          M. Tayyab
            Anton_S
            With the current version, it is not possible to assign properties to internal groups. The new version, that I am developing, will support this functionality.
            I am honestly working on the project, just not as actively. I have been focused on other things. NewtonDynamics, the physics engine used by MSPhysics, has become much more stable and robust with joints than before. We will no longer experience the weird behavior of those flexible and wandering joints and have much better experience with developing robotics. I am driven to develop the new version. Thanks for your interest in the project!
            • F Offline
              faust07
              Thanks for the information on the further development of MSPhysics. That sounds great. Will the old models be compatible with the new version?
                Anton_S
                Unfortunately MSPhysics 2 won't be compatible with current models. This time, any object intended for simulation will have to be marked explicitly, rather than excluding unwanted with the Ignore option. Scripting docs is going to be different as well. My intention is to focus on usability and tutorials with this one.
                • H Offline
                  Hza
                  Hello Anton, thanks for the great extension! Please, when we can expect release of the MSPhysics 2?
                  thanks again!
                  Hza
                    Anton_S
                    thanks again!
                    Hza
                    The first beta version should be ready in a few months.
                      jumpjack
                      Does it exist a library of mechanisms for MSP? I can find only a dozen models on warehouse.
                        kaoru_komine
                        I am commenting for the first time.
                        Thanks to the author for the great plugin.
                        I'm looking forward to the new version of "MSPhysics".
                        Now, I have a question about "MSPhysics2".
                        I use Ruby scripts that can be input from the UI to control the 3D model in the current "MSPhysics".Is it possible to do the same thing with "MSPhysics2"?
                          Anton_S
                          Yes, scripting will still be available with MSPhysics2. The scripting API will be different, however.
                            Anton_S
                            As mentioned earlier, MSPhysics 1 has weak joints, in which case creating mechanical interconnections between rods, suspension, robotic arms, and what not, makes the resulting structure weak and loose, unless all interconnected groups have an identical mass. MSPhysics 2 should be able to address this issue. I haven't yet tested that, and I am a little behind with my promises on the development of the project, but as mentioned earlier, I am very exited to utilize the newer NewtonDynamics version for this, which showed promising results with the stable and robust interlinked joint behavior.
                              tayyab2224
                              I hope we will enjoy MSP2 this summer۔۔۔
                              M. Tayyab
                                daniabreu1
                                Looking forward to see the new version of this plugin that it will work on new versions of SU. Keep updating us! Thank you! 😄
                                  tayyab2224
                                  What if flying simulation in msp2 ?
                                  M. Tayyab
                                    Anton_S
                                    You mean aerodynamics? I am planning to implement Newtonian drag (already developed in ClothWorks for simulating flags and parachute effects). Newtonian drag alone does not provide accurate results, as it does not involve turbulence and additional actors, but should yield useful results for simulating wings.
                                      sheadacus
                                      Hello is there anyway to combine a slider and servo motor. Similar to the corkscrew but I need it to move apart automatically in twisting and sliding a certain distance and angle. Whenever I do a slider I cant move the servo and vice versa.
                                        Anton_S
                                        Hi! Yes, there is. To do this, you need two groups. One way to do this is by having slider as a top level joint and servo as an inner level joint:
                                        1. Create two box groups positioned next to each other.
                                        2. Create a slider joint at the top level, next to group A.
                                        3. Create a servo joint, one level inside group A.
                                        4. Using the joint connection tool, connect servo to group B.
                                        5. Then, connect slider to group A.
                                          In this scenario, group A will be constrained to the slider and group B will be constrained to a servo, with respect to group A.
                                          mauroa6
                                          Good morning
                                          I installed MSPhysic 1.0.3 and related AMS 3.6.0h libraries, but when opening SketchUp I get this error ...
                                          Errore di caricamento del file C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb
                                          Error: #<IOError: The required, staged c extension file, "C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.5/msp_lib.so", is missing!>
                                          C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:in block in require_all' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in each'
                                          C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in require_all' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main.rb:70:in <top (required)>'
                                          C:/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require' C:/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require'
                                          C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in <top (required)>' C:/SketchUp 2019/Tools/extensions.rb:197:in require'
                                          C:/SketchUp 2019/Tools/extensions.rb:197:in load' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in register_extension'
                                          C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in <module:MSPhysics>' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:5:in <top (required)>'
                                            tayyab2224
                                            @mauroa6 said:
                                            Good morning
                                            MsP NOT WORKS IN 2017-2020.
                                            M. Tayyab
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 43 / 47
