    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
    • F
      faust07
      Sounds good. This could be a reason to purchase SketchUp 2019...
        steambuf
        been looking for an animator for some time and have looked at this plugin with Sketchup 2017 Make to keep the costs down to zero. The new version of Free Sketchup is on line only so no use to me.
        I cannot get the joints to remain located exactly and the objects drift apart after a short period of time.
        I also downloaded a steam beam engine model with full animation. this worked fine for a couple of iterations and then proceeded to disintegrate due to drifting of the joints.
        Is this just me of is this an ongoing problem with this plug in?
        If I could get it to work it would be a terrific program. everything seems to work except this drifting of the joints. pity I've spent quite a bit of time trying to make it work.
          Anton_S
          @steambuf Yes, joints are a problem. I wm hoping that an updated version of nrwton dynamics physics engine addresses the problem. In the meantime, joint stiffness is best, if all connected bodies are of the same mass and solver model is set to itetative 64 passes. To change the mass of a body, use the UI.
            steambuf
            Thanks for the reply.
            Much appreciated!!
            Will play with it a bit more and try your suggestions. I really love what you are doing to keep the fun in programming and sharing your knowledge and skill with others.
            I'm now retired and trying to keep my brain active and you are helping me do that.
            Thanks again and would love to see an update to the non sticky joints???
            Cheers Peter
            • W
              WronskiKamil
              Will it be possible to export the animation to vray in the future? Maybe in the next version;)?
                jeep906
                Dear author! I apologize for my English, I translate Google translator.
                Is it possible to save the properties of individual objects defined in the MSPhysics UI tool when combining these objects into a common group?
                if there is no such possibility in this plugin, I am ready to pay for writing a new one, where there is such an opportunity. Please help me!
                • T
                  tayyab2224
                  As far as i know , it is not possible in this version, anton_s might be busy anywhere else .
                  M. Tayyab
                    Anton_S
                    With the current version, it is not possible to assign properties to internal groups. The new version, that I am developing, will support this functionality.
                    I am honestly working on the project, just not as actively. I have been focused on other things. NewtonDynamics, the physics engine used by MSPhysics, has become much more stable and robust with joints than before. We will no longer experience the weird behavior of those flexible and wandering joints and have much better experience with developing robotics. I am driven to develop the new version. Thanks for your interest in the project!
                    • F
                      faust07
                      Thanks for the information on the further development of MSPhysics. That sounds great. Will the old models be compatible with the new version?
                        Anton_S
                        Unfortunately MSPhysics 2 won't be compatible with current models. This time, any object intended for simulation will have to be marked explicitly, rather than excluding unwanted with the Ignore option. Scripting docs is going to be different as well. My intention is to focus on usability and tutorials with this one.
                        • H
                          Hza
                          Hello Anton, thanks for the great extension! Please, when we can expect release of the MSPhysics 2?
                          thanks again!
                          Hza
                            Anton_S
                            thanks again!
                            Hza
                            The first beta version should be ready in a few months.
                              jumpjack
                              Does it exist a library of mechanisms for MSP? I can find only a dozen models on warehouse.
                              • K
                                kaoru_komine
                                I am commenting for the first time.
                                Thanks to the author for the great plugin.
                                I'm looking forward to the new version of "MSPhysics".
                                Now, I have a question about "MSPhysics2".
                                I use Ruby scripts that can be input from the UI to control the 3D model in the current "MSPhysics".Is it possible to do the same thing with "MSPhysics2"?
                                  Anton_S
                                  Yes, scripting will still be available with MSPhysics2. The scripting API will be different, however.
                                    Anton_S
                                    As mentioned earlier, MSPhysics 1 has weak joints, in which case creating mechanical interconnections between rods, suspension, robotic arms, and what not, makes the resulting structure weak and loose, unless all interconnected groups have an identical mass. MSPhysics 2 should be able to address this issue. I haven't yet tested that, and I am a little behind with my promises on the development of the project, but as mentioned earlier, I am very exited to utilize the newer NewtonDynamics version for this, which showed promising results with the stable and robust interlinked joint behavior.
                                    • T
                                      tayyab2224
                                      I hope we will enjoy MSP2 this summer۔۔۔
                                      M. Tayyab
                                        daniabreu1
                                        Looking forward to see the new version of this plugin that it will work on new versions of SU. Keep updating us! Thank you! 😄
                                        • T
                                          tayyab2224
                                          What if flying simulation in msp2 ?
                                          M. Tayyab
                                            Anton_S
                                            You mean aerodynamics? I am planning to implement Newtonian drag (already developed in ClothWorks for simulating flags and parachute effects). Newtonian drag alone does not provide accurate results, as it does not involve turbulence and additional actors, but should yield useful results for simulating wings.
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 43 / 47
