    [Preview] Wrap-R Video #3
    extensions
    42 Posts 12 Posters 8.6k Views 12 Watching
    • cmeedC
      cmeed
      As we wait for this amazing extension with bated breath, can I ask a question.
      What opportunities does it open for those waiting? What workflows are now available
      I'm interested to know what people will use this for. For me I hope to get sketchup and unreal working together (fully as only simple rectangular geometry works at the moment)
      Texture unwrapping will be a new discipline for me I know very little about how it fits in to workflows - mine is - sketchup to thea then presentation.
      I'm very interested in unreal4 maybe just for fun but a goal would be to present moving visuals.
      • Bob JamesB
        Bob James
        I hope to use it to unwrap models to use in Substance Painter.
        • FrederikF
          Frederik
          +1
          Cheers
          Kim Frederik
            I intend to use it for Minecraft.
            • cmeedC
              cmeed
              So Substance painter then .... Thea or render package?
              Basic question - as I use 'thea for sketchup' will wrap-r after its unwrapped a model then it's sent back to sketchup for 'thea for sketchup' to render - will sketchup hold this wrapped/unwrapped information?
              So this unwrapping is one step further to texturing a model or asset that fredo paint for example, can do?
                rv1974
                Rich, I'm curious how your tool would treat the attached most primitive ramp. The goal is to place dark strips parallel to expanding side borders seamlessly. Could you post the video?
                Another example:
                http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=44552%26amp;start=150
                post #5 from below. Could Pap-R apply an un-distorted texture on every turn of the attached cornice?
                Untitled.rar
                • FrederikF
                  Frederik
                  Any render application will benefit from it...
                  Of course...
                  It's a question about the UV- and UVW-mapping...
                  Cheers
                  Kim Frederik
                    Is this what you are looking to do?
                    • olisheaO
                      olishea
                      this is unbelievable for SU
                      oli
                        @oli
                        it could be a hoax though....
                        • tuna1957T
                          tuna1957
                          Fantastic........ no mac version , I'll go sit in the corner and pout now.......
                          • olisheaO
                            olishea
                            @rich o brien said:
                            @oli
                            It's not April 1st though mate!
                            I used to think that all the time so I just bought a PC instead. Much easier! πŸ˜„
                            oli
                              rv1974
                              Thank you! Yes, the result you delivered is what I expected to get.
                              A couple of notes:
                              1. There's strong ripple distortion of the checker texture. It will seen if finer textures (like decking or tiles) will be applied. Ho to fight this issue?
                                2.We saw lots of tedious manual labor. Do you have any plans to automate somehow the aligning part?
                                There's by no means any bit of criticism- I only try to clarify the things.
                              • JQLJ
                                JQL
                                I see a lot more manual work on my current process right now
                                www.casca.pt
                                Visit us on facebook!
                                  Ripples are because the texture in the viewport is not a bitmap. here's the result for you to look at...
                                  road-wrapr-rv.skp
                                  Of course. First we need to nail down to workflow then add the features.
                                    rv1974
                                    I'd disagree. I replaced the asphalt texture with decking and this here's result. It's important in Archviz and it should be addressed.
                                      That's interesting.
                                      I'll look at this.
                                      One thing worth noting is we're only process Tri meshes. Distortions like this are artefacts of such meshes.
                                      But not the outcome we want. Thanks for the heads up.
                                      • Bob JamesB
                                        Bob James
                                        Fredo's extension is a great tool, but the Substance programs (Designer, Painter and BTM) along with SubstanceTheaConverter gives you much more power to add things like worn edges and other "realistic defects".
                                        However, to do that you need an unwrapped version of your model. That's why Wrap-R is so critically important.
                                          @rv1974 said:
                                          I replaced the asphalt texture with decking...
                                          What replacement method did you use? I'm not getting the same result.
                                          • cmeedC
                                            cmeed
                                            Riiiiight got it! The ramp clip is a good example - revelation time.
                                            • 2 / 3
