    [Plugin] GreyscaleMode
    133 Posts 56 Posters 172.8k Views 56 Watching
    • N
      nujak
      LOVE IT!!! Saves me soo much headache!
      • kuponoK
        kupono
        Excited to find this on Smustard, but it's not working for me on SU Pro 2016. It errors on loading. Me or has it not been updated?
          It works fine for me in SU2016. Perhaps you didn't install it correctly? What's the error message?
          Click on the picture
          • B
            Bruce Watt
            Hi All,
            I would like to try this plugin.
            I can not find a paid version of this plugin. any pointers please. Happy to pay for it.
            I have downloaded a free version off Smustard. I am working in SK UP 2016
            Where do I put the file contained within the Zip file. I have a jf_tools folder, jf_tools.rb, and greyscales.rbs files.
            I have tried.
            C:\ProgramData\SketchUp\SketchUp 2016\SketchUp\Plugins
            and
            C:\Users\Bruce\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins
            but get errors on loading Sketchup;
            Error: #<NameError: uninitialized constant JF>
            c:/users/bruce/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/greyscale.rbs:22:in <main>' SketchUp:1:in eval'
            There is not any .rbz file to install under the normal way through sketchup- windows menu- preferences etc etc
            Any help would be appreciated.
            SKUP PRO 2021 latest version / update
            Windows 10 Pro
            Dell Alienware Aurora R10 AMD
            AMD Ryzen™ 9 3900X
            NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
              Bruce, first, go to the Plugins folder and remove any files you've installed that are related to this plugin. Then find the ZIP file you downloaded and change the extension from .zip to.rbz. Next, in SketchUp, go to Window>Preferences>Extensions. Click on Install Extension... Navigate to the rbz file, select it, choose Open and all affirmative responses. Click OK to close Preferences and then look in the Extensions menu. It should be there. If not, quit SketchUp and restart.
                FWIW, I just installed on SU2016 on my work computer and it works fine here, too.
                • kuponoK
                  kupono
                  Same error as Bruce. I did as suggested for Bruce: removed files in the plugin folder, then renamed zip to rbz, installed, exited, restarted,and got the same error. I see grayscale in the Plugins Manager, but not a sign of it in Tools, Extensions, or context menu.
                    Check your PMs.
                    • kuponoK
                      kupono
                      Jim, This is a fantastic! Thanks.
                      Dave, Thanks for the help.
                        darospa
                        what is a PMs? thank you in advance
                          PMs = Private Messages
                          • B
                            Bruce Watt
                            I have done as Dave has kindle suggested but I get the same error as Kupono.
                            Looked at PM nothing there, although the inbox states (Inbox(1)) but nothing shows.
                            PM box shows one message...but no message
                            Windows 10 Pro
                            AMD Ryzen™ 9 3900X
                            • B
                              Bruce Watt
                              Thanks Dave and Jim
                              Windows 10 Pro
                              AMD Ryzen™ 9 3900X
                              • L
                                lesourdsville
                                I'm also getting that same error. Any advice?
                                • T
                                  tex77903
                                  Same error for me as well. Any advice would be greatly appreciated.
                                    Check your PMs.
                                    • T
                                      tex77903
                                      Thanks Dave!!
                                        RandyInLA
                                        Running SU Make 2016 on OSX El Capitan.
                                        I too have downloaded the zip, renamed the extension to .rbz, successfully imported via the Extenstions section of Preferences but it throws that "Error: #<NameError: uninitialized constant JF>" error. Not sure why the solution isn't posted, but I'd like to request a PM as well, Dave. 😄
                                        -=Randy
                                        • GMthompsonG
                                          GMthompson
                                          @utiler said:
                                          First of all I'll echo Dave_R's comments. Jim, you are a generous fella...
                                          For those of you who didn't see how this evolved, see http://www.sketchucation.com/forums/scf/viewtopic.php?f=40%26amp;t=12226%26amp;p=88778#p88778
                                          Sometime, a schematic presentations seem to be best a little less 'in your face' in grey scale...
                                          I tried it out on a little modular house I designed...
                                          The only problem with it is that it doesn't act like 'face styles' in that changing from one scene to another it doesn't save with styles....
                                          Not complaining though!!! :sketchstatic: Would love to see it included in SU7.0 face styles...
                                          i 100% agree at times less is better i set up scenes/models very similar at times for LO
                                          you can learn something everyday by paying attention
                                          • Bob JamesB
                                            Bob James
                                            @dave r said:
                                            Sepo, after making the model all grey, right click on a face containing the color you wish to show. Choose Revert color from the menu. 😉
                                            This extension, now called Grey Scale, is available at the Extension Store. Is there another, more capable, paid version somewhere?
                                            In my case, I have a modification to a large building, but some of the colors in the modification are also used in the original building and some of the surrounding equipment.
                                            The big problem with this extension is that if the color you are reverting is anywhere else in the part you want to stay grey, it will also revert, ruining the effect of having the part stand out.
                                            Is it possible to have the reversion limited to a selected group without affecting any of the other groups in the model?
                                            Or, maybe it could be limited to affecting only one layer.
                                            Another difficulty I'm having is that I can find no way to revert the entire model.
                                            In addition to the GreyScale Mode there is another option called "Front Face Mode". I couldn't figure out what that does. 😞
                                            • 6 / 7
