    KT fast start returns
    44 Posts 10 Posters 13.9k Views 10 Watching
    • majidM Offline
      majid
      Maters.now the e-book is on the SCF shop for sale:
      http://sketchucation.com/shop/books/1688-kt-fast-start-2nd-edition
      Material packs are still free for members.
      I've refined it before the publish to the optimum information and later will add some more free tips and tricks to it or will share here.
      • majidM Offline
        majid
        ies lights are also supported with KT and I am preparing a tutorial on how to make and adjust them. here is a simple test scene.
        a bit adjustment is applied
        • Bryan KB Offline
          ebook? Which reader for the PC do you recommend?
          • majidM Offline
            majid
            any pdf reader, paid or free... πŸ˜„
            • Bryan KB Offline
              • majidM Offline
                majid
                An old project I was always wishing to render it. I hope find some more free times to re-render it soon.
                • majidM Offline
                  majid
                  There were an old component collection of KT lights that I've updated them, remodeled some of them and also add few other lights to them. One may tweak them and use them also for other purposes or other render engines as a light place holder.
                  Now most of the lights are including some more extra details and necessary edges are beveled. Hope you enjoy them.
                  KT Lights.zip
                  • H Offline
                    hvanessen
                    Thanks a lot
                    • majidM Offline
                      majid
                      Thanks for downloading , here is a snapshot of some of the including models:
                      • majidM Offline
                        majid
                        The ice season is going but I've prepared an ice material pack using procedural maps. here you are: enjoy rendering.
                        Ice pack.mat.zip
                        • jo-keJ Offline
                          jo-ke
                          Thank you. This is very usefull. Always appreciate good materials
                          http://www.zz7.de
                          • majidM Offline
                            majid
                            I thought a preview render may helps.
                            • pbacotP Offline
                              Those are fine materials. I would not go so far as to need that, but the realism is admirable. Good of you to share.
                              • tuna1957T Offline
                                tuna1957
                                Thank you thank you thank.... spent a couple of nights trying to come up with a good looking ice cube. Your's are much much better.
                                • majidM Offline
                                  majid
                                  If you are going to use them with KT , you need to tweak the kerkythea.ini to add extra plugins and procedural maps to the KT . Let me add extra information later.
                                  They work fine also with Twilight render kz Twilight already includes the needed plugins...
                                  Edit: I've used the M-Cell plugin. One may find and install them here:
                                  http://www.kerkythea.net/forum/viewtopic.php?f=24%26amp;t=4280
                                  The zipped files includes the "kerkythea.ini" file that must be replace with the original one and also a pdf file that has extra details...
                                  • Bryan KB Offline
                                    Well I finally got around to buying the book and also downloaded the additions.
                                    I'm looking forward to learning new techniques and using Kerkythea better than I have before. I've already taken a quick look at the PDF and it looks very comprehensive.
                                    Thank you.
                                      Thanks Majiid, you are a proper Gent.
                                      • majidM Offline
                                        majid
                                        thanks a heap Mike! I hope KT re wakes again, as users only has the power to give it a second life and only few improvements makes KT a modern render engine again. a better physical sky type a warmer sun... It was a vanguard render engine at its time and even now it is better than lots of available commercial ones.
                                          ASistGar
                                          Thanks a lot!!
                                          • majidM Offline
                                            majid
                                            This is great that some still find it useful!
                                            • 2 / 3
