    KT fast start returns
    44 Posts 10 Posters 15.6k Views 10 Watching
    • majidM
      majid
      ies lights are also supported with KT and I am preparing a tutorial on how to make and adjust them. here is a simple test scene.
      a bit adjustment is applied
      • Bryan KB
        ebook? Which reader for the PC do you recommend?
        • majidM
          majid
          any pdf reader, paid or free... πŸ˜„
          • Bryan KB
            • majidM
              majid
              An old project I was always wishing to render it. I hope find some more free times to re-render it soon.
              • majidM
                majid
                There were an old component collection of KT lights that I've updated them, remodeled some of them and also add few other lights to them. One may tweak them and use them also for other purposes or other render engines as a light place holder.
                Now most of the lights are including some more extra details and necessary edges are beveled. Hope you enjoy them.
                KT Lights.zip
                • H
                  hvanessen
                  Thanks a lot
                  • majidM
                    majid
                    Thanks for downloading , here is a snapshot of some of the including models:
                    • majidM
                      majid
                      The ice season is going but I've prepared an ice material pack using procedural maps. here you are: enjoy rendering.
                      Ice pack.mat.zip
                      • jo-keJ
                        jo-ke
                        Thank you. This is very usefull. Always appreciate good materials
                        http://www.zz7.de
                        • majidM
                          majid
                          I thought a preview render may helps.
                          • pbacotP
                            Those are fine materials. I would not go so far as to need that, but the realism is admirable. Good of you to share.
                            • tuna1957T
                              tuna1957
                              Thank you thank you thank.... spent a couple of nights trying to come up with a good looking ice cube. Your's are much much better.
                              • majidM
                                majid
                                If you are going to use them with KT , you need to tweak the kerkythea.ini to add extra plugins and procedural maps to the KT . Let me add extra information later.
                                They work fine also with Twilight render kz Twilight already includes the needed plugins...
                                Edit: I've used the M-Cell plugin. One may find and install them here:
                                http://www.kerkythea.net/forum/viewtopic.php?f=24%26amp;t=4280
                                The zipped files includes the "kerkythea.ini" file that must be replace with the original one and also a pdf file that has extra details...
                                • Bryan KB
                                  Well I finally got around to buying the book and also downloaded the additions.
                                  I'm looking forward to learning new techniques and using Kerkythea better than I have before. I've already taken a quick look at the PDF and it looks very comprehensive.
                                  Thank you.
                                    Thanks Majiid, you are a proper Gent.
                                    • majidM
                                      majid
                                      thanks a heap Mike! I hope KT re wakes again, as users only has the power to give it a second life and only few improvements makes KT a modern render engine again. a better physical sky type a warmer sun... It was a vanguard render engine at its time and even now it is better than lots of available commercial ones.
                                        ASistGar
                                        Thanks a lot!!
                                        • majidM
                                          majid
                                          This is great that some still find it useful!
                                          • 2 / 3
