    KT fast start returns
    44 Posts 10 Posters 15.4k Views 10 Watching
    • majidM Offline
      majid
      The ice season is going but I've prepared an ice material pack using procedural maps. here you are: enjoy rendering.
      Ice pack.mat.zip
      • jo-keJ Offline
        jo-ke
        Thank you. This is very usefull. Always appreciate good materials
        http://www.zz7.de
        • majidM Offline
          majid
          I thought a preview render may helps.
          • pbacotP Offline
            Those are fine materials. I would not go so far as to need that, but the realism is admirable. Good of you to share.
            • tuna1957T Offline
              tuna1957
              Thank you thank you thank.... spent a couple of nights trying to come up with a good looking ice cube. Your's are much much better.
              • majidM Offline
                majid
                If you are going to use them with KT , you need to tweak the kerkythea.ini to add extra plugins and procedural maps to the KT . Let me add extra information later.
                They work fine also with Twilight render kz Twilight already includes the needed plugins...
                Edit: I've used the M-Cell plugin. One may find and install them here:
                http://www.kerkythea.net/forum/viewtopic.php?f=24%26amp;t=4280
                The zipped files includes the "kerkythea.ini" file that must be replace with the original one and also a pdf file that has extra details...
                • Bryan KB Offline
                  Well I finally got around to buying the book and also downloaded the additions.
                  I'm looking forward to learning new techniques and using Kerkythea better than I have before. I've already taken a quick look at the PDF and it looks very comprehensive.
                  Thank you.
                    Thanks Majiid, you are a proper Gent.
                    • majidM Offline
                      majid
                      thanks a heap Mike! I hope KT re wakes again, as users only has the power to give it a second life and only few improvements makes KT a modern render engine again. a better physical sky type a warmer sun... It was a vanguard render engine at its time and even now it is better than lots of available commercial ones.
                        ASistGar
                        Thanks a lot!!
                        • majidM Offline
                          majid
                          This is great that some still find it useful!
                          • 3 / 3
