    KT fast start returns
    44 Posts 10 Posters 15.9k Views 10 Watching
    • majidM
      majid
      Thanks for downloading , here is a snapshot of some of the including models:
      • majidM
        majid
        The ice season is going but I've prepared an ice material pack using procedural maps. here you are: enjoy rendering.
        Ice pack.mat.zip
        • jo-keJ
          jo-ke
          Thank you. This is very usefull. Always appreciate good materials
          http://www.zz7.de
          • majidM
            majid
            I thought a preview render may helps.
            • pbacotP
              Those are fine materials. I would not go so far as to need that, but the realism is admirable. Good of you to share.
              • tuna1957T
                tuna1957
                Thank you thank you thank.... spent a couple of nights trying to come up with a good looking ice cube. Your's are much much better.
                • majidM
                  majid
                  If you are going to use them with KT , you need to tweak the kerkythea.ini to add extra plugins and procedural maps to the KT . Let me add extra information later.
                  They work fine also with Twilight render kz Twilight already includes the needed plugins...
                  Edit: I've used the M-Cell plugin. One may find and install them here:
                  http://www.kerkythea.net/forum/viewtopic.php?f=24%26amp;t=4280
                  The zipped files includes the "kerkythea.ini" file that must be replace with the original one and also a pdf file that has extra details...
                  • Bryan KB
                    Well I finally got around to buying the book and also downloaded the additions.
                    I'm looking forward to learning new techniques and using Kerkythea better than I have before. I've already taken a quick look at the PDF and it looks very comprehensive.
                    Thank you.
                      Thanks Majiid, you are a proper Gent.
                      • majidM
                        majid
                        thanks a heap Mike! I hope KT re wakes again, as users only has the power to give it a second life and only few improvements makes KT a modern render engine again. a better physical sky type a warmer sun... It was a vanguard render engine at its time and even now it is better than lots of available commercial ones.
                          ASistGar
                          Thanks a lot!!
                          • majidM
                            majid
                            This is great that some still find it useful!
                            • 3 / 3
