    [Plugin] SectionCutFace
    569 Posts 171 Posters 505.6k Views 170 Watching
    • wiskillW Offline
      wiskill
      Thanks for the update! Everything seems to work fine now. Any info on what was causing the faces to not update properly? I love the new visibility options btw.
        Charlie__V
        %(#FF0000)[Tig,
        Update:
        It appears removing Pipe Along Path V 2.2 20141112 stops the BugSplat on launch described below
        @tig said:
        What is your SUp version ?
        SU Pro 2016
        @tig said:
        No error messages [e.g. in Ruby Console] ?
        At what point does it splat ?
        On opening the tool or on OK ?
        Does it spat on all permutations of the options ??
        Did not have opportunity to see console, or (new SCF V6.1)options
        Splat was/is immediate on launch of SU.
        @tig said:
        How did you install the plugin ?
        From its RBZ ?
        Initially I downloaded .rbz to desktop and through SU.....window....preferences....extensions....install(ed) extension.......rbz
        Note:I did not uninstall SCF V4.4 prior either. (figured it would just overwrite)
        SU did not Bugsplat at this point, however, the options available were the same as in SCF V4.4 and for this reason I closed and re-launched SU.....and immediate Splat.
        I Then tried manual install by renaming the .rbz to .zip and deleted SCF folder and SCF ruby file from the 2016 plugins folder, and dragged the contents of the .zip to 2016 plugins folder........launch produced same splat.
        @tig said:
        Can you delete all "SectionCutFace" files and its subfolder in the Plugins folder [manually] and then reinstall and restart and see what happens...
        I did exactly that after second splat, and splat on launch again.
        @tig said:
        I assume an earlier version of the plugin work OK...
        Yes, manual reinstall of SCF V4.4 works fine as before.
        @tig said:
        Do you have many other plugins installed ?
        Maybe five or six, not on that machine right this moment.....will have to report back.
        I can try to reproduce later today if you think it will be helpful, and I do recall seeing some text in the bugsplat window that may be helpful for you to see?
        Thank You!!
        Charlie
          There should be not connection with PipeAlongPath and SectionCutFace - except that I wrote both!
          Have you tried re-installing the newest version of PAP [v2.2]
          I'll do some more digging though...
            Charlie__V
            @tig said:
            There should be not connection with PipeAlongPath and SectionCutFace - except that I wrote both!...
            I did see that.....and I am very appreciative for you having written them....especially since I use very few and found yours to be very helpful to me.(think you wrote 3 out of the six I use) 😄
            @tig said:
            Have you tried re-installing the newest version of PAP [v2.2]...
            I have, and unfortunately the same Bugsplat returns.
            Please don't spend much time on it for me, I can continue using SCF V4.4 should I need PAP as well.
            Thank you,
            Charlie
            (screenshot)Bugsplat report if helpful?
              Jack Lowcock
              Plugin looks great but once I have created the section cut face I can't Dimension or measure even in layout measurements won't snap to points is there a fix for this
                Section cut lines are not edges that dimension tools in SketchUp or LayOut can snap to. You could make the edges of the section cut face visible in the UI and dimension to the edges of the face.
                • wiskillW Offline
                  wiskill
                  Edge detection in sketchup and layout works for me if I enable visible edges. But I'll have to hide the section cuts via layers instead.
                    rui pedro
                    i dont understand this plugin, i was expected to close the solid and get as the final result the solid cuted. for example, i made a 3d model of a house, then i cut and use the sectioncutface and then i would like to render that solid cut but i cant...
                    sorry for me english 😄
                    • JQLJ Offline
                      JQL
                      Olá Rui!
                      You can render the solid cut if you use a supported renderer that works with sketchup sections.
                      I work with Thea that can do it.
                      www.casca.pt
                      Visit us on facebook!
                        A few renders will keep section-plane cuts visible in their output.
                        The ones I know of are Thea and Twilight.
                        SU Podium has an add-on tool which does something similar, but by making a copy of the model and and then using two operations, much like SectionCutFace AND Zorro2, to add the face, and then cut and delete the rest of the model, you can then render that.
                        You can mimic that - make a copy of your model - use SectionCutFace to add the face, then use Zorro2 to cut the model at the same section-plane, render that...
                        Remember to work on a copy, because it does cut up and delete chunks of your model !
                        • cottyC Offline
                          cotty
                          (Full version) of Indigo too.
                          my SketchUp gallery
                          • Q Offline
                            Q2002
                            The best section plugin I have ever found! Thx TIG.
                              Progressing_Slowly
                              Hi TIG,
                              I am too new to have PM privileges yet, is it still possible to get the ruby script files for SectionCutFace, I am still using SketchUp Pro version 8.
                              Progressing_Slowly.
                                Progressing_Slowly
                                Hi, I cannot PM yet as I am a new member, but I wanted to get the additional files needed to run this in Pro Version 8.
                                I have downloaded Sketchup Make to test, and it works great, just want to keep with my version of Pro 8 for now as everything runs so smoothly on it.
                                  @Progressing_Slowly
                                  SectionCutFace should work on all currently available versions of SketchUp.
                                  Obviously the newer versions are recommended, and be aware that v8 is no longer supported by Trimble, and v2013 will go that way shortly - they already have limited access to 3dWH and EWH pages...
                                  It is available in the SketchUcation PluginStore - download its RBZ and install using SketchUp's Preferences > Extensions > Install Extension... button, alternatively install the SketchUcation ExtensionStore³ and that allows you to install anything available in the PluginStore automatically from within SketchUp.
                                    Jotix
                                    Hi TIG!
                                    I've installed sectioncutface on my SUP 2016, but then appeared this error:
                                    Error Loading File C:/Users/(...)/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/SectionCutFace/SectionCutFace_start.rbs
                                    Failed to read RBE/RBS file.
                                    Do you have a clue about solving this problem?
                                    Thanks!!!
                                      Does that RBS file actually exist?
                                      How did you install it from the downloaded RBZ ?
                                      Use SketchUp's Window > Preferences > Extensions > Install Extension... button.
                                      Or AutoInstall it from within SketchUp itself, using the SketchUcation ExtensionStore³ toolset...
                                        Charlie__V
                                        Thank you,
                                        Charlie
                                        Update:
                                        Tig......as always.....many thanks for all you do for us all!!!
                                        I just wanted to share that I updated/installed SU Pro 64 bit 16.1.1449 today and reinstalled Pipe Along Path (PAP) with your most recent Section Cut Face (SCF)an all is well now.
                                        No more bugsplat!
                                        Best regards,
                                        Charlie
                                        • E Offline
                                          Eco15
                                          Hello,
                                          i dont know if it came up along the 15 pages of feedback, but i downloaded the plugin, and seems to be installed OK. when adding a section from sketchup and right-clicking it the add section cut face appears and doing its job BUT the CUT MODEL AT SECTION command doesnt apear afterwords. i try using Versions 2014 / 2016 / 2013.
                                          i read on the download page that it's possible to have problems with V.2014 and that i should contact Via PM (which i can not do yet - hence, writing here). i have a presentation due to the end of the week and will appreciate all help.
                                          NOTE: i tried using the plug-in in a simple model just to make sure that the amount of Info is not the problem.
                                          Thanks.
                                            It it possible you are looking for "Slice model at section" which comes from Zorro2?
                                            It works fine for me after running SectionCutFace.
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 28
                                            • 29
                                            • 22 / 29
