    [Plugin] SectionCutFace
    569 Posts 171 Posters 541.3k Views 170 Watching
    • bmikeB
      bmike
      @bmike said:
      Hi Tig -
      I'm having an issue with 5.1:
      When I 'Remake Section Cut Face' it doesn't fill the section and it creates a new object on Layer 0, despite having selected the option to name it after the layer when I first created the cut.
      I'm going to try and delete all related files from my PlugIn folder and re-install from a download.
      No luck, deleted manually and re-installed from the SKF store, same problem persists.
      -Mike
      • JQLJ
        JQL
        That usually happens if you made the original section on Layer0.
        Instead of Remaking the section try Making a new section. From then on you can Remake it and it will keep those values.
        www.casca.pt
        Visit us on facebook!
        • bmikeB
          bmike
          I didn't make the original section on Layer 0....
            Either set the Section-Plane to have the desired layer and set the SectionCutFace's layer to be '<Section's Layer>' so they always match - or pick '<Customized>' and in the dialog type in the existing layer-name e.g. S-81 - which is then frozen.
            Then when you remake it, then it always uses that customized-name.
            Picking from the list of 'all' layers is only really useful for the 'No' - Non-update-able - SectionCutFaces - which are of course frozen and not re-makeable.
            But having the list available for all SectionCutFaces types, at least lets you see what layers names already exist, to then use in '<Customize>'...
            For the two types of remake/update-able SectionCutFaces... the 'frozen' layer-name choices are:
            '<Section's Layer>' - where the Section-Plane's layer-name is used across remakes; and only changes if you have reassigned the Section-Plane's layer, in which case when you remake it, its layer is changed to match... So a simple fix is to reassign the Section-Plane to say S-81 and then when remade the SectionCutFace will also have that layer.
            'SCUT...' - where that specific initially assigned layer-name is retained across all remakes.
            '<Customized>' - where that initially chosen layer-name is retained across remakes.
            If you simply recreate either of the two update-able SectionCutFace types, by using 'Add...' it will replace the previous one, using whatever options you choose - a remake-able SectionCutFace is only one per Section-Plane - unlike a 'No' update type which can have several SectionCutFaces associated with it.
            • bmikeB
              bmike
              Thanks Tig. Will test tomorrow.
              • wiskillW
                wiskill
                I can't get the section cut faces to update on demand nor auto update. Not sure what I'm doing wrong.
                Here's a video to show the problem.
                Whenever I try to update the section cut (or have it auto-updated) it results in a blank cut lines with no faces that doesn't get put in its layers properly.
                edit: After multiple retries, with any/either options enabled/disabled or named unnamed sections and everything. I can't get the section face to auto update or update on demand no matter what I do.
                Here's a video: https://youtu.be/wYZZQCZ1zTc
                From a cleanly new file, I make a simple cube, try to make a section face with only 1 option changed, copy the cube over, remake the face and it won't update properly. All it does is create a new group in layer 0 with just the outline of the cuts. It won't update the layer, it won't make a face, and when I choose remake face again, it just keeps making a new group with the outline again.
                Right now when I want to remake a section face, I will always have to delete the old face, THEN make a new one.
                I've tried uninstalling sketchup 2014 and 2015, and using leaving only 2016 on my pc. I've tried deleting the plugin folder and reinstalling, and the problem still persists.
                I'm totally stumped. Any help appreciated.
                  davidheritier
                  Really really good job!!! THx!!!!
                    @wiskill
                    Obviously you are "doing something wrong".
                    Many others with the same OS and SUp version have no issues.
                    Different versions of SketchUp NEVER interact, so you don't need to worry about other versions.
                    Your video is puzzling, since I do the exact same steps, with the exact same set up, AND it refreshes the SectionCutFace as I might hope...
                    Can you open the Ruby Console before doing anything and see if there any error messages...
                    Can you also provide a list of all other extensions you have loading...
                    There might be a [very rare] clash...
                    ๐Ÿ˜ฒ
                    • wiskillW
                      wiskill
                      Here's the error message in from the ruby console.
                      Error; #<TypeError; no implicit conversion of Sketchup;;Layer into String>
                      c;/users/wisarut/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/sectioncutface/sectioncutface_code.rbs;121;in `name='
                      c;/users/wisarut/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/sectioncutface/sectioncutface_code.rbs;121;in `new'
                      c;/users/wisarut/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/sectioncutface/sectioncutface_start.rbs;63;in `block (2 levels) in <module;SectionCutFace>'
                      SketchUp;1;in `call'
                      Here's a video showing the error: https://youtu.be/mro1VSwkTBw
                      I think I don't have any other extensions installed. I used to have LibFredo6 and FredoScale and JointPushPull installed for Sketchup 2015, but when I moved on to Sketchup 2016, I didn't reinstall it as I wasn't using it that much.
                      Just a short note, I have 2 pcs, (1 desktop and 1 ultrabook) and the problem persists on BOTH machines.
                        @wiskill
                        Thanks for the message and video.
                        I have managed to replicate your issue.
                        I am working on a solution...
                        ๐Ÿ˜ฒ
                          Here's v6.0 http://sketchucation.com/pluginstore?pln=SectionCutFace it has the following changes:
                          Glitch/typo fixed with the 'remade' SectionCutFaces - layer error etc as recently reported.
                          The SectionCutFaces now have modified bounding-boxes, made tight to the face, and their axes are also reset so that their blue axis is perpendicular to the face, with the red axis 'horizontal', and the 'origin' set to a logical lower corner.
                          An additional option has been added to the dialog and constants file.
                          'Scene Visibility' - seen the main Documentation for more details...
                          NOTE: because of the draconian signing regime introduced in v2016, which effectively requires all subfolder Ruby files to be encrypted... some users with SketchUp versions < v2014 have had problems loading newer versions of this extension [and some others...
                          If that is your case please PM to TIG, who can PM back some fixed RB files for the ../Plugins/SectionCutFace subfolder which will allow ye olde versions of SketchUp to continue working even then...
                          If you have >= v2014 it should work with no problems !]
                          • JQLJ
                            JQL
                            ๐Ÿ˜ฎ Wow Tig! 2D sketchup! Thank you so much!
                            www.casca.pt
                            • C
                              Charlie__V
                              TIG,
                              First......I am very grateful for all of the plug ins you create and maintain for the community!
                              I do not use many plug ins myself.......but one I have used for many years now is the section cut face.
                              I see you have made some nice changes to this so I downloaded and installed V6.0 today.
                              Surprisingly I immediately got a bug splat after install, and sent the report in.
                              MS Win7Pro
                              64-bit OS
                              Intel i3-2100CPU 3.1GHz
                              8.0 GB ram
                              I have since reinstalled V4.4
                              Just thought you should know.....not sure what the cause could be.
                              Thank lots,
                              Charlie
                                What is your SUp version ?
                                No error messages [e.g. in Ruby Console] ?
                                At what point does it splat ?
                                On opening the tool or on OK ?
                                Does it spat on all permutations of the options ??
                                How did you install the plugin ?
                                From its RBZ ?
                                Can you delete all "SectionCutFace" files and its subfolder in the Plugins folder [manually] and then reinstall and restart and see what happens...
                                I assume an earlier version of the plugin work OK...
                                Do you have many other plugins installed ?
                                • wiskillW
                                  wiskill
                                  Thanks for the update! Everything seems to work fine now. Any info on what was causing the faces to not update properly? I love the new visibility options btw.
                                  • C
                                    Charlie__V
                                    %(#FF0000)[Tig,
                                    Update:
                                    It appears removing Pipe Along Path V 2.2 20141112 stops the BugSplat on launch described below
                                    SU Pro 2016
                                    Did not have opportunity to see console, or (new SCF V6.1)options
                                    Splat was/is immediate on launch of SU.
                                    From its RBZ ?
                                    Initially I downloaded .rbz to desktop and through SU.....window....preferences....extensions....install(ed) extension.......rbz
                                    Note:I did not uninstall SCF V4.4 prior either. (figured it would just overwrite)
                                    SU did not Bugsplat at this point, however, the options available were the same as in SCF V4.4 and for this reason I closed and re-launched SU.....and immediate Splat.
                                    I Then tried manual install by renaming the .rbz to .zip and deleted SCF folder and SCF ruby file from the 2016 plugins folder, and dragged the contents of the .zip to 2016 plugins folder........launch produced same splat.
                                    I did exactly that after second splat, and splat on launch again.
                                    Yes, manual reinstall of SCF V4.4 works fine as before.
                                    Maybe five or six, not on that machine right this moment.....will have to report back.
                                    I can try to reproduce later today if you think it will be helpful, and I do recall seeing some text in the bugsplat window that may be helpful for you to see?
                                    Thank You!!
                                    Charlie
                                      There should be not connection with PipeAlongPath and SectionCutFace - except that I wrote both!
                                      Have you tried re-installing the newest version of PAP [v2.2]
                                      I'll do some more digging though...
                                      • C
                                        Charlie__V
                                        @tig said:
                                        There should be not connection with PipeAlongPath and SectionCutFace - except that I wrote both!...
                                        I did see that.....and I am very appreciative for you having written them....especially since I use very few and found yours to be very helpful to me.(think you wrote 3 out of the six I use) ๐Ÿ˜„
                                        @tig said:
                                        Have you tried re-installing the newest version of PAP [v2.2]...
                                        I have, and unfortunately the same Bugsplat returns.
                                        Please don't spend much time on it for me, I can continue using SCF V4.4 should I need PAP as well.
                                        Thank you,
                                        Charlie
                                        (screenshot)Bugsplat report if helpful?
                                          Jack Lowcock
                                          Plugin looks great but once I have created the section cut face I can't Dimension or measure even in layout measurements won't snap to points is there a fix for this
                                            Section cut lines are not edges that dimension tools in SketchUp or LayOut can snap to. You could make the edges of the section cut face visible in the UI and dimension to the edges of the face.
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 28
                                            • 29
                                            • 22 / 29
