    Twilight Render - Challenge
    extensions
    76 Posts 11 Posters 16.5k Views 11 Watching
    • H Offline
      hvanessen
      and the one on a wooden floor
      wood floor
      • ntxdaveN Offline
        ntxdave
        I tried a of floor too but did not get it to work right either. Would you mind sharing you background info and the various settings?
        Press F1...thank me later
        • ntxdaveN Offline
          ntxdave
          Well - I finally made some progress.
          Here is latest effort:
          Silly Glass Sample
          Now off to go back to the original challenge and draw the glass (and maybe a bottle) with liquid content.
            at bigmanwashes they certainly have some big ass glasses!
            • ntxdaveN Offline
              ntxdave
              Not big glasses, just small blowers ❗
                JGA
                Is your background just an HDR image, rather than a physical plane?
                Regards,
                JGA
                • ntxdaveN Offline
                  ntxdave
                  In this particular case, yes.
                  • ntxdaveN Offline
                    ntxdave
                    My latest endeavor.......
                    Still not exactly what I want but getting closer.
                      It's a funny result! β˜€
                      • ntxdaveN Offline
                        ntxdave
                        Yep, it sure is. 😲
                        • tuna1957T Offline
                          tuna1957
                          Dave C. , Stumbled across your post today. Twilight user also and you peaked my curiosity. Never have done the
                          glass of wine business so figured why not. Built and textured my glass like Massimo shows ( thanks
                          for posting that Pilou ! ) .Below I've listed how I set things up.
                          Materials , Wine Glass - Snow , TW - glass / common
                          Top of wine - Indian Red 12% opacity , TW - glass / water
                          Side of wine - Fire Brick 12% opacity , TW - glass / water
                          Backdrop - Cool Grey #4 , TW - paint / eggshell
                          TW render preset - 08 Exterior Daytime Progressive
                          TW Sun Settings - Physical Sky , Brightness - .800 , Haze - 20% , Sun Strength - 3.0
                          Gave the sun a very light yellow color. all other settings left at default levels.
                          Let the render run for 100 passes. It took about 19 minutes. Probably as good as it will get with this setup. Need to
                          try some shots in an interior studio setup. Better chance of playing with lighting and use some other objects for
                          reflections and such. Good luck and just keep working with TW you'll get better with practice. Thanks for the kick to
                          do something a little different with SU & TW than I usually do. It was a nice change of pace.
                          • H Offline
                            hvanessen
                            Very good, andere cheers πŸ’š
                            • ntxdaveN Offline
                              ntxdave
                              Well, here is my latest try............
                              The wine does not really show up in the render but otherwise, it is acceptable.
                              I have done a bunch of tries and just do not seem to get it right. I have also attached the SU file if anyone wants to take a look at tell me how to adjust it more properly.
                              WineGlass-2.skp
                              • soloS Offline
                                Dave, scale is important when trying to get accurate materials, the above is way too big, try reducing it to accurate size before rendering.
                                • ntxdaveN Offline
                                  ntxdave
                                  I scaled the glass down to the correct size and rerendered using most of tuna1957's settings (not all).
                                  Still does not match what it seems like everyone else is able to do. Either I am expecting too much or I just do not get it. I am failing miserable at this challenge.
                                  I am open to suggestions or if someone who has done this successfully would like to share your SU file (with Twilight settings) for me to study, I would really appreciate it. 😑
                                  • tuna1957T Offline
                                    tuna1957
                                    Dave, Take a deep breath and step away from the keyboard πŸ’š On a serious note try not to get to frustrated.
                                    I'm no expert at this either. I remember having days I wanted to jab pencils in my head sitting at my keyboard trying
                                    figure this stuff out. I've been messing about and tweaking settings and such. Posting another pic of a "rocks glass". Was going to tweak on your model but I'm still working in SU2015. If you'd like I'll post my rocks glass model so you can get in and check out how the materials and sun is set up.
                                    • olisheaO Offline
                                      olishea
                                      is your index of refraction too high Dave? It looks like extremely thick glass (even though we know it is not)
                                      keep going!! You'll nail it soon.
                                      oli
                                      • ntxdaveN Offline
                                        ntxdave
                                        @tuna1957 - Thanks for your reply. Yes, I would like for you to share your model. I think I am missing something very basic but I do not know what it is.
                                        @olishea - Yes, the IOR setting for the glass was too high. I set it lower but I am still doing something very basic wrong.
                                        I have another question for anyone looking at this that uses Twilight. When I use the template to set the texture of the liquid in the glass, SketchUp reverses the faces of the liquid group. Is that supposed to happen?
                                        • tuna1957T Offline
                                          tuna1957
                                          Dave, I'll post the model next day or so. Haven't had the "faces" change when working in TW. I will say SU can get a little crazy with face orientation sometimes while I'm modeling. Never an issue when setting textures in TW ?
                                          • alvisA Offline
                                            alvis
                                            You can be studied in a model
                                            ready for TWrender.zip
                                            • 1 / 4
