    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Twilight Render - Challenge
    extensions
    76 Posts 11 Posters 13.2k Views 11 Watching
    • ntxdaveN Offline
      ntxdave
      I am trying to learn how to use Twilight Hobby correctly.
      One of the problems I have had is with glass. So, I am issuing a challenge:
      • Draw a glass object (bottle, glass or both) that is partially full (see sample below)
      • Render it with Twilight render (Hobby or Pro)
      • Share your settings, tips and/or tricks for accomplishing the task so that I, and others, can learn how to use Twilight more properly.
        Sample image (not mine) to use as a reference for the challenge.
        By Massimo With Twilight of course! πŸ˜‰
        http://twilightrender.com/phpBB3/download/file.php?id=5458
        http://twilightrender.com/phpBB3/download/file.php?id=5398
        • ntxdaveN Offline
          ntxdave
          Thanks Pilou. I can draw the glass although it is nice to see these instructions which I will study.
          My biggest problem is with the rendering. I cannot get the color or transparency to work correctly for me. That is why I ask for the Twilight settings for the glass. Not doing well in that part at tall.
          • BoxB Offline
            Here's a very quick one.
            Background is a flat bottomed bowl, painted with snow, set to Plastic/Satin.
            Glass is translucent glass grey with all the colour edited out, set to Glass/Common.
            Top surface of the wine is Maroon with it's opacity dropped to 11, set as Glass/Common
            The body of the wine is Firebrick opacity also dropped to 11, Set to Liquid/Water
            Then rendered with preset .04 Medium with the environment setting a shown.
            There is a great deal of room for improvement of this, but just giving you the exact settings as they are.
            • ntxdaveN Offline
              ntxdave
              Thanks Box - that is the type of feedback I was hoping for. However, I have a question:
              Where/how did you edit out the color?
              • BoxB Offline
                That was the last thing I thought you would ask.
                The materials editor of sketchup, select the material and hit the edit tab.
                Then you can change the colour and how transparent it is.
                • ntxdaveN Offline
                  ntxdave
                  That is what I thought but I was making sure.
                  When I go try to do it myself, there will probably be more. Stay tuned 😎
                  My next guess is that I will have problems with the body of the wine.........
                  • ntxdaveN Offline
                    ntxdave
                    I took an existing model (not a good one) that I had had problems with before and tried some of the things Box had pointed out. Well, I got the glass showing up the way I wanted it but the background is a mess. Here is the render I created and a screen shot of all of the Twilight settings.
                    Notice how the background is a mess. I also tried a single background color and it did not come out correctly either. In particular, notice the grainy top portion of the background.
                    I have not even tried putting anything other that the silly objects inside the glass.
                    Here are the Twilight settings (notice there are no lights in the model).
                    Twilight Hobby Settings
                    Welcome all suggestions on how to get the background to come out right/better. I am satisfied that I now understand how to control the glass itself. Thanks Box you gave me the tips.......... πŸ‘
                    I have attached the skp file as well.........
                    SillySample.skp
                    • H Offline
                      hvanessen
                      a quick test with a different background
                      • H Offline
                        hvanessen
                        and the one on a wooden floor
                        wood floor
                        • ntxdaveN Offline
                          ntxdave
                          I tried a of floor too but did not get it to work right either. Would you mind sharing you background info and the various settings?
                          • ntxdaveN Offline
                            ntxdave
                            Well - I finally made some progress.
                            Here is latest effort:
                            Silly Glass Sample
                            Now off to go back to the original challenge and draw the glass (and maybe a bottle) with liquid content.
                              at bigmanwashes they certainly have some big ass glasses!
                              • ntxdaveN Offline
                                ntxdave
                                Not big glasses, just small blowers ❗
                                  JGA
                                  Is your background just an HDR image, rather than a physical plane?
                                  Regards,
                                  JGA
                                  • ntxdaveN Offline
                                    ntxdave
                                    In this particular case, yes.
                                    • ntxdaveN Offline
                                      ntxdave
                                      My latest endeavor.......
                                      Still not exactly what I want but getting closer.
                                        It's a funny result! β˜€
                                        • ntxdaveN Offline
                                          ntxdave
                                          Yep, it sure is. 😲
                                          • tuna1957T Offline
                                            tuna1957
                                            Dave C. , Stumbled across your post today. Twilight user also and you peaked my curiosity. Never have done the
                                            glass of wine business so figured why not. Built and textured my glass like Massimo shows ( thanks
                                            for posting that Pilou ! ) .Below I've listed how I set things up.
                                            Materials , Wine Glass - Snow , TW - glass / common
                                            Top of wine - Indian Red 12% opacity , TW - glass / water
                                            Side of wine - Fire Brick 12% opacity , TW - glass / water
                                            Backdrop - Cool Grey #4 , TW - paint / eggshell
                                            TW render preset - 08 Exterior Daytime Progressive
                                            TW Sun Settings - Physical Sky , Brightness - .800 , Haze - 20% , Sun Strength - 3.0
                                            Gave the sun a very light yellow color. all other settings left at default levels.
                                            Let the render run for 100 passes. It took about 19 minutes. Probably as good as it will get with this setup. Need to
                                            try some shots in an interior studio setup. Better chance of playing with lighting and use some other objects for
                                            reflections and such. Good luck and just keep working with TW you'll get better with practice. Thanks for the kick to
                                            do something a little different with SU & TW than I usually do. It was a nice change of pace.
                                            • 1 / 4
