    [Plugin] GKWare Cabinet Maker
    625 Posts 67 Posters 438.4k Views 68 Watching
      Garry K
      Version 1.0.31 is now ready for download.
        Garry K
        Version 1.0.31 has a number of bugs all relating to Top Gap for frame less construction.
        Version 1.0.32 addresses these issues and provides a solution.
        1. Fillers with frameless construction were too low when using Top Gap > 0. Fixed
        2. Upper cabinet insertion point with frameless construction was wrong when Top Gap > 0. Fixed
        3. Dividers overlapped Top Filler when Top Gap > 0. Fixed
        4. Top Filler wrong for Return and Angled cabinets. Fixed
          Garry K
          Version 1.0.32 ready for download
          • utilerU Offline
            utiler
            Hi Garry, not sure what's going on here. I can't seem to get the plugin going....?
            When I click to start the second point ['select right front corner"] won't happen. Neither will it allow me to enter a length in the VCB.
            Any ideas?
            Just Curious...
              Garry K
              Andrew
              Not sure what's happening with your setup.
              Please email me with the email address I PM'd you with. We will get this working for you.
              In the meantime. If you would open the Ruby Console and then try - maybe there are some errors.
              Also - when you email me - please include your OS version and SU version.
              Garry
                Garry K
                For some unknown reason Andrew hasn't picked up the PM that I sent him.
                Users can also contact me via my web site.
                http://cabmaker32.com/contact/
                I see these emails just as fast as if you emailed me directly. I also respond fairly quickly. After I respond you would have my email address and I will have yours.
                The last few releases are in response to a few users that have had some issues. They emailed me and I dug into the issues. Thanks to Scott, Bill, Grant and Piere.
                • utilerU Offline
                  utiler
                  Thanks Garry, all sorted now!
                  Just Curious...
                    Garry K
                    Here is a video with cab maker and cut list pro integration.
                      Garry K
                      I'm thinking about adding a feature where you create a cabinet with create options:
                      Create Options
                      Drop down that has "Full Cabinet", "Door Fronts Only", "Door Fronts and Frames Only"
                      • utilerU Offline
                        utiler
                        Hi Garry, is there a way for Cabmaker to identify material list as per what is in the current model?
                        Just Curious...
                          Garry K
                          Yes - Go to the defaults tab.
                          That will show you what all the defaults are.
                          I do save defaults settings with each model.
                          • utilerU Offline
                            utiler
                            Thanks but my defaults only show imperial_rules & imperial_rules_upper...?
                            How do I change it to metric?
                            Just Curious...
                              Garry K
                              From the main menu choose
                              Extensions \ GKWare CabMaker \ Cab Maker - Edit Config
                              Set Filter to Imperial to filter out Imperial
                              OR - depending upon what you want
                              Set Filter to Metric to filter out Metric
                              • utilerU Offline
                                utiler
                                I have that set to metric but still the defaults show imperial....
                                Just Curious...
                                  Garry K
                                  Yes - you are filtering out Metric.
                                  This setting will show everything else.
                                    Garry K
                                    Version 1.0.33 is now ready to download.
                                    1. Added width adjustment for cabinet sides and top / bottoms.
                                    2. Added bottom gap for frameless construction with overlay doors.
                                    3. Modified reports. Changed Solid to Dimensioned Lumber so that the report would work with Cut List Plus.
                                    • utilerU Offline
                                      utiler
                                      Gotcha. Filtering is filtering out. A bit back to front but I understand now. thanks.
                                      Just Curious...
                                      • soloS Offline
                                        Cabinet maker not working if you have Plusspec installed, I tried using it but it does not create any geometry or open any dialogs, I am assuming Plusspec is the cause as it started this behaviour after I installed the new version of Plusspec. However the Ruby console has this:
                                        Error; #<SyntaxError; (eval);1; syntax error, unexpected tIDENTIFIER, expecting end-of-input
                                        su"{dire">="olosp","wssa"drol">=evsa"sagil",snec>="ea",2l_...
                                        c;/users/pete/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/gkware_cabmaker/utils_cabmaker.rbs;592;in `eval'
                                        c;/users/pete/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/gkware_cabmaker/utils_cabmaker.rbs;592;in `read_license'
                                        c;/users/pete/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/gkware_cabmaker/license_cabmaker.rbs;62;in `activate_license'
                                        c;/users/pete/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/gkware_cabmaker/cabmaker.rbs;240;in `activate'
                                        c;/users/pete/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/gkware_cabmaker/cabmaker.rbs;4523;in `select_tool'
                                        c;/users/pete/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/gkware_cabmaker/cabmaker.rbs;4523;in `block in <module;CabMaker>'
                                        SketchUp;1;in `call'
                                          Garry K
                                          Just an assumption bug it looks like eval has been modified. Modifying built in objects is considered bad form.
                                          At this moment I suggest that you disable Plus Spec and try again and see what happens.
                                          • soloS Offline
                                            I just tried Cabinet maker using SU 2014 which does not have Plusspec installed and I am getting same behaviour, must be another issue.
                                            • 31
                                            • 32
                                            • 6 / 32
