    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 573.6k Views 71 Watching
      Garry K
      Here is a video with cab maker and cut list pro integration.
        Garry K
        I'm thinking about adding a feature where you create a cabinet with create options:
        Create Options
        Drop down that has "Full Cabinet", "Door Fronts Only", "Door Fronts and Frames Only"
        • utilerU Offline
          utiler
          Hi Garry, is there a way for Cabmaker to identify material list as per what is in the current model?
          Just Curious...
            Garry K
            Yes - Go to the defaults tab.
            That will show you what all the defaults are.
            I do save defaults settings with each model.
            • utilerU Offline
              utiler
              Thanks but my defaults only show imperial_rules & imperial_rules_upper...?
              How do I change it to metric?
              Just Curious...
                Garry K
                From the main menu choose
                Extensions \ GKWare CabMaker \ Cab Maker - Edit Config
                Set Filter to Imperial to filter out Imperial
                OR - depending upon what you want
                Set Filter to Metric to filter out Metric
                • utilerU Offline
                  utiler
                  I have that set to metric but still the defaults show imperial....
                  Just Curious...
                    Garry K
                    Yes - you are filtering out Metric.
                    This setting will show everything else.
                      Garry K
                      Version 1.0.33 is now ready to download.
                      1. Added width adjustment for cabinet sides and top / bottoms.
                      2. Added bottom gap for frameless construction with overlay doors.
                      3. Modified reports. Changed Solid to Dimensioned Lumber so that the report would work with Cut List Plus.
                      • utilerU Offline
                        utiler
                        Gotcha. Filtering is filtering out. A bit back to front but I understand now. thanks.
                        Just Curious...
                        • soloS Offline
                          Cabinet maker not working if you have Plusspec installed, I tried using it but it does not create any geometry or open any dialogs, I am assuming Plusspec is the cause as it started this behaviour after I installed the new version of Plusspec. However the Ruby console has this:
                          Error; #<SyntaxError; (eval);1; syntax error, unexpected tIDENTIFIER, expecting end-of-input
                          su"{dire">="olosp","wssa"drol">=evsa"sagil",snec>="ea",2l_...
                          c;/users/pete/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/gkware_cabmaker/utils_cabmaker.rbs;592;in `eval'
                          c;/users/pete/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/gkware_cabmaker/utils_cabmaker.rbs;592;in `read_license'
                          c;/users/pete/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/gkware_cabmaker/license_cabmaker.rbs;62;in `activate_license'
                          c;/users/pete/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/gkware_cabmaker/cabmaker.rbs;240;in `activate'
                          c;/users/pete/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/gkware_cabmaker/cabmaker.rbs;4523;in `select_tool'
                          c;/users/pete/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/gkware_cabmaker/cabmaker.rbs;4523;in `block in <module;CabMaker>'
                          SketchUp;1;in `call'
                            Garry K
                            Just an assumption bug it looks like eval has been modified. Modifying built in objects is considered bad form.
                            At this moment I suggest that you disable Plus Spec and try again and see what happens.
                            • soloS Offline
                              I just tried Cabinet maker using SU 2014 which does not have Plusspec installed and I am getting same behaviour, must be another issue.
                                Garry K
                                Pete,
                                I've sent you a PM with my email address. We can figure this out.
                                Garry
                                  Garry K
                                  For support users shoul contact me via my web site.
                                  http://cabmaker32.com/contact/
                                  This will get through to me almost immediately and no chance of going to trash.
                                  I will then answer as quickly as possible.
                                    Garry K
                                    A user has found a bug and I've fixed it.
                                    I will put out version 1.0.34 with the fix late tomorrow or early the next day.
                                    The bug has to do with finished panels.
                                    • aadbuildA Offline
                                      aadbuild
                                      Hi Garry i understand we have some type of clash between Plusspec and Cabinet maker? I can send you a beta version or vice versa of that helps? .
                                      I had a quick look at what you are doing and it's fantastic. Good job, sometimes it takes a tradesman to build site specific software. It looks like it would compliment what we are doing with Plusspec.
                                      Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                                      https://www.plusspec.com
                                      • soloS Offline
                                        Andrew.
                                        Figured out it has nothing to do with Plusspec, just a coincidental timing thing. It has to do with my login.
                                          Garry K
                                          I think Pete is correct.
                                          Andrew - I am slowly trying to narrow this down.
                                          The crazy part is that the old version used to work on Pete's computer - now it doesn't.
                                          Something has changed - just don't know what it is. What I mean is the old version no longer works.
                                          The other interesting thing is that no one else has reported this problem. That doesn't mean no one else has seen it - it just means no one has brought it to my attention.
                                          • aadbuildA Offline
                                            aadbuild
                                            That is good to know, we do have the PlusSpec 2016 beta version out to beta testers, it would be great if you joined Garry. PM me if keen, I understand that you have a lot on your plate so no hurry mate.
                                            Getting close to beer o'clock down under. See you all at BaseCamp
                                            With your input, this post could be even better šŸ’—
                                            • 11
                                            • 12
                                            • 31
                                            • 32
                                            • 10 / 32
