    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 538.2k Views 71 Watching
      Garry K
      Bill,
      All horizontal cabinet parts are first created vertical (so wood grain works and length is length for reports). Then the parts are moved and rotated into cabinet position.
      The toe kick part that remained vertical means the cabinet create process quit at an error. In this case it is probably a nil reference because of the 0 thickness for the materials. Toe kicks are the last thing I create - so that is why the rest of the cabinet is complete - however the cabinet itself would stay at the origin and would fail to move and rotate into position.
      Currently there is no way to create a cabinet with more than 2 side by side doors. To do so the permutations and combinations become staggering. To handle your 3 door example as a cabinet maker I always created 2 cabinets - 1 with 2 doors and 1 with 1 door. In my opinion the 1 extra side panel is very inexpensive as compared to all the extra labour to handle everything from design to all the logistics of that custom cabinet.
      Finally - when I want to draw a custom cabinet I just create the parts from scratch and use the Door Maker to fit the drawers. However you can right click and explode the various parts - but it is probably more time consuming than creating a single cabinet from scratch.
        Garry K
        I've been asked to consider a lease to own program and I would like to hear from people on how they feel about this.
        For easy round numbers let's take a plugin that is 100 $
        If the lease to own program is a one year program then the monthly lease would be 10 $
        This means your total cost of ownership would be 120 $
        Any comments?
          Garry K
          Version 1.0.30 is now ready for download
          1. Updated Rules editor. Fields now automatically enable / disable based on "Overlay / Inset" and "Construction".
          2. Added Drawer Back Length Adjustment for drawer boxes. This corrects the parts listing when cabinet makers want to create dovetail drawers.
          3. Added Back Overhang for finished panels. You can use a negative value if you wish.
          4. Added Filters so that examples can be filtered out. From main menu run 'Cab Maker - Edit Config'
          5. Fixed problem with un-profiled door panels. They were always showing up as 6mm or 1/4". Cab Maker now honors panel thickness from the materials template.
            Garry K
            Set Filter to 1 of 4 values, 'None', 'Metric', 'Imperial', 'Both'
            All template examples now start with the text 'metric_' or the text 'imperial_'
            If you work in inches then filter out metric or vice versa.
            Filter Examples uses a text file called filters.txt for additional specific filtering.
              Garry K
              Version 1.0.31 - Feb 10 2016
              1. Single pullout door and pullout created error. Fixed.
              2. Fixed bug with tall cabinets and frameless construction.
              3. Run filler to floor when notch is set to 0 for base cabinets.
              4. Fixed parts report. Sorting and Summarizing now working.
              5. Added side by side drawers for Standard and Sink Base cabinets (not angled).
              6. Added auto size drawers. Works for Standard cabinets where there are at least 2 drawers and no doors. Works for Tall cabinets if there is at least 1 drawer.
              7. Added Top Filler for frameless construction when Top Gap is increased to more than 1/2 the thickness of the top.
              For faceframe construction you can now have side by side drawers for standard cabinets where there is at least 1 drawer (full frame) or exactly 1 drawer (partial frame). You can have 0, 1 or 2 doors.
              For Drawer Banks and tall cabinets you can now ask Cab Maker to calculate the proper height of the bottom most drawer
              Filler works for all cabinets. With sink cabinets the top filler takes precedence over the sink stretcher.
                Garry K
                Version 1.0.31 is now ready for download.
                  Garry K
                  Version 1.0.31 has a number of bugs all relating to Top Gap for frame less construction.
                  Version 1.0.32 addresses these issues and provides a solution.
                  1. Fillers with frameless construction were too low when using Top Gap > 0. Fixed
                  2. Upper cabinet insertion point with frameless construction was wrong when Top Gap > 0. Fixed
                  3. Dividers overlapped Top Filler when Top Gap > 0. Fixed
                  4. Top Filler wrong for Return and Angled cabinets. Fixed
                    Garry K
                    Version 1.0.32 ready for download
                    • utilerU Offline
                      utiler
                      Hi Garry, not sure what's going on here. I can't seem to get the plugin going....?
                      When I click to start the second point ['select right front corner"] won't happen. Neither will it allow me to enter a length in the VCB.
                      Any ideas?
                      Just Curious...
                        Garry K
                        Andrew
                        Not sure what's happening with your setup.
                        Please email me with the email address I PM'd you with. We will get this working for you.
                        In the meantime. If you would open the Ruby Console and then try - maybe there are some errors.
                        Also - when you email me - please include your OS version and SU version.
                        Garry
                          Garry K
                          For some unknown reason Andrew hasn't picked up the PM that I sent him.
                          Users can also contact me via my web site.
                          http://cabmaker32.com/contact/
                          I see these emails just as fast as if you emailed me directly. I also respond fairly quickly. After I respond you would have my email address and I will have yours.
                          The last few releases are in response to a few users that have had some issues. They emailed me and I dug into the issues. Thanks to Scott, Bill, Grant and Piere.
                          • utilerU Offline
                            utiler
                            Thanks Garry, all sorted now!
                            Just Curious...
                              Garry K
                              Here is a video with cab maker and cut list pro integration.
                                Garry K
                                I'm thinking about adding a feature where you create a cabinet with create options:
                                Create Options
                                Drop down that has "Full Cabinet", "Door Fronts Only", "Door Fronts and Frames Only"
                                • utilerU Offline
                                  utiler
                                  Hi Garry, is there a way for Cabmaker to identify material list as per what is in the current model?
                                  Just Curious...
                                    Garry K
                                    Yes - Go to the defaults tab.
                                    That will show you what all the defaults are.
                                    I do save defaults settings with each model.
                                    • utilerU Offline
                                      utiler
                                      Thanks but my defaults only show imperial_rules & imperial_rules_upper...?
                                      How do I change it to metric?
                                      Just Curious...
                                        Garry K
                                        From the main menu choose
                                        Extensions \ GKWare CabMaker \ Cab Maker - Edit Config
                                        Set Filter to Imperial to filter out Imperial
                                        OR - depending upon what you want
                                        Set Filter to Metric to filter out Metric
                                        • utilerU Offline
                                          utiler
                                          I have that set to metric but still the defaults show imperial....
                                          Just Curious...
                                            Garry K
                                            Yes - you are filtering out Metric.
                                            This setting will show everything else.
                                            With your input, this post could be even better šŸ’—
                                            • 11
                                            • 31
                                            • 32
                                            • 9 / 32
