    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 574.2k Views 71 Watching
      Garry K
      I've been asked to consider a lease to own program and I would like to hear from people on how they feel about this.
      For easy round numbers let's take a plugin that is 100 $
      If the lease to own program is a one year program then the monthly lease would be 10 $
      This means your total cost of ownership would be 120 $
      Any comments?
        Garry K
        Version 1.0.30 is now ready for download
        1. Updated Rules editor. Fields now automatically enable / disable based on "Overlay / Inset" and "Construction".
        2. Added Drawer Back Length Adjustment for drawer boxes. This corrects the parts listing when cabinet makers want to create dovetail drawers.
        3. Added Back Overhang for finished panels. You can use a negative value if you wish.
        4. Added Filters so that examples can be filtered out. From main menu run 'Cab Maker - Edit Config'
        5. Fixed problem with un-profiled door panels. They were always showing up as 6mm or 1/4". Cab Maker now honors panel thickness from the materials template.
          Garry K
          Set Filter to 1 of 4 values, 'None', 'Metric', 'Imperial', 'Both'
          All template examples now start with the text 'metric_' or the text 'imperial_'
          If you work in inches then filter out metric or vice versa.
          Filter Examples uses a text file called filters.txt for additional specific filtering.
            Garry K
            Version 1.0.31 - Feb 10 2016
            1. Single pullout door and pullout created error. Fixed.
            2. Fixed bug with tall cabinets and frameless construction.
            3. Run filler to floor when notch is set to 0 for base cabinets.
            4. Fixed parts report. Sorting and Summarizing now working.
            5. Added side by side drawers for Standard and Sink Base cabinets (not angled).
            6. Added auto size drawers. Works for Standard cabinets where there are at least 2 drawers and no doors. Works for Tall cabinets if there is at least 1 drawer.
            7. Added Top Filler for frameless construction when Top Gap is increased to more than 1/2 the thickness of the top.
            For faceframe construction you can now have side by side drawers for standard cabinets where there is at least 1 drawer (full frame) or exactly 1 drawer (partial frame). You can have 0, 1 or 2 doors.
            For Drawer Banks and tall cabinets you can now ask Cab Maker to calculate the proper height of the bottom most drawer
            Filler works for all cabinets. With sink cabinets the top filler takes precedence over the sink stretcher.
              Garry K
              Version 1.0.31 is now ready for download.
                Garry K
                Version 1.0.31 has a number of bugs all relating to Top Gap for frame less construction.
                Version 1.0.32 addresses these issues and provides a solution.
                1. Fillers with frameless construction were too low when using Top Gap > 0. Fixed
                2. Upper cabinet insertion point with frameless construction was wrong when Top Gap > 0. Fixed
                3. Dividers overlapped Top Filler when Top Gap > 0. Fixed
                4. Top Filler wrong for Return and Angled cabinets. Fixed
                  Garry K
                  Version 1.0.32 ready for download
                  • utilerU Offline
                    utiler
                    Hi Garry, not sure what's going on here. I can't seem to get the plugin going....?
                    When I click to start the second point ['select right front corner"] won't happen. Neither will it allow me to enter a length in the VCB.
                    Any ideas?
                    Just Curious...
                      Garry K
                      Andrew
                      Not sure what's happening with your setup.
                      Please email me with the email address I PM'd you with. We will get this working for you.
                      In the meantime. If you would open the Ruby Console and then try - maybe there are some errors.
                      Also - when you email me - please include your OS version and SU version.
                      Garry
                        Garry K
                        For some unknown reason Andrew hasn't picked up the PM that I sent him.
                        Users can also contact me via my web site.
                        http://cabmaker32.com/contact/
                        I see these emails just as fast as if you emailed me directly. I also respond fairly quickly. After I respond you would have my email address and I will have yours.
                        The last few releases are in response to a few users that have had some issues. They emailed me and I dug into the issues. Thanks to Scott, Bill, Grant and Piere.
                        • utilerU Offline
                          utiler
                          Thanks Garry, all sorted now!
                          Just Curious...
                            Garry K
                            Here is a video with cab maker and cut list pro integration.
                              Garry K
                              I'm thinking about adding a feature where you create a cabinet with create options:
                              Create Options
                              Drop down that has "Full Cabinet", "Door Fronts Only", "Door Fronts and Frames Only"
                              • utilerU Offline
                                utiler
                                Hi Garry, is there a way for Cabmaker to identify material list as per what is in the current model?
                                Just Curious...
                                  Garry K
                                  Yes - Go to the defaults tab.
                                  That will show you what all the defaults are.
                                  I do save defaults settings with each model.
                                  • utilerU Offline
                                    utiler
                                    Thanks but my defaults only show imperial_rules & imperial_rules_upper...?
                                    How do I change it to metric?
                                    Just Curious...
                                      Garry K
                                      From the main menu choose
                                      Extensions \ GKWare CabMaker \ Cab Maker - Edit Config
                                      Set Filter to Imperial to filter out Imperial
                                      OR - depending upon what you want
                                      Set Filter to Metric to filter out Metric
                                      • utilerU Offline
                                        utiler
                                        I have that set to metric but still the defaults show imperial....
                                        Just Curious...
                                          Garry K
                                          Yes - you are filtering out Metric.
                                          This setting will show everything else.
                                            Garry K
                                            Version 1.0.33 is now ready to download.
                                            1. Added width adjustment for cabinet sides and top / bottoms.
                                            2. Added bottom gap for frameless construction with overlay doors.
                                            3. Modified reports. Changed Solid to Dimensioned Lumber so that the report would work with Cut List Plus.
                                            With your input, this post could be even better šŸ’—
                                            • 11
                                            • 12
                                            • 31
                                            • 32
                                            • 10 / 32
