    Line length on circle scaled to ellipse is very wrong
    48 Posts 12 Posters 6.1k Views 12 Watching
      Using Approximation 2, the perimeter would be 2118.265712279433
      A nurbs program 400 * 900 ellipse gives 2118,2799332 length line perimeter
      Sketchup gives 2118,276442 with circle 1000 segments
        slbaumgartner
        I think it is a bug. I looked up the formula for perimeter of an ellipse and compared that with what SketchUp's entity info returns. For a 10x20 ellipse, the result should be 96.88. SketchUp variously returned 62.83 (20*pi), 111.3, and 113.27.
        • ely862meE Offline
          ely862me
          There was already a bug submitted for this, yes it is a bug. Also changing lengths when copying an ellipse is a bug. They are in the database and most likely sometime in the near future will be fixed.
          Elisei (sketchupper)
          Come and See EliseiDesign
            mac1
            There is no closed form equation for perimeter of ellipse
            it is approximated by p=2PIsqrt[[[ a^2+b^2]/2]^1/2]
            The correct value p=4aE where E is the elliptic integral where k=1/a
            sqrt[a^2-b^2]
            • bazB Offline
              baz
              sqrt[a^2-b^2]
              Yeah, what Mac said...
                slbaumgartner
                Mac is right, though there are several other approximate formulas that are better than the one he gave. Also, there are power-series that can be run to enough terms to get arbitrarily close. The point here is that even the sum of the lengths of the edges in the oval comes much closer than the strange values that SketchUp sometimes provides.i
                  CAUL
                  The best estimation of the circumference I've found is this:
                    def self.circumference(major, minor)
                      a = major / 2.0
                      b = minor / 2.0
                      d = b / a
                      x0 = d**0.5
                      x1 = d
                      x2 = d**1.5
                      x3 = d**2
                      x4 = d**2.5
                      s0 = 3929 * x0 + 1639157 * x1 + 19407215 * x2 + 24302653 * x3 + 12892432 * x4
                      s1 = 86251 + 1924742 * x0 + 6612384 * x1 + 7291509 * x2 + 6436977 * x3 + 3158719 * x4
                      c = 4 * a + b * (s0 / s1)
                      return c
                  It's extremely accurate, unfortunately I don't know where I found it so I can't give credits.
                    And what is its result in this case ? (Ellipse 400*900)
                      CAUL
                      2118.2799288074484
                      The result above is for major = 900, minor = 400, if your input refers to the semi axes multiply the result by 2.
                        @ Caul
                        So my result of Nurbs prog was not so bad! πŸ˜‰
                        2118,2799 332 against your theoric 2118.2799 288074484
                        Sketchup gives 2118,27 6442 with circle 1000 segments! πŸ˜‰
                        But what think of this
                        The actual line length is 2155 +/- 5. measured in the real world.
                        Measured with ?
                        http://www.filoche-et-ficelle.fr/314-831-thickbox/pelote-de-jute-ficelle-jute-75m.jpg
                        or
                        http://www.achatmat.com/mesure-courte/metre-ruban-ergonomique-bi-matiere-p-3000740-600x600.jpg
                        or...?
                          mac1
                          Attched is pic of ellipse drawn by the means of supplemental chords with no scaling. I included different seg counts just to show what can be done. If there is intersest I'll redo with more care.
                          Su reports length of 48.364" for size shown.
                          If you can run the polynomial curve fit equation shown I would appreciate. If this approach is useful for you I'll redo and show how to draw. It is a little more complicated than scaling but not much since you can draw 1/4 and then mirrow.
                          • bazB Offline
                            baz
                            @pilou said:
                            @ Caul
                            Measured with ?
                            A piece of string Pilou, sorry I cant recheck it, the job is done and dusted.
                            • bazB Offline
                              baz
                              @mac1 said:
                              Attched is pic of ellipse drawn by the means of supplemental chords with no scaling. I included different seg counts just to show what can be done. If there is interest I'll redo with more care.
                              Su reports length of 48.364" for size shown. (1228.4456mm)
                              Oops see one dimension got cropped it is 10"[attachment=0:cf3intzr]<!-- ia0 -->conjuate ellipse.jpg<!-- ia0 -->[/attachment:cf3intzr]
                              Curious to see how you do it Mac. (Tho' the curve on the minor axis is a bit pointy n'est pas?)
                                CAUL
                                The code below constructs an ellipse in a group centered at origo where all edges have the exact same length. Since the script only computes a quarter ellipse the final full ellipse has an edge count divisible by 4. There's a "user interface" at the end to set major, minor and edge count. The circumference converges to the correct value with increased edgecount.
                                To run it, just paste the code into the ruby console and press enter.
                                module CAUL_RegularEllipse
                                  #hack found on the internets. Very accurate...
                                    a = major / 2.0
                                    b = minor / 2.0
                                    d = b / a
                                    x0 = d**0.5
                                    x1 = d
                                    x2 = d**1.5
                                    x3 = d**2
                                    x4 = d**2.5
                                    return c
                                  #find the intersection between a positive half ellipse at (0, 0) and a
                                  #positive half circle at (h, k) with radius r in the first quadrant.
                                  def self.circle_ellipse_intersect(a, b, h, k, r, c)
                                    #start point must be chosen with care so we don't end up outside the domain
                                    x = h - c * r
                                    epsilon = 0.000000000000001
                                    f_e = f_c = 0
                                    (0..15).each { |i|
                                      f_e_sqr = 4 * (a*a * b*b) * (a*a - x*x)
                                      f_c_sqr = 2 * h * x + r*r - x*x - h*h
                                      df_e_sqr = a*a * b*b * (a*a - x*x)
                                      df_c_sqr = r*r + 2 * h * x - x*x - h*h
                                      return nil if f_e_sqr < 0 || f_c_sqr < 0 || df_e_sqr < 0 || df_c_sqr < 0
                                      f_e  = Math;;sqrt(f_e_sqr) / (2 * a*a)
                                      f_c =  Math;;sqrt(f_c_sqr) + k
                                      df_e = -(b*b * x) / Math;;sqrt(df_e_sqr)
                                      df_c = (h - x) / Math;;sqrt(df_c_sqr)
                                      break if (f_e - f_c).abs <= epsilon
                                      x = x - (f_e - f_c) / (df_e - df_c)
                                    return [x, f_e]
                                  #given a positive x-value, return the point on the ellipse in the first qudrant
                                  def self.get_ellipse_point(major, minor, x)
                                    a = major / 2.0
                                    b = minor / 2.0
                                    return Geom;;Point3d.new(x, f_e, 0)
                                  #return how close the ellipse gets to the endpoint at ex with #bits segments
                                  #of length len.
                                  def self.test_ellipse(len, q_bits, major, minor, ex)
                                    a = major / 2.0;
                                    b = minor / 2.0;
                                    d = count = 0
                                    coff = [0.99999999, 0.00000001, 0.5]
                                    p0 = Geom;;Point3d.new(a, 0, 0)
                                    pe = get_ellipse_point(major, minor, ex)
                                    (0..q_bits - 2).each { |i|
                                      arr = nil
                                      coff.each { |c|
                                        arr = circle_ellipse_intersect(a, b, p0.x, p0.y, len, c)
                                        break if arr != nil
                                      return nil, nil if arr == nil
                                      p0.x = arr[0]
                                      p0.y = arr[1]
                                      d = pe.distance(p0)
                                      count += 1
                                      break if d < len
                                    return d, count
                                  #given an ellipse and the number of segments (q_bits) covering a quarter of the ellipse,
                                  #compute the length of a segment.
                                  def self.get_segment_length(major, minor, q_bits, ex)
                                    c = circumference(major, minor)
                                    #len is guaranteed to be a close over estimation
                                    len = (c / 4.0) / q_bits
                                    #regress towards the root by adjusting len downwards. Very rapid convergence..
                                    (0..10).each { |i|
                                      d, count =  test_ellipse(len, q_bits, major, minor, ex)
                                      over = (len - d) + (q_bits - 1 - count) * d
                                      len -= over / q_bits
                                    return len
                                  def self.get_quarter_ellipse(major, minor, q_bits, len)
                                    a = major / 2.0;
                                    b = minor / 2.0;
                                    d = count = 0
                                    ps = [p0]
                                    pe = Geom;;Point3d.new(0, b, 0)
                                      arr = nil
                                      coff.each { |c|
                                        break if arr != nil
                                      p1 = Geom;;Point3d.new(arr[0], arr[1], 0)
                                      ps << p1
                                      p0 = p1
                                    ps << pe
                                    return ps
                                  def self.get_ellipse(major, minor, q_bits, len)
                                    ps = get_quarter_ellipse(major, minor, q_bits, len)
                                    ##add the other three quadrants
                                    len = ps.length
                                    (0..len - 2).each { |i| ps << Geom;;Point3d.new(-ps[len - 2 - i].x, ps[len - 2 - i].y, 0) }
                                    len = ps.length
                                    (0..len - 2).each { |i| ps << Geom;;Point3d.new(ps[len - 2 - i].x, -ps[len - 2 - i].y, 0) }
                                    ps.delete_at(ps.length - 1)
                                    return ps
                                  ######### MAIN #########
                                  def self.main
                                    mod = Sketchup.active_model
                                    ent = mod.entities
                                    sel = mod.selection
                                    ###### USER INTERFACE ####
                                    major = 900.mm
                                    minor = 400.mm
                                    q_bits = 100 #number of segments in a quarter ellipse (-> full ellipse has q_bits * 4 segments)
                                    len = get_segment_length(major, minor, q_bits, 0)
                                    ps = get_ellipse(major, minor, q_bits, len)
                                    ### ADD THE ELLIPSE ##
                                    ng = ent.add_group
                                    (0..ps.length - 1).each { |i| ng.entities.add_line ps[i], ps[(i+1) % ps.length] }
                                    puts 'done'
                                  main
                                • bazB Offline
                                  baz
                                  A L. Great, that will be very useful in the future. Thanks.
                                  Ps: 2118mm again, How long was my piece of string?
                                  • BoxB Offline
                                    Use elastic next time Baz then you can get several measurements in one.
                                    • bazB Offline
                                      baz
                                      Which was exactly where I came in...
                                      ... everybody chill, it's solved in at least four or five ways, go back to your lives!
                                      Thank you all for all your obsessive help. β˜€
                                      Baz
                                      PS: It's still a bug. πŸ˜›
                                        At the maximum display precision of SU with Caul program
                                        2118.238356
                                        Nurbs Prog 2118,2799 332 against your theoric 2118.2799 288074484
                                        For Baz πŸ˜‰
                                        http://i2.cdscdn.com/pdt2/4/1/0/1/700x700/auc3760180275410/rw/loom-bands-sachet-300-elastiques.jpg
                                          mac1
                                          conjuate ellipse.skpBaz: as noted the model was just proof of concept so not worried about segments yet. the 10X5 (semi) " better model reports 24.227n inches for 1/2 , has only 72 edges and looks very nice.
                                          Some way the number I posted above is not correct so forget about running you calculation. BTW that brings up a question. There are several eliptic intergals and the corresponding polynominal curve fits to those. Do you know which type your equation is for.
                                          • bazB Offline
                                            baz
                                            @mac1 said:
                                            [attachment=0:1ln04vy0]<!-- ia0 -->conjuate ellipse.skp<!-- ia0 -->[/attachment:1ln04vy0]Baz: Do you know which type your equation is for.
                                            Sorry Mac, I have no idea.
                                            • 2 / 3
