    Line length on circle scaled to ellipse is very wrong
    48 Posts 12 Posters 6.6k Views 12 Watching
    • bazB
      baz
      @pbacot said:
      if you split the circles before the length of the two half curves remains the same when scaled regardless of sides...
      Sorry, not quite following you there.
      But to restate the question: If I draw a line at 100, Entity Info will tell me its 100.
      If I draw an arc and explode, I will get an accurate line length.
      However, if I scale a circle to make an ellipse, Entity Info gives me nonsense, and not even consistent nonsense. I just went back to my example model as shown at top and all the reported numbers are now different...
      It's to do with scaling, I reckon. It confuses SU's little brain.
      • ely862meE
        ely862me
        This might be a bug..
        Elisei (sketchupper)
        Come and See EliseiDesign
        • bazB
          baz
          According to previous posters, it is a limitation of SU. But I can't see why a line shouldn't be a line, whether curved, stretched or otherwise abused.
          Shall I load the skp?
          • G
            Garry K
            Circle1 144s at 400 mm - scale by factor of 2
            Circle2 288s at 400 mm - scale by factor of 2
            entity information reports ~5026.5 mm for both - I don't know where this number comes from
            Then pushpull each ellipse into elliptical cylinder
            Select arc and explode
            entity information now reports ~3872.6 mm for Circle1
            entity information now reports ~3875.3 mm for Circle2
            Elliptical Circumference calculates out at 3875.38
            • bazB
              baz
              Exactly! Or inexactly as it happens. Could you open that file again and see if the numbers have changed, they have on mine.
              • ely862meE
                ely862me
                Once you get to copy them around you get all kinds of lengths.
                • pbacotP
                  It doesn't make sense. Really CAD programs should have an ellipse tool.
                    slbaumgartner
                    I did some probing via Ruby, and it seems there is a chain of bugs causing this. First, when you scale a circle to make it an ellipse, SketchUp should drop the metadata defining it as a circle and treat it as just a closed loop of segments (a Curve). It does not do so, it continues to carry the center point, radius, and normal vector as if the loop is still a circle, and the edges still say they are part of an ArcCurve. This evidently triggers a second bug in the method that calculates the circumference of the loop. In some cases it still calculates the mathematical 2pir as if the circle hasn't been scaled. In other cases it calculates a strange value that has no evident relationship to anything. In no case does it return the sum of the lengths of the edges!
                    • Wo3DanW
                      Wo3Dan
                      Lengths of (part of) an ellips do not show rigtht. This has been mentioned before.
                      I hope you can see this thread. See posts around 17/4/2008 and on.
                      https://groups.google.com/forum/#!searchin/sketchup3d/ellips$2Barea%7Csort:relevance/sketchup3d/z70T5xdUm_I/g-ChcSEcL2YJ
                      *"Taff, Google SU team,
                      Very nice approach Taff, almost precise. Here again there is the
                      lack of a precise ''snap to" with these rotations. But it's the best
                      you can do!
                      But I noticed an (important) bug in the "Entity Info" and "Text"
                      tool output.
                      The curve length shown is only half of what it should be.
                      Before you exploded the 1/4 ellipse curve the Entity Info reports
                      141.371669' as the curve length (also through Text tool)
                      It should however be: 282.743338'
                      16 segments out of the exploded curve add up to: 281.923143'
                      just a bit shorter which is obvious.
                      The more segments the more precise Taff's approach will be.
                      Even better when there were a "rotate snap" option to a curve.
                      Regards,
                      Wo3Dan "*
                      • bazB
                        baz
                        Pilou. The actual line length is 2155 +/- 5. measured in the real world.
                        This thread is starting to make my brain hurt...so, respected elders, is it a Bug or not?
                          Using Approximation 2, the perimeter would be 2118.265712279433
                          A nurbs program 400 * 900 ellipse gives 2118,2799332 length line perimeter
                          Sketchup gives 2118,276442 with circle 1000 segments
                            slbaumgartner
                            I think it is a bug. I looked up the formula for perimeter of an ellipse and compared that with what SketchUp's entity info returns. For a 10x20 ellipse, the result should be 96.88. SketchUp variously returned 62.83 (20*pi), 111.3, and 113.27.
                            • ely862meE
                              ely862me
                              There was already a bug submitted for this, yes it is a bug. Also changing lengths when copying an ellipse is a bug. They are in the database and most likely sometime in the near future will be fixed.
                                mac1
                                There is no closed form equation for perimeter of ellipse
                                it is approximated by p=2PIsqrt[[[ a^2+b^2]/2]^1/2]
                                The correct value p=4aE where E is the elliptic integral where k=1/a
                                sqrt[a^2-b^2]
                                • bazB
                                  baz
                                  sqrt[a^2-b^2]
                                  Yeah, what Mac said...
                                    slbaumgartner
                                    Mac is right, though there are several other approximate formulas that are better than the one he gave. Also, there are power-series that can be run to enough terms to get arbitrarily close. The point here is that even the sum of the lengths of the edges in the oval comes much closer than the strange values that SketchUp sometimes provides.i
                                    • C
                                      CAUL
                                      The best estimation of the circumference I've found is this:
                                        def self.circumference(major, minor)
                                          a = major / 2.0
                                          b = minor / 2.0
                                          d = b / a
                                          x0 = d**0.5
                                          x1 = d
                                          x2 = d**1.5
                                          x3 = d**2
                                          x4 = d**2.5
                                          s0 = 3929 * x0 + 1639157 * x1 + 19407215 * x2 + 24302653 * x3 + 12892432 * x4
                                          s1 = 86251 + 1924742 * x0 + 6612384 * x1 + 7291509 * x2 + 6436977 * x3 + 3158719 * x4
                                          c = 4 * a + b * (s0 / s1)
                                          return c
                                      It's extremely accurate, unfortunately I don't know where I found it so I can't give credits.
                                        And what is its result in this case ? (Ellipse 400*900)
                                        • C
                                          CAUL
                                          2118.2799288074484
                                          The result above is for major = 900, minor = 400, if your input refers to the semi axes multiply the result by 2.
                                            @ Caul
                                            So my result of Nurbs prog was not so bad! 😉
                                            2118,2799 332 against your theoric 2118.2799 288074484
                                            Sketchup gives 2118,27 6442 with circle 1000 segments! 😉
                                            But what think of this
                                            Measured with ?
                                            http://www.filoche-et-ficelle.fr/314-831-thickbox/pelote-de-jute-ficelle-jute-75m.jpg
                                            or
                                            http://www.achatmat.com/mesure-courte/metre-ruban-ergonomique-bi-matiere-p-3000740-600x600.jpg
                                            or...?
                                            • 2 / 3
