    Line length on circle scaled to ellipse is very wrong
    48 Posts 12 Posters 6.1k Views 12 Watching
    • bazB Offline
      baz
      Pilou. The actual line length is 2155 +/- 5. measured in the real world.
      This thread is starting to make my brain hurt...so, respected elders, is it a Bug or not?
        Using Approximation 2, the perimeter would be 2118.265712279433
        A nurbs program 400 * 900 ellipse gives 2118,2799332 length line perimeter
        Sketchup gives 2118,276442 with circle 1000 segments
          slbaumgartner
          I think it is a bug. I looked up the formula for perimeter of an ellipse and compared that with what SketchUp's entity info returns. For a 10x20 ellipse, the result should be 96.88. SketchUp variously returned 62.83 (20*pi), 111.3, and 113.27.
          • ely862meE Offline
            ely862me
            There was already a bug submitted for this, yes it is a bug. Also changing lengths when copying an ellipse is a bug. They are in the database and most likely sometime in the near future will be fixed.
            Elisei (sketchupper)
            Come and See EliseiDesign
              mac1
              There is no closed form equation for perimeter of ellipse
              it is approximated by p=2PIsqrt[[[ a^2+b^2]/2]^1/2]
              The correct value p=4aE where E is the elliptic integral where k=1/a
              sqrt[a^2-b^2]
              • bazB Offline
                baz
                sqrt[a^2-b^2]
                Yeah, what Mac said...
                  slbaumgartner
                  Mac is right, though there are several other approximate formulas that are better than the one he gave. Also, there are power-series that can be run to enough terms to get arbitrarily close. The point here is that even the sum of the lengths of the edges in the oval comes much closer than the strange values that SketchUp sometimes provides.i
                    CAUL
                    The best estimation of the circumference I've found is this:
                      def self.circumference(major, minor)
                        a = major / 2.0
                        b = minor / 2.0
                        d = b / a
                        x0 = d**0.5
                        x1 = d
                        x2 = d**1.5
                        x3 = d**2
                        x4 = d**2.5
                        s0 = 3929 * x0 + 1639157 * x1 + 19407215 * x2 + 24302653 * x3 + 12892432 * x4
                        s1 = 86251 + 1924742 * x0 + 6612384 * x1 + 7291509 * x2 + 6436977 * x3 + 3158719 * x4
                        c = 4 * a + b * (s0 / s1)
                        return c
                    It's extremely accurate, unfortunately I don't know where I found it so I can't give credits.
                      And what is its result in this case ? (Ellipse 400*900)
                        CAUL
                        2118.2799288074484
                        The result above is for major = 900, minor = 400, if your input refers to the semi axes multiply the result by 2.
                          @ Caul
                          So my result of Nurbs prog was not so bad! πŸ˜‰
                          2118,2799 332 against your theoric 2118.2799 288074484
                          Sketchup gives 2118,27 6442 with circle 1000 segments! πŸ˜‰
                          But what think of this
                          Measured with ?
                          http://www.filoche-et-ficelle.fr/314-831-thickbox/pelote-de-jute-ficelle-jute-75m.jpg
                          or
                          http://www.achatmat.com/mesure-courte/metre-ruban-ergonomique-bi-matiere-p-3000740-600x600.jpg
                          or...?
                            mac1
                            Attched is pic of ellipse drawn by the means of supplemental chords with no scaling. I included different seg counts just to show what can be done. If there is intersest I'll redo with more care.
                            Su reports length of 48.364" for size shown.
                            If you can run the polynomial curve fit equation shown I would appreciate. If this approach is useful for you I'll redo and show how to draw. It is a little more complicated than scaling but not much since you can draw 1/4 and then mirrow.
                            • bazB Offline
                              baz
                              @pilou said:
                              @ Caul
                              Measured with ?
                              A piece of string Pilou, sorry I cant recheck it, the job is done and dusted.
                              • bazB Offline
                                baz
                                @mac1 said:
                                Attched is pic of ellipse drawn by the means of supplemental chords with no scaling. I included different seg counts just to show what can be done. If there is interest I'll redo with more care.
                                Su reports length of 48.364" for size shown. (1228.4456mm)
                                Oops see one dimension got cropped it is 10"[attachment=0:cf3intzr]<!-- ia0 -->conjuate ellipse.jpg<!-- ia0 -->[/attachment:cf3intzr]
                                Curious to see how you do it Mac. (Tho' the curve on the minor axis is a bit pointy n'est pas?)
                                  CAUL
                                  The code below constructs an ellipse in a group centered at origo where all edges have the exact same length. Since the script only computes a quarter ellipse the final full ellipse has an edge count divisible by 4. There's a "user interface" at the end to set major, minor and edge count. The circumference converges to the correct value with increased edgecount.
                                  To run it, just paste the code into the ruby console and press enter.
                                  module CAUL_RegularEllipse
                                    #hack found on the internets. Very accurate...
                                      a = major / 2.0
                                      b = minor / 2.0
                                      d = b / a
                                      x0 = d**0.5
                                      x1 = d
                                      x2 = d**1.5
                                      x3 = d**2
                                      x4 = d**2.5
                                      return c
                                    #find the intersection between a positive half ellipse at (0, 0) and a
                                    #positive half circle at (h, k) with radius r in the first quadrant.
                                    def self.circle_ellipse_intersect(a, b, h, k, r, c)
                                      #start point must be chosen with care so we don't end up outside the domain
                                      x = h - c * r
                                      epsilon = 0.000000000000001
                                      f_e = f_c = 0
                                      (0..15).each { |i|
                                        f_e_sqr = 4 * (a*a * b*b) * (a*a - x*x)
                                        f_c_sqr = 2 * h * x + r*r - x*x - h*h
                                        df_e_sqr = a*a * b*b * (a*a - x*x)
                                        df_c_sqr = r*r + 2 * h * x - x*x - h*h
                                        return nil if f_e_sqr < 0 || f_c_sqr < 0 || df_e_sqr < 0 || df_c_sqr < 0
                                        f_e  = Math;;sqrt(f_e_sqr) / (2 * a*a)
                                        f_c =  Math;;sqrt(f_c_sqr) + k
                                        df_e = -(b*b * x) / Math;;sqrt(df_e_sqr)
                                        df_c = (h - x) / Math;;sqrt(df_c_sqr)
                                        break if (f_e - f_c).abs <= epsilon
                                        x = x - (f_e - f_c) / (df_e - df_c)
                                      return [x, f_e]
                                    #given a positive x-value, return the point on the ellipse in the first qudrant
                                    def self.get_ellipse_point(major, minor, x)
                                      a = major / 2.0
                                      b = minor / 2.0
                                      return Geom;;Point3d.new(x, f_e, 0)
                                    #return how close the ellipse gets to the endpoint at ex with #bits segments
                                    #of length len.
                                    def self.test_ellipse(len, q_bits, major, minor, ex)
                                      a = major / 2.0;
                                      b = minor / 2.0;
                                      d = count = 0
                                      coff = [0.99999999, 0.00000001, 0.5]
                                      p0 = Geom;;Point3d.new(a, 0, 0)
                                      pe = get_ellipse_point(major, minor, ex)
                                      (0..q_bits - 2).each { |i|
                                        arr = nil
                                        coff.each { |c|
                                          arr = circle_ellipse_intersect(a, b, p0.x, p0.y, len, c)
                                          break if arr != nil
                                        return nil, nil if arr == nil
                                        p0.x = arr[0]
                                        p0.y = arr[1]
                                        d = pe.distance(p0)
                                        count += 1
                                        break if d < len
                                      return d, count
                                    #given an ellipse and the number of segments (q_bits) covering a quarter of the ellipse,
                                    #compute the length of a segment.
                                    def self.get_segment_length(major, minor, q_bits, ex)
                                      c = circumference(major, minor)
                                      #len is guaranteed to be a close over estimation
                                      len = (c / 4.0) / q_bits
                                      #regress towards the root by adjusting len downwards. Very rapid convergence..
                                      (0..10).each { |i|
                                        d, count =  test_ellipse(len, q_bits, major, minor, ex)
                                        over = (len - d) + (q_bits - 1 - count) * d
                                        len -= over / q_bits
                                      return len
                                    def self.get_quarter_ellipse(major, minor, q_bits, len)
                                      a = major / 2.0;
                                      b = minor / 2.0;
                                      d = count = 0
                                      ps = [p0]
                                      pe = Geom;;Point3d.new(0, b, 0)
                                        arr = nil
                                        coff.each { |c|
                                          break if arr != nil
                                        p1 = Geom;;Point3d.new(arr[0], arr[1], 0)
                                        ps << p1
                                        p0 = p1
                                      ps << pe
                                      return ps
                                    def self.get_ellipse(major, minor, q_bits, len)
                                      ps = get_quarter_ellipse(major, minor, q_bits, len)
                                      ##add the other three quadrants
                                      len = ps.length
                                      (0..len - 2).each { |i| ps << Geom;;Point3d.new(-ps[len - 2 - i].x, ps[len - 2 - i].y, 0) }
                                      len = ps.length
                                      (0..len - 2).each { |i| ps << Geom;;Point3d.new(ps[len - 2 - i].x, -ps[len - 2 - i].y, 0) }
                                      ps.delete_at(ps.length - 1)
                                      return ps
                                    ######### MAIN #########
                                    def self.main
                                      mod = Sketchup.active_model
                                      ent = mod.entities
                                      sel = mod.selection
                                      ###### USER INTERFACE ####
                                      major = 900.mm
                                      minor = 400.mm
                                      q_bits = 100 #number of segments in a quarter ellipse (-> full ellipse has q_bits * 4 segments)
                                      len = get_segment_length(major, minor, q_bits, 0)
                                      ps = get_ellipse(major, minor, q_bits, len)
                                      ### ADD THE ELLIPSE ##
                                      ng = ent.add_group
                                      (0..ps.length - 1).each { |i| ng.entities.add_line ps[i], ps[(i+1) % ps.length] }
                                      puts 'done'
                                    main
                                  • bazB Offline
                                    baz
                                    A L. Great, that will be very useful in the future. Thanks.
                                    Ps: 2118mm again, How long was my piece of string?
                                    • BoxB Offline
                                      Use elastic next time Baz then you can get several measurements in one.
                                      • bazB Offline
                                        baz
                                        Which was exactly where I came in...
                                        ... everybody chill, it's solved in at least four or five ways, go back to your lives!
                                        Thank you all for all your obsessive help. β˜€
                                        Baz
                                        PS: It's still a bug. πŸ˜›
                                          At the maximum display precision of SU with Caul program
                                          2118.238356
                                          Nurbs Prog 2118,2799 332 against your theoric 2118.2799 288074484
                                          For Baz πŸ˜‰
                                          http://i2.cdscdn.com/pdt2/4/1/0/1/700x700/auc3760180275410/rw/loom-bands-sachet-300-elastiques.jpg
                                            mac1
                                            conjuate ellipse.skpBaz: as noted the model was just proof of concept so not worried about segments yet. the 10X5 (semi) " better model reports 24.227n inches for 1/2 , has only 72 edges and looks very nice.
                                            Some way the number I posted above is not correct so forget about running you calculation. BTW that brings up a question. There are several eliptic intergals and the corresponding polynominal curve fits to those. Do you know which type your equation is for.
                                            • 2 / 3
