    [Solved]DC Dialog troubles....
    22 Posts 5 Posters 3.4k Views 5 Watching
    • BoxB
      Not meaning to have a go Rich but that could be written up as a classic example of how Not to ask a question.
        it's every dynamic component I open. whether from the 3DW or if I try make a cube a DC.
        Dialog loads with errors 😞
          πŸ‘
          • BoxB
            Not a lot to go on. So no clues from me. I can open and create happily therefore your system must be at least infinitesimally different to mine.
            Could it be somehow Java or web related. It seems often web talking things are either not up to date, insecure or just plain blocking these days.
              Works in 2015 though. must be a clash or something...
              back to 2015 for me.
                driven
                Rich, trash all the su_ rubies and folders in plugins folder and restart SU...
                it will update any that are 'corrupt'...
                  Will do. Thanks John.
                  Sent from my iPhone using Tapatalk
                    sorted. corrupt su_dc file
                    • pmolsonP
                      pmolson
                      Rich,
                      I am experiencing exact problem you described.
                      Will you please explain exactly what you did to locate, remove, and replace the corrupt dc file?
                      Thanks.
                        driven
                        Paul,
                        either remove it from the Plugins folder or go to the Extension Warehouse >> click on your user Name >> My Extensions >> Dynamic Components >> Uninstall...
                        Then Install it again...
                        the freshest versions are stored there...
                        • pmolsonP
                          pmolson
                          • pmolsonP
                            pmolson
                            @driven said:
                            Paul,
                            I did the above, and I am still getting the error message.(no entity data returned)
                            I tried uninstalling and reinstalling dynamic component and when that did not work I tried physically removing the dynamic components folder and rb file from the plug in folder located in this location
                            C:\Users\user\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins
                            Is there another location I should be looking in to remove the files?
                              Did you remove the su_* .rb file and the matching su_* subfolder from the ../Plugins folder ?
                              When SketchUp restarts new copies should be copied from the ../ShippedExtensions subfolder.
                              If that fails... then try deleting the su* files / subfolder in ../Plugins - then reinstalling SketchUp from its installer [ remember to 'run as administrator' in the right-click context-menu ]
                              If you have the properly installed latest su_* files then it should work !
                                driven
                                when you go to the Extension Warehouse and log in, hover on your User Name then click 'My Extensions'...
                                Dynamic Components will either be listed as UpDate Available, Disabled or Enabled...
                                if it not in the list something is wrong and you need to instal it from there...
                                • pmolsonP
                                  pmolson
                                  Yes i removed them from this location
                                  If that fails... then try deleting the su* files / subfolder in ../Plugins - then reinstalling SketchUp from its installer [ remember to 'run as administrator' in the right-click context-menu ]"
                                  I will try this
                                  • pmolsonP
                                    pmolson
                                    **It is on the list as installed, after I uninstalled and reinstalled.
                                    Going to try Tig's suggestion now.**
                                      driven
                                      did you try a different DC?
                                      any from the Components Browser will confirm if it's the Extension or the DC that's failing...
                                      • pmolsonP
                                        pmolson
                                        I have tried it on many DCs. Known good components that I have no issues with on my other installation.
                                        Tig, I have tried as you suggested and removed the folder and rb file from the plug in folder and then re installed the dynamic component plugin from the my extensions.
                                        I must be doing something wrong. Is there more than one location for the plug ins folder to reside...am i maybe not working in the correct location on my computer?
                                        this is where I am locating the plugins folder.
                                        C:\Users\Paul\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins
                                        This is where I am seeing the shippedextensions folder
                                        C:\Program Files\SketchUp\SketchUp 2016\ShippedExtensions
                                        I even tried copying the contents of the dynamic components folder and the rb file from the shipped extensions folder on my computer in which everything is working normal and replaced the like files on the lap top where it is not working.
                                        What am I doing wrong?
                                        Sorry I am an idiot...not as sorry as my wife, but that is another story.
                                        I have now completely uninstalled sketchup 2016 and re installed it with the latest download available and I still get the "no data" message followed by the "callback" message.
                                        I am stuck. Good thing I have two machines and one is working, or I wouldn't be...working that is.
                                        • pmolsonP
                                          pmolson
                                          Fixed!
                                          Just uninstalling and reinstalling sketchup did not work, but uninstalling through windows 10 programs and features followed by manually deleting every folder related to sketchup i could find did work.
                                          Now my laptop installation works again so I am free to fly about the country.
                                          Thanks.
                                            driven
                                            good to here...
