    Any suggestions? Making a basin with Curviloft...
    20 Posts 7 Posters 3.0k Views 7 Watching
    • utilerU Offline
      utiler
      @Rich, where do I find SubD??
      Just Curious...
        Use Artisan Andrew. SubD ain't out ....yet
        Should do the same job.
        • utilerU Offline
          utiler
          Cheers,
          Just Curious...
          • ccaponigroC Offline
            ccaponigro
            Y'all are making me feel stupid.
            cfcaia.com
            • utilerU Offline
              utiler
              Thanks guys, think I've got the knack of it now. Here's the end result.
              Really needed to model it accurately [overalls at least] for dimensioning later.
              Looking forward to SubD comes out though; looks really neat!
              Just Curious...
                kaas
                @utiler said:
                ..kaas, Not sure what you mean by this? Can you explain?
                As often, my comment was a bit too short. I meant to say that you have to pick the contours in the right order or your shape will be messed up (see pic).
                Also, this lofting technique could be used as well for roads for instance. I tend to use quads for the shape type for more easy texturing with the Quad tools (also see pic, I added a small segment of the dialog to the original pic).
                I had a quick(!) go at the sink. To really get the results you desire you have to play a bit with the amount of segments in the contours, the position of the contours and the individual curviloft settings.
                edit: I just noticed that using offset on some of the contours made a few vertices go just over the mirror plane. Something to be aware of.
                IdealStandard-ActiveVessel.skp
                • utilerU Offline
                  utiler
                  Thanks mate, understand now!!
                  Just Curious...
                  • oceanembersO Offline
                    oceanembers
                    Rich, what was the plugin you used to model that sink? With the maya/max/blender/etc. style manipulator? I feel like I'm missing out on a massively useful tool here...
                    • utilerU Offline
                      utiler
                      George it's called SubD, by Thomthom. Not out yet apparently but will be a real winner by the looks of it!!
                      Just Curious...
                        I used Vertex Tools for the modelling and SubD for the organic form at the end.
                        Sent from my iPhone using Tapatalk
