    [Plugin] Smooth Zoom 2.1.0 - 24 October 2021
    76 Posts 31 Posters 98.6k Views 30 Watching
      Anton_S
      Thanks Rich 😄
      I made an update to work with SU 64bit. Note that it requires AMS Library. There are still feature requests to add and bugs to fix, such as making it work properly while Fredo tools are active. Maybe someday...
      • B
        bharralure
        Bonjour Anton
        Smooth Zoom v1.1.0 installĂ© sur SU Make v15.3.331 64 bits, sous Windows 8.1 fonctionne parfaitement en mode camera rĂ©glĂ© sur "Perspective" ou sur "Perspective Ă  deux points", mais ne semble pas fonctionner correctement si mode camera rĂ©glĂ© sur "Projection parallĂšle" : la molette de la souris provoque un dĂ©placement latĂ©ral de la vue, et non un zoom. Mis peut-ĂȘtre est ce normal ?
        • B
          bharralure
          Bonjour Anton
          Smooth Zom v1.1.0 installé sur SU Make v15.3.331 64 bits sous Windws 8.1 fonctionne parfaitement en mode "Camera" réglé sur "Perspective" et sur "Perspective à deux points"
          Par contre, il me semble ne pas fonctionner correctement en mode "Camera" rĂ©glĂ©e sur "Projection parallĂšle": la molette de la souris provoque un dĂ©placement latĂ©ral de la vue de gauche et de droite, et non un zoom. Mais peut-ĂȘtre est-ce normal?
            Anton_S
            Bonjoir, LANDRY Patric. That plugin with parallel projection is indeed pretty weird. I will look into this someday. Meanwhile, you can always disable smooth zoom when switching to parallel projection. Uncheck Plugins -> AMS Smooth Zoom -> Enable and you're good to go. Thanks for the report.
            • C
              cgarcia_arq
              This is an excellent plugin! I've been trying to control the wheel speed since the first time i worked with sketchup and FINALLY now i can. Thank you so much!!!
              i would like to propose a future feature: the ability to control the zoom-in and zoom-out parameters independently. It seems a have to scroll a little more when i zoom-out to get to the same place i was before zooming-in.
              • dereiD
                derei
                Just tested the plugin. I like the fact it makes the zoom smoother, but from what i could see, this plugin can't make the zooming factor smaller than sketchup's default, although it can increase the factor. Is fun to play with those inertial modes when the transition is sensibly longer.
                Few suggestions:
                -see if the zooming factor can be DECREASED, this would help in case of precision zooming needs.
                -please consider moving it in Camera Menu, because everybody is putting their plugin in Extensions, as there is no other place in SketchUp. And that menu becomes longer than some screens height...
                Good Luck.
                DESIGNER AND ARTIST DEREI.UK
                  Anton_S
                  Derei, if I understood you correctly, you want to reduce the zooming intensity, right? You can decrease the zoom factor by going to Plugins->AMS Smooth Zoom->Options and reducing intensity, to say, 0.1. Thanks for your feedback!
                  • dereiD
                    derei
                    Factor 0.1 from what i could see, actually makes the zooming intensity equal to "sketchup default". Higher values will make zooming faster (in bigger steps).
                    I was hoping to go under sketchup's default. To have a smoother zoom in terms of precision, not only visualization.
                      davecoopstl
                      Ever since the 12/5 update, Smooth Zoom causes errors when opening SketchUp 2015. See attached image.
                      The only way to prevent these errors is by disabling Smooth Zoom from loading. But then I can't activate it!
                      I'm using SU 2015. It worked fine, until the latest updated via the ExtensionStore 3.0.
                      Anyone else have this issue? Any suggestions?
                      Dave.
                        Anton_S
                        Hello davecoopstl, based on an error, it seems that you don't have AMS Library plugin installed or your AMS Library copy has some components missing. Try reinstalling AMS Library and AMS Smooth Zoom and see how it goes.
                          awadrummer
                          Hi Anton,
                          Is there any way you could update this to work with 2019?
                          Chris B.
                            Anton_S
                            Hi Chris,
                            I updated SmoothZoom for SU2019 compatibility.
                            Anton
                              awadrummer
                              @anton_s said:
                              Hi Chris,
                              Anton
                              Awesome! Thanks Anton!
                              • zooenZ
                                zooen
                                Merci Anton!
                                  SKEMTHESAGE
                                  are you planing on making a mac version? I think the accelerometer could be very useful and smooth with this plug in 😄
                                    Anton_S
                                    Mac OS X has a completely different API. I do not know if there is a way to hack into a Mac OS X SketchUp window to take control of the the mouse wheel input. That is sure possible with Windows API but probably not with Mac OS X API, Carbon or Cocoa.
                                    I know that zooming with laptop mouse pads already eliminates the bumpiness from zoom. Perhaps a better mouse wheel hardware is a solution.
                                      awadrummer
                                      Hi, I just upgraded from Sketchup 2019 to 2021 and noticed this plugin doesn't appear to work for the new version. Is there a chance that it will be updated to work with the new version of Sketchup? Is there an alternative? Thank you!
                                      • P
                                        pibuz
                                        Same here.
                                        It was working on 2020 but it isn't anymore on 2021..
                                        So sad!
                                        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                          Anton_S
                                          Announcing version 2. This one should not interfere with any tools. The way this works is it suppresses existing mouse wheel messages with deltas of 120 and in turn sends multiple subsequent mouse wheel messages with smaller deltas, yielding smoother transition effects. Let me know if this works, so that I can decide how to proceed with this. Options to adjust zoom intensity will be added soon. Thanks!
                                          By the way, this is still Windows only, for now (SU6-SU2021). I only tested this with SU2020 and SU2021 though. Also, AMS Library is not longer needed for this, so this is an independent plugin.
                                          • P
                                            pibuz
                                            Wonderful!!! Thanks Anton!
                                            • 2 / 4
