    [Plugin] Smooth Zoom 2.1.0 - 24 October 2021
    76 Posts 31 Posters 96.5k Views 30 Watching
    • dereiD Offline
      derei
      Just tested the plugin. I like the fact it makes the zoom smoother, but from what i could see, this plugin can't make the zooming factor smaller than sketchup's default, although it can increase the factor. Is fun to play with those inertial modes when the transition is sensibly longer.
      Few suggestions:
      -see if the zooming factor can be DECREASED, this would help in case of precision zooming needs.
      -please consider moving it in Camera Menu, because everybody is putting their plugin in Extensions, as there is no other place in SketchUp. And that menu becomes longer than some screens height...
      Good Luck.
      DESIGNER AND ARTIST DEREI.UK
        Anton_S
        Derei, if I understood you correctly, you want to reduce the zooming intensity, right? You can decrease the zoom factor by going to Plugins->AMS Smooth Zoom->Options and reducing intensity, to say, 0.1. Thanks for your feedback!
        • dereiD Offline
          derei
          Factor 0.1 from what i could see, actually makes the zooming intensity equal to "sketchup default". Higher values will make zooming faster (in bigger steps).
          I was hoping to go under sketchup's default. To have a smoother zoom in terms of precision, not only visualization.
            davecoopstl
            Ever since the 12/5 update, Smooth Zoom causes errors when opening SketchUp 2015. See attached image.
            The only way to prevent these errors is by disabling Smooth Zoom from loading. But then I can't activate it!
            I'm using SU 2015. It worked fine, until the latest updated via the ExtensionStore 3.0.
            Anyone else have this issue? Any suggestions?
            Dave.
              Anton_S
              Hello davecoopstl, based on an error, it seems that you don't have AMS Library plugin installed or your AMS Library copy has some components missing. Try reinstalling AMS Library and AMS Smooth Zoom and see how it goes.
                awadrummer
                Hi Anton,
                Is there any way you could update this to work with 2019?
                Chris B.
                  Anton_S
                  Hi Chris,
                  I updated SmoothZoom for SU2019 compatibility.
                  Anton
                    awadrummer
                    @anton_s said:
                    Hi Chris,
                    Anton
                    Awesome! Thanks Anton!
                    • zooenZ Offline
                      zooen
                      Merci Anton!
                        SKEMTHESAGE
                        are you planing on making a mac version? I think the accelerometer could be very useful and smooth with this plug in 😄
                          Anton_S
                          Mac OS X has a completely different API. I do not know if there is a way to hack into a Mac OS X SketchUp window to take control of the the mouse wheel input. That is sure possible with Windows API but probably not with Mac OS X API, Carbon or Cocoa.
                          I know that zooming with laptop mouse pads already eliminates the bumpiness from zoom. Perhaps a better mouse wheel hardware is a solution.
                            awadrummer
                            Hi, I just upgraded from Sketchup 2019 to 2021 and noticed this plugin doesn't appear to work for the new version. Is there a chance that it will be updated to work with the new version of Sketchup? Is there an alternative? Thank you!
                              pibuz
                              Same here.
                              It was working on 2020 but it isn't anymore on 2021..
                              So sad!
                              WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                Anton_S
                                Announcing version 2. This one should not interfere with any tools. The way this works is it suppresses existing mouse wheel messages with deltas of 120 and in turn sends multiple subsequent mouse wheel messages with smaller deltas, yielding smoother transition effects. Let me know if this works, so that I can decide how to proceed with this. Options to adjust zoom intensity will be added soon. Thanks!
                                By the way, this is still Windows only, for now (SU6-SU2021). I only tested this with SU2020 and SU2021 though. Also, AMS Library is not longer needed for this, so this is an independent plugin.
                                  pibuz
                                  Wonderful!!! Thanks Anton!
                                    AISmebel
                                    Hello. Thank you very much for the useful plugin. It is very convenient.
                                    After the update, the option menu disappeared. Please return it to adjust the speed. Thank you very much! 👍
                                      awadrummer
                                      Hey Anton, thank you so much for the update! For me personally I utilize this plugin in order prevent having to scroll a lot to get in and out of my models. I'm not necessarily particular about how smooth the zooming is. I just do a lot of large scale models, mainly floor plans for schools and office buildings and to get in and change a wall I have to scroll in a lot. I got around it temporarily by changing my Logitech mouse to treat one scroll wheel movement as 3 which was ok except when I had to use the save or open dialog box to scroll through files lol.
                                      Again thank you so much for continuing to offer this capability. I can't wait until you add back the dialog to set the scroll distance as this helps so much.
                                        gisello
                                        how to regulate the smoothnes sof the zoom in SketchUp 2020 - 21 ?
                                        option command are not available
                                          Anton_S
                                          Announcing 2.1. This version allows adjusting single-notch duration and frequency.
                                          • X Offline
                                            xyhcwu
                                            Thank you very much for sharing 👍
                                            • 2 / 4
