    [Plugin] Smooth Zoom 2.1.0 - 24 October 2021
    76 Posts 31 Posters 94.5k Views 30 Watching
      Anton_S
      Ugh, I forgot about this plug... Will update once get home.
      • BerserkB Offline
        Berserk
        Very nice idea! And it will be better if add scrolling speed dependence.
          leetran72
          When will you fix it for x64 T.T
            Anton_S
            Making an update is a piece of cake. I just wanted to include all the feature requests and fix bugs before uploading, but upon your request I'll upload 64bit version shortly.
              Thanks Anton.
              Your tools are always killer!
                Anton_S
                Thanks Rich 😄
                I made an update to work with SU 64bit. Note that it requires AMS Library. There are still feature requests to add and bugs to fix, such as making it work properly while Fredo tools are active. Maybe someday...
                  bharralure
                  Bonjour Anton
                  Smooth Zoom v1.1.0 installĂ© sur SU Make v15.3.331 64 bits, sous Windows 8.1 fonctionne parfaitement en mode camera rĂ©glĂ© sur "Perspective" ou sur "Perspective Ă  deux points", mais ne semble pas fonctionner correctement si mode camera rĂ©glĂ© sur "Projection parallĂšle" : la molette de la souris provoque un dĂ©placement latĂ©ral de la vue, et non un zoom. Mis peut-ĂȘtre est ce normal ?
                    bharralure
                    Bonjour Anton
                    Smooth Zom v1.1.0 installé sur SU Make v15.3.331 64 bits sous Windws 8.1 fonctionne parfaitement en mode "Camera" réglé sur "Perspective" et sur "Perspective à deux points"
                    Par contre, il me semble ne pas fonctionner correctement en mode "Camera" rĂ©glĂ©e sur "Projection parallĂšle": la molette de la souris provoque un dĂ©placement latĂ©ral de la vue de gauche et de droite, et non un zoom. Mais peut-ĂȘtre est-ce normal?
                      Anton_S
                      Bonjoir, LANDRY Patric. That plugin with parallel projection is indeed pretty weird. I will look into this someday. Meanwhile, you can always disable smooth zoom when switching to parallel projection. Uncheck Plugins -> AMS Smooth Zoom -> Enable and you're good to go. Thanks for the report.
                        cgarcia_arq
                        This is an excellent plugin! I've been trying to control the wheel speed since the first time i worked with sketchup and FINALLY now i can. Thank you so much!!!
                        i would like to propose a future feature: the ability to control the zoom-in and zoom-out parameters independently. It seems a have to scroll a little more when i zoom-out to get to the same place i was before zooming-in.
                        • dereiD Offline
                          derei
                          Just tested the plugin. I like the fact it makes the zoom smoother, but from what i could see, this plugin can't make the zooming factor smaller than sketchup's default, although it can increase the factor. Is fun to play with those inertial modes when the transition is sensibly longer.
                          Few suggestions:
                          -see if the zooming factor can be DECREASED, this would help in case of precision zooming needs.
                          -please consider moving it in Camera Menu, because everybody is putting their plugin in Extensions, as there is no other place in SketchUp. And that menu becomes longer than some screens height...
                          Good Luck.
                            Anton_S
                            Derei, if I understood you correctly, you want to reduce the zooming intensity, right? You can decrease the zoom factor by going to Plugins->AMS Smooth Zoom->Options and reducing intensity, to say, 0.1. Thanks for your feedback!
                            • dereiD Offline
                              derei
                              Factor 0.1 from what i could see, actually makes the zooming intensity equal to "sketchup default". Higher values will make zooming faster (in bigger steps).
                              I was hoping to go under sketchup's default. To have a smoother zoom in terms of precision, not only visualization.
                                davecoopstl
                                Ever since the 12/5 update, Smooth Zoom causes errors when opening SketchUp 2015. See attached image.
                                The only way to prevent these errors is by disabling Smooth Zoom from loading. But then I can't activate it!
                                I'm using SU 2015. It worked fine, until the latest updated via the ExtensionStore 3.0.
                                Anyone else have this issue? Any suggestions?
                                Dave.
                                  Anton_S
                                  Hello davecoopstl, based on an error, it seems that you don't have AMS Library plugin installed or your AMS Library copy has some components missing. Try reinstalling AMS Library and AMS Smooth Zoom and see how it goes.
                                    awadrummer
                                    Hi Anton,
                                    Is there any way you could update this to work with 2019?
                                    Chris B.
                                      Anton_S
                                      Hi Chris,
                                      I updated SmoothZoom for SU2019 compatibility.
                                      Anton
                                        awadrummer
                                        @anton_s said:
                                        Hi Chris,
                                        Anton
                                        Awesome! Thanks Anton!
                                        • zooenZ Offline
                                          zooen
                                          Merci Anton!
                                            SKEMTHESAGE
                                            are you planing on making a mac version? I think the accelerometer could be very useful and smooth with this plug in 😄
                                            • 2 / 4
