    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 202.0k Views 109 Watching
    • dereiD Offline
      derei
      Great plugin ! Just started to use it. Please, please add Twilight Render support to it.
      And second, automatic start with A LOT of layers crashes sketchup. Worth investigate.
      Keep up the good work!
      EDIT:
      -too bad it doesn't have a sorting function by column (name, state).
      Please continue developing it. It is a really good plugin (and I would pay for it, if that is the condition for you to continue development). Or at least, if you are not willing to, maybe someone else would take it to continue, if you will agree on that. Is so bad that an advanced layers manager goes to die. πŸ‘
      EDIT2:
      -In SU 2015, "Highlight Selection's Layer" doesn't seem to work.
      DESIGNER AND ARTIST DEREI.UK
      • ashscottA Offline
        ashscott
        Have been waiting to try this plugin out for some time and just taking it for a first run in conjunction with Layout - really impressed
        Just some stuff I do with Sketchup.
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          The source is on GitHub, anyone can fork the project and push updates. I'd be glad to release them.
          GitHub - thomas-hauchecorne/Layers-Panel
          Contribute to thomas-hauchecorne/Layers-Panel development by creating an account on GitHub.
          GitHub (github.com)
          • dereiD Offline
            derei
            I have a suspicion that Layers Panel is messing up with Scene settings. It won't keep the hidden/visible layers as set and something (couldn't figure what) makes certain scenes (the activated one) to update with the setting on that particular moment.
            Eg: - i set some hidden/visible layers to a scene, then I update it. If I change something after that (add layer, hide layers, show more layers, etc), I will end up with a messed-up scene that won't keep the settings that i did to it in the first time.
            This just renders the plugin mostly unusable.
            Did this happened to others?
            • ashscottA Offline
              ashscott
              Have just dealt with this exact issue although I wouldn't say that it renders the plugin unuseable.
              I simply scan through the scenes (50+ in current model) selecting/deselcting appropriate layers and updating the scenes as I go - takes a few minutes to overcome
              • ashscottA Offline
                ashscott
                You've done a pretty impressive job IMO
                  jiminy-billy-bob
                  The ruby-side of the whole layers system is just a mess. It's really difficult, if not impossible, to keep track of everything. What the user does, what he expects to happen, what Layers Panel should do, and how. Some stuff is not even possible, for other stuff I had to use really dirty workaround.
                  You just ran into one of these. Nothing in the ruby API is planned to keep track of when a scene is updated.
                  I'm aware of this issue, but I never found a better way to do it.
                  I know Layers Panel has problems, but the reason why I stopped pushing it forward is because the ruby API is not meant for this.
                  Frankly, if I knew in what I was diving into, I probably would never have started this project.
                  And that's why working on Skatter is so rewarding : It's a whole new tool, it's not built on some existing Sketchup system, I don't have to keep track of user actions outside the tool, etc. So it's much more stable and easy to develop.
                  EDIT : You can see the original strugle on this : http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=54473
                    simoncbevans
                    I would like to use this plugin but it tells me I have the wrong SU version (SU 2015). Is there anything I can do to make it like my version?
                    Simon
                      jiminy-billy-bob
                      Layers panel is not maintained anymore.
                      It is now open-source, anyone can contribute and update it, or even make it better and sell it if you want.
                      Here is the repo : https://github.com/jiminy-billy-bob/Layers-Panel
                      As a result, I'm not responding to bug or feature requests anymore. You can still post them, in case another developer might want to fix/add them.
                      • JQLJ Offline
                        JQL
                        You have to go to settings and untick the "update active scene" button.
                        Actually if you go to the first posts on the topic you'll see it was a feature that Jiminy fixed and removed, but I complained that it was very handy so we could adjust scenes layers...
                        www.casca.pt
                        Visit us on facebook!
                        • E Offline
                          ExpertBeater
                          Thank you jiminy-billy-bob for this genius plug-in, i wonder if there is possibilty to add mitsuba renderer engine to existing render engines
                            akeo563
                            sorry Im new in sketch up . I have a question ,when i install Layers Panel 1.2.1 in sketch up 2016 and got problem like this it not show true panel how to solve it ,Please help me
                            • EdsonE Offline
                              Edson
                              I have always used Layers Panel without much trouble. Until now. Perhaps it has to do with some incompatibility to SU 2016. the fact is: icannot seem to get the main panel to appear on my screen. the layer states panel shows up but the main one does not. I have reinstalled it twice but the behavior is the same.
                              any ideas? thanks.
                              http://www.mahfuz.arq.br
                              • jujuJ Offline
                                juju
                                any ideas? thanks.
                                It looks like it is something local to your machine, working here. (Win 8.1, SU 2016 x64)
                                have you had more monitors connected recently?
                                • EdsonE Offline
                                  Edson
                                  hi juju,
                                  no, the setup is the same as before. but I am on mac so the fact that it is working for you does not mean much in this case.
                                  thanks.
                                  • Rubber DuckyR Offline
                                    Rubber Ducky
                                    I am also having this problem and am also on a Mac. The main panel simply will not show on my computer screen. This plugin worked well for several months before the main panel disappeared. I have also uninstalled and reinstalled the plugin. Near as I can tell, the panel "thinks" it is showing properly. The Mac version of Sketchup doesn't have any kind of "show all panels onscreen" sort of command.
                                    Layers Panel was a very useful plug-in while it worked. If anyone has a suggestion for fixing this problem, pleas post it.
                                    • EdsonE Offline
                                      Edson
                                      I am afraid our complaints will reach a dead end as the author of this extension is no longer developing nor mantaining it. pity. it showed great promise.
                                      perhaps someone would take it up and fix it.
                                        resmas
                                        Amazing plugin mate, great work.
                                        SU should implement it by default.
                                        I have a request, cna you add Octane Render support?
                                        I use Octane to render my work, and would be a charme if i had the Octane layer option.
                                        You can find more information in here.
                                        http://sketchucation.com/forums/viewtopic.php?f=81%26amp;t=58461
                                        cheers
                                        resmas
                                        all the best to you, and one mote time a big thanks πŸ˜‰
                                          art3mii
                                          Hello!
                                          When i push "R" on layer Panel, error: "Vray is not installed jn this system? or is disabled"
                                          what am I doing wrong?((
                                          SU pro2017 17.2.2555 64bit + V-Ray 3.60.03 Trial.
                                            jiminy-billy-bob
                                            Layers Panel is quite old, I don't think it works with V-Ray 3, sorry.
                                            • 11
                                            • 12
                                            • 13
                                            • 33
                                            • 34
                                            • 11 / 34
