    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 321.9k Views 110 Watching
    • E Offline
      ExpertBeater
      Thank you jiminy-billy-bob for this genius plug-in, i wonder if there is possibilty to add mitsuba renderer engine to existing render engines
        akeo563
        sorry Im new in sketch up . I have a question ,when i install Layers Panel 1.2.1 in sketch up 2016 and got problem like this it not show true panel how to solve it ,Please help me
        • EdsonE Offline
          Edson
          I have always used Layers Panel without much trouble. Until now. Perhaps it has to do with some incompatibility to SU 2016. the fact is: icannot seem to get the main panel to appear on my screen. the layer states panel shows up but the main one does not. I have reinstalled it twice but the behavior is the same.
          any ideas? thanks.
          http://www.mahfuz.arq.br
          • jujuJ Offline
            juju
            any ideas? thanks.
            It looks like it is something local to your machine, working here. (Win 8.1, SU 2016 x64)
            have you had more monitors connected recently?
            • EdsonE Offline
              Edson
              hi juju,
              no, the setup is the same as before. but I am on mac so the fact that it is working for you does not mean much in this case.
              thanks.
              • Rubber DuckyR Offline
                Rubber Ducky
                I am also having this problem and am also on a Mac. The main panel simply will not show on my computer screen. This plugin worked well for several months before the main panel disappeared. I have also uninstalled and reinstalled the plugin. Near as I can tell, the panel "thinks" it is showing properly. The Mac version of Sketchup doesn't have any kind of "show all panels onscreen" sort of command.
                Layers Panel was a very useful plug-in while it worked. If anyone has a suggestion for fixing this problem, pleas post it.
                • EdsonE Offline
                  Edson
                  I am afraid our complaints will reach a dead end as the author of this extension is no longer developing nor mantaining it. pity. it showed great promise.
                  perhaps someone would take it up and fix it.
                    resmas
                    Amazing plugin mate, great work.
                    SU should implement it by default.
                    I have a request, cna you add Octane Render support?
                    I use Octane to render my work, and would be a charme if i had the Octane layer option.
                    You can find more information in here.
                    404 Not Found
                    (sketchucation.com)
                    cheers
                    resmas
                    all the best to you, and one mote time a big thanks πŸ˜‰
                      art3mii
                      Hello!
                      When i push "R" on layer Panel, error: "Vray is not installed jn this system? or is disabled"
                      what am I doing wrong?((
                      SU pro2017 17.2.2555 64bit + V-Ray 3.60.03 Trial.
                      • jiminy-billy-bobJ Offline
                        jiminy-billy-bob
                        Layers Panel is quite old, I don't think it works with V-Ray 3, sorry.
                          RubenB
                          I know this is an old thread and no one has posted any changes to the open source code. Sure would be nice if someone would take up the task of updating this to SU 19 and adding support for line types. Sure heat to give up this tool but without line type support it's pretty much useless now, Quite the shame sense this layer manager is so much better than the SU layer tool
                            jiminy-billy-bob
                            There is a new plugin based on Layers Panel: https://extensions.sketchup.com/sv/content/layers-organizer
                              arquibaires
                              HOW CAN I ALPHABETICALLY ORDER THE LAYERS IN THE PLUGIN LAYERS PANEL?
                              THANKS
                                samodelkin_77
                                THANKS
                                you can find the link on page 1 ))
                                By the way, guru in Ruby, please tell me how to add a little code so that you can change the name of the layer by pressing F2 ?
                                ((Now it works by double-clicking, I'm more familiar with F2, and I can't substitute an addition and a check for F2 in the code in any way-it doesn't work out = little experience)
                                  PropertyToday
                                  Hello.
                                  I have some problem with layer panel plugin v 1.2.2 (Thomas Hauchecorne)
                                  Sometimes, all groups disappear and all layers appear in one row with no groups. Do you know this bug? Do you know how to deal with it. Is it possible to restore groups or do we have to build the entire group structure from the begining? Adam
                                  • X Offline
                                    xongchaksin
                                    Extension Errors Report
                                    SketchUp: 26.1.252
                                    OS: Windows 11
                                    Ruby: 3.2.2
                                    Extension: Layers Panel (1.2.2)
                                    Error: LoadError (cannot load such file -- Win32API)
                                    <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require'
                                    C:/Users/thana/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:21:in <module:JBB_LayersPanel>' C:/Users/thana/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:5:in <top (required)>'
                                    C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:197:in load'
                                    C:/Users/thana/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jbb_layers_panel.rb:51:in register_extension' C:/Users/thana/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jbb_layers_panel.rb:51:in module:JBB_LayersPanel'
                                    C:/Users/thana/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jbb_layers_panel.rb:35:in `<top (required)>'
                                    • 30
                                    • 31
                                    • 32
                                    • 33
                                    • 34
                                    • 34 / 34
