    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 368.9k Views 110 Watching
      siim11s
      @brooklynarch said:
      Hello,
      This is my favorite plug-in for organizing my model.
      But I am unable to get it to work in SU 2015 (Mac OS X Yosemite).
      I have tried loading and unloading it several times. The layers panel open for only a split second and then disappears...I've never had this problem before and don't know when it started. only the 'layer state' panel stays open...
      Can you tell me what I need to do to get this plugin to work properly?
      Is it compatible with my system?
      Do I need to delete older files?
      Thank you!
      Same problem - it worked before and I don't remember updating anything, might have installed a plugin or two though.
      SU 2015, OS X Yosemite.
      //S.
      • G
        greatoe
        Pity to hear that this plug-in is discontinued developing. Would like to pay for it. It really speed up the workflow a lot.
        • jiminy-billy-bobJ
          jiminy-billy-bob
          Sorry about that... But please understand that only few people are willing to pay for this, and not a lot of money.
          I am curently developping another plugin that I will sell, so I can't take much time for Layers Panel.
          I think LP is already pretty good as is. Although I will try my best to fix bugs.
          BrooklynArch, did you try what we discussed by email?
            siim11s
            @siim11s said:
            @brooklynarch said:
            Hello,
            Thank you!
            Uninstalled "CutList" plugin (inactivate did not help). LP now works again.
            //S.
            • dereiD
              derei
              Great plugin ! Just started to use it. Please, please add Twilight Render support to it.
              And second, automatic start with A LOT of layers crashes sketchup. Worth investigate.
              Keep up the good work!
              EDIT:
              -too bad it doesn't have a sorting function by column (name, state).
              Please continue developing it. It is a really good plugin (and I would pay for it, if that is the condition for you to continue development). Or at least, if you are not willing to, maybe someone else would take it to continue, if you will agree on that. Is so bad that an advanced layers manager goes to die. πŸ‘
              EDIT2:
              -In SU 2015, "Highlight Selection's Layer" doesn't seem to work.
              DESIGNER AND ARTIST DEREI.UK
              • ashscottA
                ashscott
                Have been waiting to try this plugin out for some time and just taking it for a first run in conjunction with Layout - really impressed
                Just some stuff I do with Sketchup.
                • jiminy-billy-bobJ
                  jiminy-billy-bob
                  The source is on GitHub, anyone can fork the project and push updates. I'd be glad to release them.
                  GitHub - thomas-hauchecorne/Layers-Panel
                  Contribute to thomas-hauchecorne/Layers-Panel development by creating an account on GitHub.
                  GitHub (github.com)
                  • dereiD
                    derei
                    I have a suspicion that Layers Panel is messing up with Scene settings. It won't keep the hidden/visible layers as set and something (couldn't figure what) makes certain scenes (the activated one) to update with the setting on that particular moment.
                    Eg: - i set some hidden/visible layers to a scene, then I update it. If I change something after that (add layer, hide layers, show more layers, etc), I will end up with a messed-up scene that won't keep the settings that i did to it in the first time.
                    This just renders the plugin mostly unusable.
                    Did this happened to others?
                    • ashscottA
                      ashscott
                      Have just dealt with this exact issue although I wouldn't say that it renders the plugin unuseable.
                      I simply scan through the scenes (50+ in current model) selecting/deselcting appropriate layers and updating the scenes as I go - takes a few minutes to overcome
                      • ashscottA
                        ashscott
                        You've done a pretty impressive job IMO
                        • jiminy-billy-bobJ
                          jiminy-billy-bob
                          The ruby-side of the whole layers system is just a mess. It's really difficult, if not impossible, to keep track of everything. What the user does, what he expects to happen, what Layers Panel should do, and how. Some stuff is not even possible, for other stuff I had to use really dirty workaround.
                          You just ran into one of these. Nothing in the ruby API is planned to keep track of when a scene is updated.
                          I'm aware of this issue, but I never found a better way to do it.
                          I know Layers Panel has problems, but the reason why I stopped pushing it forward is because the ruby API is not meant for this.
                          Frankly, if I knew in what I was diving into, I probably would never have started this project.
                          And that's why working on Skatter is so rewarding : It's a whole new tool, it's not built on some existing Sketchup system, I don't have to keep track of user actions outside the tool, etc. So it's much more stable and easy to develop.
                          EDIT : You can see the original strugle on this : http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=54473
                            simoncbevans
                            I would like to use this plugin but it tells me I have the wrong SU version (SU 2015). Is there anything I can do to make it like my version?
                            Simon
                            • jiminy-billy-bobJ
                              jiminy-billy-bob
                              Layers panel is not maintained anymore.
                              It is now open-source, anyone can contribute and update it, or even make it better and sell it if you want.
                              Here is the repo : https://github.com/jiminy-billy-bob/Layers-Panel
                              As a result, I'm not responding to bug or feature requests anymore. You can still post them, in case another developer might want to fix/add them.
                              • JQLJ
                                JQL
                                You have to go to settings and untick the "update active scene" button.
                                Actually if you go to the first posts on the topic you'll see it was a feature that Jiminy fixed and removed, but I complained that it was very handy so we could adjust scenes layers...
                                www.casca.pt
                                Visit us on facebook!
                                • E
                                  ExpertBeater
                                  Thank you jiminy-billy-bob for this genius plug-in, i wonder if there is possibilty to add mitsuba renderer engine to existing render engines
                                    akeo563
                                    sorry Im new in sketch up . I have a question ,when i install Layers Panel 1.2.1 in sketch up 2016 and got problem like this it not show true panel how to solve it ,Please help me
                                    • EdsonE
                                      Edson
                                      I have always used Layers Panel without much trouble. Until now. Perhaps it has to do with some incompatibility to SU 2016. the fact is: icannot seem to get the main panel to appear on my screen. the layer states panel shows up but the main one does not. I have reinstalled it twice but the behavior is the same.
                                      any ideas? thanks.
                                      http://www.mahfuz.arq.br
                                      • jujuJ
                                        juju
                                        any ideas? thanks.
                                        It looks like it is something local to your machine, working here. (Win 8.1, SU 2016 x64)
                                        have you had more monitors connected recently?
                                        • EdsonE
                                          Edson
                                          hi juju,
                                          no, the setup is the same as before. but I am on mac so the fact that it is working for you does not mean much in this case.
                                          thanks.
                                          • Rubber DuckyR
                                            Rubber Ducky
                                            I am also having this problem and am also on a Mac. The main panel simply will not show on my computer screen. This plugin worked well for several months before the main panel disappeared. I have also uninstalled and reinstalled the plugin. Near as I can tell, the panel "thinks" it is showing properly. The Mac version of Sketchup doesn't have any kind of "show all panels onscreen" sort of command.
                                            Layers Panel was a very useful plug-in while it worked. If anyone has a suggestion for fixing this problem, pleas post it.
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 33 / 34
