    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 316.1k Views 110 Watching
      simoncbevans
      I would like to use this plugin but it tells me I have the wrong SU version (SU 2015). Is there anything I can do to make it like my version?
      Simon
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Layers panel is not maintained anymore.
        It is now open-source, anyone can contribute and update it, or even make it better and sell it if you want.
        Here is the repo : https://github.com/jiminy-billy-bob/Layers-Panel
        As a result, I'm not responding to bug or feature requests anymore. You can still post them, in case another developer might want to fix/add them.
        • JQLJ Offline
          JQL
          @derei said:
          I have a suspicion that Layers Panel is messing up with Scene settings. It won't keep the hidden/visible layers as set and something (couldn't figure what) makes certain scenes (the activated one) to update with the setting on that particular moment.
          Eg: - i set some hidden/visible layers to a scene, then I update it. If I change something after that (add layer, hide layers, show more layers, etc), I will end up with a messed-up scene that won't keep the settings that i did to it in the first time.
          This just renders the plugin mostly unusable.
          Did this happened to others?
          You have to go to settings and untick the "update active scene" button.
          Actually if you go to the first posts on the topic you'll see it was a feature that Jiminy fixed and removed, but I complained that it was very handy so we could adjust scenes layers...
          www.casca.pt
          Visit us on facebook!
          • E Offline
            ExpertBeater
            Thank you jiminy-billy-bob for this genius plug-in, i wonder if there is possibilty to add mitsuba renderer engine to existing render engines
              akeo563
              sorry Im new in sketch up . I have a question ,when i install Layers Panel 1.2.1 in sketch up 2016 and got problem like this it not show true panel how to solve it ,Please help me
              • EdsonE Offline
                Edson
                I have always used Layers Panel without much trouble. Until now. Perhaps it has to do with some incompatibility to SU 2016. the fact is: icannot seem to get the main panel to appear on my screen. the layer states panel shows up but the main one does not. I have reinstalled it twice but the behavior is the same.
                any ideas? thanks.
                http://www.mahfuz.arq.br
                • jujuJ Offline
                  juju
                  any ideas? thanks.
                  It looks like it is something local to your machine, working here. (Win 8.1, SU 2016 x64)
                  have you had more monitors connected recently?
                  • EdsonE Offline
                    Edson
                    hi juju,
                    no, the setup is the same as before. but I am on mac so the fact that it is working for you does not mean much in this case.
                    thanks.
                    • Rubber DuckyR Offline
                      Rubber Ducky
                      I am also having this problem and am also on a Mac. The main panel simply will not show on my computer screen. This plugin worked well for several months before the main panel disappeared. I have also uninstalled and reinstalled the plugin. Near as I can tell, the panel "thinks" it is showing properly. The Mac version of Sketchup doesn't have any kind of "show all panels onscreen" sort of command.
                      Layers Panel was a very useful plug-in while it worked. If anyone has a suggestion for fixing this problem, pleas post it.
                      • EdsonE Offline
                        Edson
                        I am afraid our complaints will reach a dead end as the author of this extension is no longer developing nor mantaining it. pity. it showed great promise.
                        perhaps someone would take it up and fix it.
                          resmas
                          Amazing plugin mate, great work.
                          SU should implement it by default.
                          I have a request, cna you add Octane Render support?
                          I use Octane to render my work, and would be a charme if i had the Octane layer option.
                          You can find more information in here.
                          404 Not Found
                          (sketchucation.com)
                          cheers
                          resmas
                          all the best to you, and one mote time a big thanks πŸ˜‰
                            art3mii
                            Hello!
                            When i push "R" on layer Panel, error: "Vray is not installed jn this system? or is disabled"
                            what am I doing wrong?((
                            SU pro2017 17.2.2555 64bit + V-Ray 3.60.03 Trial.
                              jiminy-billy-bob
                              Layers Panel is quite old, I don't think it works with V-Ray 3, sorry.
                                RubenB
                                I know this is an old thread and no one has posted any changes to the open source code. Sure would be nice if someone would take up the task of updating this to SU 19 and adding support for line types. Sure heat to give up this tool but without line type support it's pretty much useless now, Quite the shame sense this layer manager is so much better than the SU layer tool
                                  jiminy-billy-bob
                                  There is a new plugin based on Layers Panel: https://extensions.sketchup.com/sv/content/layers-organizer
                                    arquibaires
                                    HOW CAN I ALPHABETICALLY ORDER THE LAYERS IN THE PLUGIN LAYERS PANEL?
                                    THANKS
                                      samodelkin_77
                                      THANKS
                                      you can find the link on page 1 ))
                                      By the way, guru in Ruby, please tell me how to add a little code so that you can change the name of the layer by pressing F2 ?
                                      ((Now it works by double-clicking, I'm more familiar with F2, and I can't substitute an addition and a check for F2 in the code in any way-it doesn't work out = little experience)
                                        PropertyToday
                                        Hello.
                                        I have some problem with layer panel plugin v 1.2.2 (Thomas Hauchecorne)
                                        Sometimes, all groups disappear and all layers appear in one row with no groups. Do you know this bug? Do you know how to deal with it. Is it possible to restore groups or do we have to build the entire group structure from the begining? Adam
                                        • X Offline
                                          xongchaksin
                                          Extension Errors Report
                                          SketchUp: 26.1.252
                                          OS: Windows 11
                                          Ruby: 3.2.2
                                          Extension: Layers Panel (1.2.2)
                                          Error: LoadError (cannot load such file -- Win32API)
                                          <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require'
                                          C:/Users/thana/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:21:in <module:JBB_LayersPanel>' C:/Users/thana/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:5:in <top (required)>'
                                          C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:197:in load'
                                          C:/Users/thana/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jbb_layers_panel.rb:51:in register_extension' C:/Users/thana/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jbb_layers_panel.rb:51:in module:JBB_LayersPanel'
                                          C:/Users/thana/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jbb_layers_panel.rb:35:in `<top (required)>'
                                          • 30
                                          • 31
                                          • 32
                                          • 33
                                          • 34
                                          • 34 / 34
