    [Plugin] Memory Copy (xformclone.rb)
    44 Posts 26 Posters 64.0k Views 26 Watching
      driven
      This is a very easy to use bit of kit, made the candy-stripe pole and used it for the animation as well.
      very,very nice
      thanks for posting....
      a quick(ish) play
      ???how do I add embedded youtube???
      • jason_marantoJ
        jason_maranto
        This is one of those functions I thought should be in Sketchup right from the beginning -- a really basic but totally useful function.
        I'm one of the folks who can't get the array part of this script to work... I'll take a look at the script and see if I can't get to the bottom of it , but does anyone already know why?
        Best,
        Jason.
        • plot-parisP
          plot-paris
          Jason, did you make sure to do everything in exactly the right order?
          for the array function to work you have to select the first component, then right click > 'play it again'. then type in something like 5x (make sure to type in an axtual 'x' and not a *). and then click the second component...
          I think this behavior could be optimized to better fit into the native SketchUp workflow, as I already explained in the third post of this page...
          I still hope, that at some point someone will hear my pleading and will perfect the script πŸ˜„
          • jason_marantoJ
            jason_maranto
            I did try that but I'll try it again, maybe I gave up on that avenue too quickly as it did not seem to make much sense to me in regards to Sketchups natural workflow...
            Best,
            Jason.
              adaycalledzero
              Are you sure you are working with components? Groups are not supported.
              • jason_marantoJ
                jason_maranto
                Yeah, I'm a moron -- it works fine, I just didn't get the procedure correct.
                Thanks for the help.
                Best,
                Jason.
                • dereiD
                  derei
                  I think the plugin should be on first post, also with changelog and updates (if any). It's easier to follow and if the topic gets large, the user doesn't have to crawl on all posts to find the download πŸ˜„
                  Thanks.
                  DESIGNER AND ARTIST DEREI.UK
                    Thanks.
                    Plugin Added πŸ‘
                      agamemnus
                      πŸ‘
                      • P
                        Pherim
                        Wow, cool plugin, I can't believe I never noticed it before and I'm surprised how old it already is... but it still works fine in SU2016. Though I can't get it to make multiple copies with a single click (using the tutorial on the first page of this thread) and I discovered that as soon as I change the camera position (zooming is fine) it starts again with the first component. Not big issues though and it's a very useful plugin!
                          JGA
                          I've having the same issues as Pherim in that I have to change the camera view & click the original component, not the copy. The other issue I have is that it copies in the opposite direction from the first one in SKUP 2015 - weird.
                          Great idea for a plugin though.
                          Regards,
                          JGA
                            sophie23
                            good for mac users also?
                            • P
                              paulchow
                              It is cool tools, but it can not run in Sketchup 2018, it said not support *.rb file
                              May I ask for update version for Memory copy in *.rbz format?
                              Thanks.
                                The latest version of this script is in RBZ format in the PluginStore:
                                https://sketchucation.com/pluginstore?pln=xformclone
                                Alternatively you can add any lone RB into your Plugins folder 'manually'...
                                It's called 'xformclone.rb' in this case.
                                Lone scripts like this are 'unsigned' and therefore newer versions of SketchUp must have their Extension Manager Loading policy set to Unrestricted.
                                Since it's an old script I am uncertain about its compatibility with newer versions...
                                  rv1974
                                  TIG, this tool has big problems with precision (rotation is OK, fails at moving)
                                  I tried your Grow.rb- works perfectly. So maybe it's possible to update this script inserting some portions of Grow.rb please? Thanks in advance.
                                  P.S. Please see attached: try to make >30 copies upward. The script just can't put components exactly on Cpoints
                                  iii.skp
                                  • K
                                    Kondybas
                                    The most indispensable plugin for my project. All other have alternatives but not that.
                                    • F
                                      FlorinAp
                                      There is another one from Eneroth, and i think maybe two more (one may be Tax Engineering, plus another one)
                                      • 2 / 3
