    [PLUGIN] Flowify v1.1.0 (updated 150327)
    126 Posts 57 Posters 211.3k Views 57 Watching
    • cottyC Offline
      cotty
      Another example from this topic...
      my SketchUp gallery
      • I Offline
        ivreich
        Hey, brilliant plugin!
        I can finally make complex lattice structures with the aid of Bezierspline and Curviloft...many possibilities for pseudo-parametric facades and forms as well (for the architects among us).
        One minor bug I've found - I'm not sure how to describe it in words but there are some geometries that go jagged when mapping to a steeply curved surface - have a look at these screenshots.
        The SketchUp file (I'm using SU Pro 2015) is too big to post here, but let me know of a way to send it to you if it helps...
        Cheers
        Joel
        Support group + array of components + target surface
        Some of the mapped geometry becomes jagged after Flowify :(
        What I'm trying to achieve...
        • W Offline
          word99899
          thank you for sharing , love it.
            RueM
            Hi, great plugin i'm just discovering !
            But I also just starting having some issues. I'm trying to build a quite complex staircase silt, with differents curves. As some plugins like "follow me and keep" plugins don't work very well for what i need, my last chance is to make flowify work.
            On the picture (0) is the profile and guide. On the picture (1) you can see that flowify is going crazy on the end. I don't know if I did something wrong, but i just followed the tutorials. If I try not to use the entire grid to avoid the crazy end, it appears that the result isn't really scaled (2)...
            Any idea of what is going wrong ?
            Thanks a lot
              RueM
              [see below]
                CAUL
                Not really. Could you please attach a skp file?
                  RueM
                  I found where it could came from. I did an other operation before and made a grid and the plane surface then. I didn't removed that grid, and it might not feet to the new operation (so flowify might calcules with false beginning and ending geometry).
                  I made an other plane rectangular with any grid and it worked perfectly.
                  We can still have the model to see what crasy results it mades.
                  Thanks a lot
                  issue and solution
                    Align Target surface by the middle from the Source surface avoid generally some problem for the 2 lines! πŸ€“
                    • cottyC Offline
                      cotty
                      Some spiral examples...
                      flowify_cotty_06.skp
                      my SketchUp gallery
                        capseyb
                        Thanks for this plugin.
                        I've been having a lot of trouble with errors with grid parsing, even with simple geometry. Would anyone be able to quickly diagnose what is wrong with the attached model?
                        Thanks again,
                        Brian
                        bend4.skp
                        • cottyC Offline
                          cotty
                          There were little edges or errors in your quad mesh, after repairing them, it worked like a charm...
                          bend4_cotty.skp
                          my SketchUp gallery
                            CAUL
                            Thanks cotty! I was just trying to find the error.
                            • yanrothwellY Offline
                              yanrothwell
                              I have a curved roof to make with some simple wedge shaped shingles. Each time I try to use Flowify to bed the shingles onto the 'roof' I get a strange result making the result, un-flowified and huge.
                              I am puzzled and presume I must be doing something wrong. I explode all the components and groups of the shingles so it is only what I believe to be raw geometry, then group it place it on the target quad mesh, click on Flowify.
                              Any ideas where I've messed up? (skp attached).
                              I'm using SU pro 2015
                              [Edit] Realised it's something to do with multiple objects, but I this seems to work in the Demo Video?
                              parts for Flowify shingles.skp
                              http://www.ianrothwell.co.uk
                                CAUL
                                Thank you for the file! It's a bug in Flowify and it seems to be in the intersection part of the extension, so you can still use**'Flowify without cut'**. Maybe that is enough?
                                Nevertheless, I'm looking into it.
                                  Volume to project can't be group of groups!
                                  So explode all many time and re-group !
                                  Surface Start must be a surface and not a volume!
                                  But there is also something wrong in your first original shingle!
                                  So redraw it!
                                  Another thing : center your target surface for avoid over crossing of the 2 lines toward the extremities!
                                  Edit : seems i move over a bug! πŸ’š
                                    Gama_Pro
                                    hi!!! i love this plugin, but i had a problem. It doesnt running in SK2016. Where can i get this plugin for SK2016?
                                    thks!!
                                      beecee660
                                      Hello,
                                      I am having problems shaping this perforated disc into the target dome. Keep getting this INPUT ERROR, screen grab attached.
                                      Can anyone help? Are domes not possible? I gave it a base square as I read flowify only works with quads.
                                      I successfully did it with a different shape yesterday I copied off a video tutorial.
                                      I would appreciate any advice.
                                      Many thanks.
                                        Why not publish your SKP file problem?
                                        It's difficult to say something about an image! πŸ˜„
                                        Maybe there are some overlapings...but without the file...
                                        • cottyC Offline
                                          cotty
                                          You can use the quadfacetools (Thomthom) to control the quads...
                                          my SketchUp gallery
                                          • cottyC Offline
                                            cotty
                                            Another example model...
                                            flowify_cotty_07.skp
                                            my SketchUp gallery
                                            • 3 / 7
