    [PLUGIN] Flowify v1.1.0 (updated 150327)
    126 Posts 57 Posters 218.1k Views 57 Watching
    • cottyC Offline
      cotty
      Inspired from Chippwalters very nice video (http://sketchucation.com/forums/viewtopic.php?f=18%26amp;t=62083#p568500) here a much simpler example...
      flowify_cotty_01.zip
      my SketchUp gallery
      • cottyC Offline
        cotty
        ... and after "Hide Overlapping Geometry" (thank you CAUL for this too again!)...
        my SketchUp gallery
        • cottyC Offline
          cotty
          Another example...
          flowify_cotty_02.zip
          my SketchUp gallery
          • panixiaP Offline
            panixia
            nice job cotty!
            • H Offline
              hagawaga
              I've tried some examples downloaded from here, but I always get the message:
              "INPUT ERROR: Not enough Input".
              Can somebody please help
              Thanks in advance
                CAUL
                You must have BOTH the support group and the source geometry selected before running Flowify. Below is a screen shot (from the example file) of what this looks like.
                • H Offline
                  hagawaga
                  Thank you CAUL, it works like a charm now. The plug is very useful.
                  Regards
                  haga
                  • F Offline
                    faust07
                    Absolutely brilliant. And Hide Overlapping Geometry Removal as well. Great time saving when rendering. Thank you!
                    • cottyC Offline
                      cotty
                      Another example from this topic...
                      my SketchUp gallery
                      • I Offline
                        ivreich
                        Hey, brilliant plugin!
                        I can finally make complex lattice structures with the aid of Bezierspline and Curviloft...many possibilities for pseudo-parametric facades and forms as well (for the architects among us).
                        One minor bug I've found - I'm not sure how to describe it in words but there are some geometries that go jagged when mapping to a steeply curved surface - have a look at these screenshots.
                        The SketchUp file (I'm using SU Pro 2015) is too big to post here, but let me know of a way to send it to you if it helps...
                        Cheers
                        Joel
                        Support group + array of components + target surface
                        Some of the mapped geometry becomes jagged after Flowify :(
                        What I'm trying to achieve...
                        • W Offline
                          word99899
                          thank you for sharing , love it.
                            RueM
                            Hi, great plugin i'm just discovering !
                            But I also just starting having some issues. I'm trying to build a quite complex staircase silt, with differents curves. As some plugins like "follow me and keep" plugins don't work very well for what i need, my last chance is to make flowify work.
                            On the picture (0) is the profile and guide. On the picture (1) you can see that flowify is going crazy on the end. I don't know if I did something wrong, but i just followed the tutorials. If I try not to use the entire grid to avoid the crazy end, it appears that the result isn't really scaled (2)...
                            Any idea of what is going wrong ?
                            Thanks a lot
                              RueM
                              [see below]
                                CAUL
                                Not really. Could you please attach a skp file?
                                  RueM
                                  I found where it could came from. I did an other operation before and made a grid and the plane surface then. I didn't removed that grid, and it might not feet to the new operation (so flowify might calcules with false beginning and ending geometry).
                                  I made an other plane rectangular with any grid and it worked perfectly.
                                  We can still have the model to see what crasy results it mades.
                                  Thanks a lot
                                  issue and solution
                                    Align Target surface by the middle from the Source surface avoid generally some problem for the 2 lines! ๐Ÿค“
                                    • cottyC Offline
                                      cotty
                                      Some spiral examples...
                                      flowify_cotty_06.skp
                                      my SketchUp gallery
                                        capseyb
                                        Thanks for this plugin.
                                        I've been having a lot of trouble with errors with grid parsing, even with simple geometry. Would anyone be able to quickly diagnose what is wrong with the attached model?
                                        Thanks again,
                                        Brian
                                        bend4.skp
                                        • cottyC Offline
                                          cotty
                                          There were little edges or errors in your quad mesh, after repairing them, it worked like a charm...
                                          bend4_cotty.skp
                                          my SketchUp gallery
                                            CAUL
                                            Thanks cotty! I was just trying to find the error.
                                            • 3 / 7
