    [PLUGIN] Flowify v1.1.0 (updated 150327)
    126 Posts 57 Posters 227.1k Views 57 Watching
    • cottyC
      cotty
      ... and after "Hide Overlapping Geometry" (thank you CAUL for this too again!)...
      my SketchUp gallery
      • cottyC
        cotty
        Another example...
        flowify_cotty_02.zip
        my SketchUp gallery
        • panixiaP
          panixia
          nice job cotty!
          • H
            hagawaga
            I've tried some examples downloaded from here, but I always get the message:
            "INPUT ERROR: Not enough Input".
            Can somebody please help
            Thanks in advance
            • C
              CAUL
              You must have BOTH the support group and the source geometry selected before running Flowify. Below is a screen shot (from the example file) of what this looks like.
              • H
                hagawaga
                Thank you CAUL, it works like a charm now. The plug is very useful.
                Regards
                haga
                • F
                  faust07
                  Absolutely brilliant. And Hide Overlapping Geometry Removal as well. Great time saving when rendering. Thank you!
                  • cottyC
                    cotty
                    Another example from this topic...
                    my SketchUp gallery
                    • I
                      ivreich
                      Hey, brilliant plugin!
                      I can finally make complex lattice structures with the aid of Bezierspline and Curviloft...many possibilities for pseudo-parametric facades and forms as well (for the architects among us).
                      One minor bug I've found - I'm not sure how to describe it in words but there are some geometries that go jagged when mapping to a steeply curved surface - have a look at these screenshots.
                      The SketchUp file (I'm using SU Pro 2015) is too big to post here, but let me know of a way to send it to you if it helps...
                      Cheers
                      Joel
                      Support group + array of components + target surface
                      Some of the mapped geometry becomes jagged after Flowify :(
                      What I'm trying to achieve...
                      • W
                        word99899
                        thank you for sharing , love it.
                          RueM
                          Hi, great plugin i'm just discovering !
                          But I also just starting having some issues. I'm trying to build a quite complex staircase silt, with differents curves. As some plugins like "follow me and keep" plugins don't work very well for what i need, my last chance is to make flowify work.
                          On the picture (0) is the profile and guide. On the picture (1) you can see that flowify is going crazy on the end. I don't know if I did something wrong, but i just followed the tutorials. If I try not to use the entire grid to avoid the crazy end, it appears that the result isn't really scaled (2)...
                          Any idea of what is going wrong ?
                          Thanks a lot
                            RueM
                            [see below]
                            • C
                              CAUL
                              Not really. Could you please attach a skp file?
                                RueM
                                I found where it could came from. I did an other operation before and made a grid and the plane surface then. I didn't removed that grid, and it might not feet to the new operation (so flowify might calcules with false beginning and ending geometry).
                                I made an other plane rectangular with any grid and it worked perfectly.
                                We can still have the model to see what crasy results it mades.
                                Thanks a lot
                                issue and solution
                                  Align Target surface by the middle from the Source surface avoid generally some problem for the 2 lines! ๐Ÿค“
                                  • cottyC
                                    cotty
                                    Some spiral examples...
                                    flowify_cotty_06.skp
                                    my SketchUp gallery
                                    • C
                                      capseyb
                                      Thanks for this plugin.
                                      I've been having a lot of trouble with errors with grid parsing, even with simple geometry. Would anyone be able to quickly diagnose what is wrong with the attached model?
                                      Thanks again,
                                      Brian
                                      bend4.skp
                                      • cottyC
                                        cotty
                                        There were little edges or errors in your quad mesh, after repairing them, it worked like a charm...
                                        bend4_cotty.skp
                                        my SketchUp gallery
                                        • C
                                          CAUL
                                          Thanks cotty! I was just trying to find the error.
                                          • yanrothwellY
                                            yanrothwell
                                            I have a curved roof to make with some simple wedge shaped shingles. Each time I try to use Flowify to bed the shingles onto the 'roof' I get a strange result making the result, un-flowified and huge.
                                            I am puzzled and presume I must be doing something wrong. I explode all the components and groups of the shingles so it is only what I believe to be raw geometry, then group it place it on the target quad mesh, click on Flowify.
                                            Any ideas where I've messed up? (skp attached).
                                            I'm using SU pro 2015
                                            [Edit] Realised it's something to do with multiple objects, but I this seems to work in the Demo Video?
                                            parts for Flowify shingles.skp
                                            http://www.ianrothwell.co.uk
                                            • 3 / 7
