[Plugin Library] LibFredo6 - v14.5b - 24 May 24
On a PC all of SketchUp's dialogs use Internet-Explorer.
On a MAC all of SketchUp's dialogs use Safari.
This usage is quite separate from whatever you use for your day-to-day browsing.Like everything else... the SketchUcation PluginStore uses those 'helper' applications for its dialogs...
So if you are on a MAC open Safari, then empty its cache...
Then restart SketchUp and see if that helps... -
Thanks TIG! Cleaned. No effect, the same bug
when that fails to make a difference you can trash the SU WebKit cache, because it not really Safari...
Drag this to Trash...
~/Library/Caches/com.sketchup.SketchUp.2015or whatever version of SU your running [your profile says v8???]
Thanks driven!
SU cache is trashed, SU is restarted, No effect! -
well unless your really still on v8, WebDialog seems to not be the issue...
I'll try and instal it...
john -
works with v15, but it's sooo long since I fired up SU v8, SketchUcation Plugin Store shows a 404...
maybe later...
but it did instal using Preferences >> Instal Extension...
I installed the joint push pull by rubyscript. And i'm trying to install the lib fredo..... by plugin store.
What am i doing wrong here? I push install in the plugin store then this comes out.
When i restart sketchup he says this?
A priori, you need to install LibFredo6 6.9. Did you do it (if so, you should see a submenu "LibFredo6 Settings..." in the Window menu of Sketchup.
The clue is in the message.
First load the latest LibFredo, then whatever Fredo's tools you use.
[Because the Lib has changed you need the latest tools too]
Finally restart SketchUp to complete the installations... -
Hi guys,
Thanks for the fast reply's but i think that it's going wrong on the first pic.
Pc says as you see on the pic:
You can write to main plugins folder, and...
You have a costum plugins folder.
then he give's the two folders but i can not pick one,
I have pressed enter and every button on my keyboard so i don't undestand how i properly can instal the fredo 6.3 tools. Ore choose the correct folder what is going wrong here?Thanks in advance,
Sam
Fixed it, i made the most obvious mistake ever. (schame shame shame )
I just needed to make the window bigger and choose the correct map.
Thanks again guys!!
iv come up against a really confusing issue, ALL fredo tools have stopped working, (scale, round corner, pushpull, curviloft, tool on surface) none of them do anything when i press the icons... they stopped working on 2015, uninstalled and cleaned everything out of old plugin folders (appdata loc), reinstalled and nonthing, try 2016 and the exact same thing happens, why on earth do they now no longer work?!
Have you installed the latest version of Fredo's Lib AND ALL of his plugins...
They were all updated in one go...
If not, then something might break.
If you try any of them with the Ruby Console open, then are there any relevant error messages ? -
i had installed all latest plugins and lib files, none worked, no errors on console, its like they just didnt work... ended up getting an older version of everything to work... good thing i had an out of date back up.
How did you install them. Clearly not correctly or they would have worked.
Did you get all the icons in the toolbar and menus?
yes i had all the icons, they were shown as installed in the plugins manager, they all said to be up to date.... as for installing correctly, its not hard to install an rbz now is it so dont be so arrogant or ignorant of the situation, i came here looking for help... but iv sorted it now either way, just old versions, what ever i ended up with the newer ones from either here or the plugin that downloads them automatically just caused them to fail but there was never anything wrong with the old ones anyway... unless i want to get a newer plug in for something but for now its ok
Bonjour Frédo, un grand merci pour le travail que vous faite pour rendre Sketchup très agréable à utiliser
J'ai une requête à vous demander sur l'un de vos plug "Angle inspector", serait-il possible d'avoir un sélecteur dans la barre d'outil qui donnerait le choix d'une base de calcule des angles entre 180° et 90° sur les sélections des faces rouge et verte ?
L'information sur le mode actuel de 180° un angle inférieur de 30° donne 150° en angle supérieur...
Sur un mode 90° un angle inférieur de 30° donne 60° en angle supérieur...Cette information est très utile et directement utilisable pour le réglage des fraises inclinables sur machine à bois. La cerise sur le gateau serait un labellé automatique de l'angle choisi en cliquant dessus... mais je rêve trop...
Merci encore pour vos travaux,
Patrick
wondering if someone can let me know what might be wrong with my installation or something missing - I followed the specific installation instructions from this thread - here is my folder architecture and the error messages - thanks for any help you can give
running SketchUp 2016 on OSX 10.11.1
