    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.1m Views 585 Watching
      The clue is in the message.
      First load the latest LibFredo, then whatever Fredo's tools you use.
      [Because the Lib has changed you need the latest tools too]
      Finally restart SketchUp to complete the installations...
      • P
        Poot
        Hi guys,
        Thanks for the fast reply's but i think that it's going wrong on the first pic.
        Pc says as you see on the pic:
        You can write to main plugins folder, and...
        You have a costum plugins folder.
        then he give's the two folders but i can not pick one,
        I have pressed enter and every button on my keyboard so i don't undestand how i properly can instal the fredo 6.3 tools. Ore choose the correct folder what is going wrong here?
        Thanks in advance,
        Sam
        • P
          Poot
          Fixed it, i made the most obvious mistake ever. (schame shame shame 😕 )
          I just needed to make the window bigger and choose the correct map.
          Thanks again guys!!
          • C
            coasterinc
            iv come up against a really confusing issue, ALL fredo tools have stopped working, (scale, round corner, pushpull, curviloft, tool on surface) none of them do anything when i press the icons... they stopped working on 2015, uninstalled and cleaned everything out of old plugin folders (appdata loc), reinstalled and nonthing, try 2016 and the exact same thing happens, why on earth do they now no longer work?!
              Have you installed the latest version of Fredo's Lib AND ALL of his plugins...
              They were all updated in one go...
              If not, then something might break.
              If you try any of them with the Ruby Console open, then are there any relevant error messages ?
              • C
                coasterinc
                i had installed all latest plugins and lib files, none worked, no errors on console, its like they just didnt work... ended up getting an older version of everything to work... good thing i had an out of date back up.
                  How did you install them. Clearly not correctly or they would have worked.
                  • fredo6F
                    Did you get all the icons in the toolbar and menus?
                    • C
                      coasterinc
                      yes i had all the icons, they were shown as installed in the plugins manager, they all said to be up to date.... as for installing correctly, its not hard to install an rbz now is it so dont be so arrogant or ignorant of the situation, i came here looking for help... but iv sorted it now either way, just old versions, what ever i ended up with the newer ones from either here or the plugin that downloads them automatically just caused them to fail but there was never anything wrong with the old ones anyway... unless i want to get a newer plug in for something but for now its ok
                      • P
                        patt22
                        Bonjour Frédo, un grand merci pour le travail que vous faite pour rendre Sketchup très agréable à utiliser
                        J'ai une requête à vous demander sur l'un de vos plug "Angle inspector", serait-il possible d'avoir un sélecteur dans la barre d'outil qui donnerait le choix d'une base de calcule des angles entre 180° et 90° sur les sélections des faces rouge et verte ?
                        L'information sur le mode actuel de 180° un angle inférieur de 30° donne 150° en angle supérieur...
                        Sur un mode 90° un angle inférieur de 30° donne 60° en angle supérieur...
                        Cette information est très utile et directement utilisable pour le réglage des fraises inclinables sur machine à bois. La cerise sur le gateau serait un labellé automatique de l'angle choisi en cliquant dessus... mais je rêve trop...
                        Merci encore pour vos travaux,
                        Patrick
                          Decker
                          wondering if someone can let me know what might be wrong with my installation or something missing - I followed the specific installation instructions from this thread - here is my folder architecture and the error messages - thanks for any help you can give
                          running SketchUp 2016 on OSX 10.11.1
                          • fredo6F
                            @Decker
                            Most likely, this should be solved by removing GHOSTCOMP_Dir_10 subfolder.
                            It's an old version, which contains files which are not encoded in UTF.
                            If you need GhostComp, please install the latest version 1.3a from the PluginStore
                            • E
                              essai
                              Bonjour,
                              je viens de m'inscrire au forum en mode "Free", je ne vois pas le bouton Download pour un de vos script .... ni pour "LibFredo6"
                              Il est possible de télécharger en mode Free ??
                              Merci pour votre réponse
                              Cordialement
                              • fredo6F
                                @essai
                                Le mieux est de télécharger le PluginStore tool et l'installer en extension de Sketchup. Voici le mode d'emploi.
                                Apres, il suffit d'un clic pour installer tous les plugins, inclus LibFredo6.
                                In English
                                The best is to download and install the PluginStore Tool as an extension of Sketchup. Here is the process to follow
                                Then, you can install all plugins, including LibFredo6, in one click.
                                  Fredo says the best way, BUT.
                                  If you now have an SCF membership.
                                  Now you need to login.
                                  Then you can use the PluginsStore link in the menu [above].
                                  Search for Author == Fredo6
                                  The list should show all of Fredo's entries.
                                  Click on any of them to download their plugin's RBZ...
                                  Fredo dit la meilleure façon, MAIS.
                                  Si vous avez maintenant une adhésion de SCF.
                                  Maintenant, vous devez vous identifier.
                                  Ensuite, vous pouvez utiliser le lien de PluginStore dans le menu ci-dessus.
                                  Rechercher Auteur [Author] == Fredo6
                                  La liste devrait avoir toutes les entrées de Fredo.
                                  Cliquez sur l'un d'eux pour télécharger de leur Plug-in RBZ...
                                  • E
                                    essai
                                    Merci pour votre rapide réponse.
                                    Je vais essayer.
                                    A bientôt
                                    • irwanwrI
                                      irwanwr
                                      Having this pop-up message every time SketchUp 8 starting lately
                                        I responded to your similar question in another thread.
                                        The fact that both installations expect to update [repeatedly] suggests that you don't have FULL [read/write/modify] Security permissions set up for ALL possible users listed under the Plugins folder's Properties [right-click context-menu] > Edit dialog...
                                        What is your Windows version ?
                                        Are you installing the RBZ successfully ??
                                        • irwanwrI
                                          irwanwr
                                          Yes, thank you for the quick reply Sir.
                                          Just checked the folder properties and changed the permission moment ago.
                                          Have full permission on my own PC. Didn't thought it would be different here.
                                          Thank you very much again, Sir.
                                            By default, Windows limits the permissions to all folders/subfolders/files within the 'Program Files' folder tree - including SketchUp's.
                                            Even if you are an admin you still get these permissions, preset.
                                            They can be changed manually to FULL [provided you have admin-powers].
                                            These changes should trickle down to all subfolders/files within the re-permissioned subfolder.
                                            [On Pc, but the older MAC versions there's a optional 'toggle' setting to do that trickle-down]
                                            To avoid this, since v2014 the Plugins folder was relocated into the User's AppData folder tree.
                                            Here you automatically have FULL rights.
                                            If you want to add/change ANY files in ANY other subfolders which are in ANY of the SketchUp 'Program Files' folder tree, then you'll need to fix their subfolder's permissions too [ typically these might be the Components, Materials or Styles subfolders ? ]
                                            • 51
                                            • 52
                                            • 53
                                            • 54
                                            • 55
                                            • 112
                                            • 113
                                            • 53 / 113
