    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
      alisonkr
      Okay I dumped everything out of my plugins folder to start clean again. I loaded the SketchUcationTools.rbz file in SketchUp 8 and opened up the window for it in the program. I selected Autoinstall for the LibFredo6 and restarted SketchUp with no errors. I then opened up the SketchUcation window again and Autoinstalled the RoundCorners v3.0b and restarted this time getting the following errors, I added a picture of my plugin's folder as well:
      What am I missing?
        This is a weird error...
        Works for me - I can see no problems/errors...
        Can you also do the following, copy+paste this into the Ruby Console and report the path returned...
        Sketchup.find_support_file('Plugins')
        Is this the same as the installed location of the subfolders/rb files etc ?
        Also try this and post the result...
        ENV["APPDATA"]
        Does your Windows User-Name include any unusual [accented] characters ?
        • fredo6F
          @alisonkr
          At least do you have LibFredo6 loading, i.e. do you see a menu "LibFredo6 settings..." in the Windows menu of Sketchup?
          • X
            xianglin
            Hi Fredo you have MSN number.
            Tell me this number, I want to talk to you about SketchUp's plugin.
            Thank you
              alisonkr
              This is what I get from the Ruby Console:
              Sketchup.find_support_file('Plugins') H:/Program Files (x86)/Google/Google SketchUp 8/Plugins ENV["APPDATA"] C:\Users\Alison\AppData\Roaming
              And no I don't see "LibFredo6 settings..." in the Windows menu of Sketchup. (Edit: After looking at the System Preferences > Extensions I did find the LibFredo6 Settings option and enabled it. So now I do see it in the Windows menu.)
              I was able load the Bezier Spline toolbar without any errors but nothing was added to the Windows menu.
                Shinnah1
                Version 6.8 seems to be broken. It says "An error was found when processing geometry Corner at fault is highlighted in the model" Everything works fine unless trying to use only one segment.
                  This sounds more like your geometry has a problem but you're blaming the tool. How about sharing the part of the model where you get the error. And what tool were you using when you got this message.
                    Shinnah1
                    It was not my intention to "blame the tool", but to point out a possible bug. I certainly thought my model was at fault, but tested it in several situations before concluding there may be a bug.
                    Cube.skp
                      How big is this 'box' you are trying to 'round' ?
                      The 'rounding' is currently set to be 6" - so if the object itself is smaller that that the operation will fail...
                      Giving us the [simple] problem SKP itself - with your clear intentions regarding this 'rounding' - would be more use...
                      Help us to help you...
                        It worked fine for me using the same settings so I don't think there's a problem with LibFred6 or with Round Corner. Do you have the most recent versions of both installed?
                          I agree with Dave.
                          I can round [or chamfer] the corner at 6" - no problems at all.
                          So please check you have installed the latest Lib and Plugin version - both available from the SketchUcation PluginStore...
                            Shinnah1
                            I have installed the current version of both. In fact, the chamfer (one segment) tool worked fine until I updated to latest versions. I will reinstall both and try again. Thanks for the help guys.
                            I just discovered that an in-house plugin was causing interference. Thanks again guys.
                            • I
                              ittayd
                              I installed the library by downloading the file and installing it. Now when I start sketchup I get:
                              SketchUp
                              LibFredo6: Problem of installation in creation of Data directories in C:/Windows
                              OK
                                @ittayd said:
                                I installed the library by downloading the file and installing it...
                                How did you download it?
                                Was it the RBZ from the PluginStore ?
                                How did you install it?
                                Using the Preferences > Extensions > Install Extensions... button ?
                                Have you restarted SketchUp?
                                If the file and its subfolder in your user Plugins folder ??
                                • fredo6F
                                  SketchUp
                                  OK
                                  It looks like your environment is not well defined in Windows.
                                  Normally, if you type ENV["LOCALAPPDATA"], you should get a directory under you local user name. Apparently you get C:\Windows and you do not have the permissions to create subfolders in this directory.
                                  Which Windows system do you run?
                                  • fredo6F
                                    NEW RELEASE: LibFredo6 v6.9b - 13 Nov 15
                                    LibFredo6 6.9b is a maintenance release for fixing bugs
                                    See main post of this thread for Download of LibFredo6.
                                      maxosmedia
                                      Hm... where is "download" button?
                                        Hm...It helps to look at the first post of the thread to which Fredo linked.
                                          maxosmedia
                                          Thanks Dave R! But, you links is for LibFredo6_v6.8
                                            The current version is available in the SCF Plugin Store as described in the first post of this thread. Use the SCF Plugin Store to automatically install it.
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 115
                                            • 116
                                            • 51 / 116
