    [Plugin] follow me rotate
    211 Posts 79 Posters 243.4k Views 79 Watching
      Good catch, TIG. I see back a few years ago I made the comment about putting the CN version in and getting the plugin to work. I didn't realize the CN version is really in English and never tried removing the "EN" version. Hmmm....
      • pep75P Offline
        pep75
        mmm...okay...I'll analyse TIG's "essay" thoroughly again, en then I'm going to test it...Thanks!!!
          @pep
          If you can't be bothered to read... 😒
          Here's a précis...
          Delete the file FaR .rb, which has the 'en' suffix.
          When SketchUp restarts the 'cn' version will load properly, giving you the ENglish version [perversely!]
          The faulty 'en' version will not be there to load and so no more errors at startup. 😄
          • pep75P Offline
            pep75
            Oh no TIG, then you misunderstood me...I was actually very glad with your analysis 😄..But I did what you wrote down and it still gave an error message(only deleting the cn version). I just removed the plugin, installed it again, removed the CN file...and again the error. Maybe my 'cocktail' of plugins doesn't match with this particular one! 😄
            Well please don't spend to much time on this as I'm, I guess, the only one with this problem...Thanks Tig!
              @pep
              NO !
              You do NOT remove the CN suffixed version 😒
              Leave it where it is.
              It is actually the ENglish version within the CN wrapper, owing to a code typo by the author.
              So that CN version loads and works OK - giving ENglish menus rather than the ChiNese ones it was meant to make...
              In v2014 the EN has some ChiNese text which causes failures...
              So if you remove the EN version that error will stop appearing as SketchUp starts.
              The CN one loads and works OK on its own...
              BUT the EN one will always fail in v2014, so NOT having that EN one load just stops any related errors !
              • pep75P Offline
                pep75
                Sorry, will try it! Thanks!
                  myskp99
                  Hello mates, hope one can answer this:
                  installed the rbz file of follow me and rotate and it works, but at the begining of the program i get this message:
                  Error: c:/users/ivan/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8)
                  c:/users/ivan/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/followandrotate_en.rbs:49: syntax error, unexpected end-of-input, expecting keyword_end
                  inp=Inputbox.new "±äÐθúËæ"
                  -e:1:in `eval'
                  hope some help, why does this happen?
                  thanks
                    -e:1:in `eval'
                    thanks
                    See a few posts back http://sketchucation.com/forums/viewtopic.php?p=530627#p530627 and then http://sketchucation.com/forums/viewtopic.php?p=531322#p531322
                    One of the .RBS files inside the RBZ is wrongly encoded [in Chinese!], so if you delete it the other version will load and work OK... Note the error in the file naming that is confusing - remove the EN but keep the CN version...
                    • gonashviliG Offline
                      gonashvili
                      Seems super.
                      Does it work for a free v8?
                      Can't seem to install this.
                        @gonashvili said:
                        Seems super.
                        Please [re]read the post immediately before your own...
                        http://sketchucation.com/forums/viewtopic.php?p=537020#p537020
                        You need to access this plugin's folder inside Plugins, and then delete an RBS file - illogically the EN version is wrong! - keep the CN one... 😒
                          gonashvili
                          Oh I had it working, just couldn't find it in the menu at first, then forgot to delete my post.
                          Cheers 😄
                            alnahrini
                            Hi guys,,
                            i just installed it, but i have this error message
                            Note: am using sketchup 2016
                            Error: c:/users/wasseem grou/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8)
                            c:/users/wasseem grou/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/followandrotate_en.rbs:49: syntax error, unexpected end-of-input, expecting keyword_end
                            SketchUp:1:in `eval'
                            please can any one help me..
                            thanks in advance
                              @alnahrini said:
                              Hi guys,,
                              thanks in advance
                              Read TIG's post just a few up from yours.
                                pipinek
                                After installing the plugin on SU 2015 I have the following message on SU start:
                                Error: c:/users/ddd/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8)
                                c:/users/artur/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8)
                                c:/users/ddd/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/followandrotate_en.rbs:49: syntax error, unexpected end-of-input, expecting keyword_end
                                I will be thankful for any solution to this issue.
                                Thank you in advance.
                                  You might do the same thing I suggested in the post just above yours in response to the post before that in which the poster reported the exact same problem.
                                  • I Offline
                                    irminv
                                    I installed the plugin, but I get an error message whenever I start SU.
                                    also the plugin is not visible as a toolbar.
                                    I have SU15 pro...
                                      Reread this, about using the correct [but oddly named] version http://sketchucation.com/forums/viewtopic.php?p=537020#p537020
                                        I have SU15 pro...
                                        What makes you think there is a toolbar button that is missing? If you watch the tutorial video in the first post, you see it tells you the tool is accessed through the Plugins menu which is now called the Extensions menu.
                                          Albert95
                                          Hello wikii Is it possible to update "follow me and rotate" for sketchup 2017 ?
                                          console ruby
                                          Error: #<NoMethodError: undefined method curve' for nil:NilClass> c:/users/.../appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:28:in wikii_push_pull'
                                          c:/users/.../appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:109:in block in <main>' SketchUp:1:in call'
                                          thank you
                                          Albert
                                            Albert95
                                            Hello,
                                            I followed the advice of Tig : "Find the 'en' version and remove it from the v2014 Plugins folder [find that folder using the appropriate utility in the SketchUcation submenu]."
                                            http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=13014%26amp;start=120#p530627
                                            But "FAR" does not work properly to model a rope.
                                            Can I get help
                                            thank in advance
                                            Albert
                                            follow-me and rotate in sketchup 2017
                                            • 11
                                            • 4 / 11
